SparrowHawk Test Flight Facts
David Lawrence's article in the August issue of Soaring magazine "Lord if
You're Up There." teaches us a lesson about the need to be thorough and prepared whenever we fly. The accident is also a reminder of what can happen when an aircraft is flown faster than it is designed to fly. But there are important points in the article about the SparrowHawk glider that need to be clarified. As mentioned in the article the redline of the SparrowHawk is 123 KEAS (120 KIAS) based on a calculated flutter speed of 158 KEAS. Flutter speed was exceeded during the flight (162 KIAS ~ 185 KTAS at 7,600 ft) and resulted in the destruction of the wings due to flutter, not because of a ".2.5 g load." as implied in the article. The data recorder showed that the SparrowHawk went from 80 KIAS to 162 KIAS in less than five seconds and with only 1100 FT of altitude loss. It was still accelerating at 15 KTS per second at 162 KIAS with David pulling 2.8 g's while the nose coming up but still at 45 DEG nose down. The SparrowHawk is a tough little plane and is rated at +5.6 g and -4 g using standard safety margins and would not and has not failed at speeds below redline. High speeds also lead to the failure of the BRS ballistic parachute, which is rated at a maximum deployment speed of 120 KEAS. The BRS has a decelerator ring which limits the g load at speeds below redline but had limited effect at the speeds encountered in this accident. It has been estimated that the rapid opening of the BRS at 162 KIAS caused a load of over 100 g, more than enough stress to destroy the attachment to the glider and pilot or enough stress to kill the pilot if the pilot did stay attached in the airframe. The data logs showed that in previous flights maneuvers up to 5 g's had been done. In addition the over-speeding of the aircraft was not limited to a single flight or flight maneuver. It was discovered that many instances of speeds well over redline had been completed without incident. High speed and flutter are dangerous threats to an airframe regardless of which glider we are talking about. The flights at the University of Mississippi have proven that the SparrowHawk has out-performed its calculated specifications at high speeds and through high g maneuvers and is among the most thoroughly tested gliders on the market. In no way does this mean that this or any other aircraft should be flown over redline speed. Flutter is an important risk that is not discussed enough in the soaring community. Modern gliders are so sleek that they can easily fly over redline even in non-aerobatic flight and the risk of serious flutter is multiplied at high altitudes when TAS becomes much larger than IAS. Flutter has two states: flutter, and no flutter, there is no warning other than flying too fast and once it starts the result is a destroyed airframe and often a dead pilot. Thank God you are still with us David! Greg Cole, Designer and manufacturer of the SparrowHawk and Bill Thar, Eastern USA SparrowHawk dealer · KTAS is "knots true airspeed", the airspeed of an aircraft relative to undisturbed air. · KIAS is "knots indicated airspeed", the speed shown on an aircraft's pitot-static airspeed indicator. · KCAS is "knots calibrated airspeed", the indicated airspeed corrected for position error and instrument error. · KEAS is "knots equivalent airspeed", the calibrated airspeed corrected for adiabatic compressible flow for the particular altitude. |
Correction, Mississippi State University not The University of Mississippi.
"Bill Thar" wrote in message ... David Lawrence's article in the August issue of Soaring magazine "Lord if You're Up There." teaches us a lesson about the need to be thorough and prepared whenever we fly. The accident is also a reminder of what can happen when an aircraft is flown faster than it is designed to fly. But there are important points in the article about the SparrowHawk glider that need to be clarified. As mentioned in the article the redline of the SparrowHawk is 123 KEAS (120 KIAS) based on a calculated flutter speed of 158 KEAS. Flutter speed was exceeded during the flight (162 KIAS ~ 185 KTAS at 7,600 ft) and resulted in the destruction of the wings due to flutter, not because of a ".2.5 g load." as implied in the article. The data recorder showed that the SparrowHawk went from 80 KIAS to 162 KIAS in less than five seconds and with only 1100 FT of altitude loss. It was still accelerating at 15 KTS per second at 162 KIAS with David pulling 2.8 g's while the nose coming up but still at 45 DEG nose down. The SparrowHawk is a tough little plane and is rated at +5.6 g and -4 g using standard safety margins and would not and has not failed at speeds below redline. High speeds also lead to the failure of the BRS ballistic parachute, which is rated at a maximum deployment speed of 120 KEAS. The BRS has a decelerator ring which limits the g load at speeds below redline but had limited effect at the speeds encountered in this accident. It has been estimated that the rapid opening of the BRS at 162 KIAS caused a load of over 100 g, more than enough stress to destroy the attachment to the glider and pilot or enough stress to kill the pilot if the pilot did stay attached in the airframe. The data logs showed that in previous flights maneuvers up to 5 g's had been done. In addition the over-speeding of the aircraft was not limited to a single flight or flight maneuver. It was discovered that many instances of speeds well over redline had been completed without incident. High speed and flutter are dangerous threats to an airframe regardless of which glider we are talking about. The flights at the University of Mississippi have proven that the SparrowHawk has out-performed its calculated specifications at high speeds and through high g maneuvers and is among the most thoroughly tested gliders on the market. In no way does this mean that this or any other aircraft should be flown over redline speed. Flutter is an important risk that is not discussed enough in the soaring community. Modern gliders are so sleek that they can easily fly over redline even in non-aerobatic flight and the risk of serious flutter is multiplied at high altitudes when TAS becomes much larger than IAS. Flutter has two states: flutter, and no flutter, there is no warning other than flying too fast and once it starts the result is a destroyed airframe and often a dead pilot. Thank God you are still with us David! Greg Cole, Designer and manufacturer of the SparrowHawk and Bill Thar, Eastern USA SparrowHawk dealer · KTAS is "knots true airspeed", the airspeed of an aircraft relative to undisturbed air. · KIAS is "knots indicated airspeed", the speed shown on an aircraft's pitot-static airspeed indicator. · KCAS is "knots calibrated airspeed", the indicated airspeed corrected for position error and instrument error. · KEAS is "knots equivalent airspeed", the calibrated airspeed corrected for adiabatic compressible flow for the particular altitude. |
Similar Threads | ||||
Mojave Civilian Flight test center accident...Rutan SpaceShip II propellant test explosion. | Blueskies | Piloting | 3 | July 27th 07 11:47 PM |
Fun but useless aviation facts | Magiel venema | General Aviation | 2 | February 7th 07 08:05 PM |
More facts on KVKX closing | John Swarey | Piloting | 21 | November 10th 05 12:53 PM |
Amazing facts | ZASoars | Soaring | 0 | April 8th 04 08:48 PM |
These are the facts | D. Strang | Military Aviation | 0 | March 22nd 04 03:47 AM |
