Wing Stall
Old December 9th 03, 09:36 PM
Ron Natalie
"Ray Andraka" wrote in message ...
I had a set of video magazines from sometime in the 80's that had a clip of
someone famous doing exactly that, except he used pieces of yarn and had several
dozen on the wing. I don't think I have the videos any more. It was a video
magazine for pilots that only lasted 2 or 3 issues. Wish I could remember the
name of the mag. The speaker on that segment might have been Barry Schiff. The
same series had Chuck Yeager's time to climb attempt in a conquest, and had a
segment on that gulfstream outfitted with cameras for filming aircraft in
flight.
Kerschner for sure spent some time tufting his plane. He also added little trailing
cones and some interior pendulums to work out the dynamics during spins. He
has a rather humerous talk on his escapades with this (both the results of the tests
and comments between him and ATC when he flew the tufted plane into a controlled
field).
Old December 9th 03, 09:44 PM
Ray Andraka
flight.
ShawnD2112 wrote:
Chuck,
You didn't happen to video it, did you? I've been looking for exactly that
kind of footage for my ground school class to show exactly what you've
talked about.
Shawn
"PaulaJay1" wrote in message
I did an interesting experiment in my Archer yesterday. I've read about
wing washout and know the soft stall of my Archer but yeaterday I saw it.
Using small pieces of duct tape, I put eight, six inch ribbons on the left
wing
- four along the leading edge, back about 10 inches, and four, 10 inches
forward of the trailing edge.
At 3,000 AGL, I slowly decreased speed while holding altitude. For the
longest
time they all streamed. Then the most inboard aft "came loose". Just
before
the break for the stall, all four close in ribbons were stalling and the
four
out ribbons were still streaming. The Archer stall is mild and is a
series of
scollops. The outside ribbons, in the area of the ailerons kept
streaming.
I saw what makes this a forgiving plane and a good choice for the
occasional
pilot.
Chuck
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old December 10th 03, 12:05 AM
ShawnD2112
Probably copyrighted, though.
There's the rub. Thanks for the tip, though.
Shawn
"Dave Butler" wrote in message
Various of the King Schools knowledge exam prep multimedia materials have
some
footage like that. Probably copyrighted, though.
Dave
Remove SHIRT to reply directly.
ShawnD2112 wrote:
Chuck,
that
talked about.
Shawn
it.
left
wing
longest
before
four
series of
streaming.
occasional
pilot.
Chuck
Dave Butler, software engineer 919-392-4367
A fool and his money are soon flying more airplane than he can handle.
Old December 10th 03, 01:20 AM
Bill J
I have a video of just that done with a Cherokee by someone at the
factory. It also includes an interview of the Cherokee original
engineer. Now what was his name?????......
ShawnD2112 wrote:
Chuck,
talked about.
Shawn
wing
longest
before
four
series of
streaming.
occasional
pilot.
Chuck
Old December 10th 03, 02:25 AM
Kevin
PaulaJay1 wrote:
In article eZ5Bb.272612$Dw6.930509@attbi_s02, Kevin writes:
Cool test Chuck! I assume the ribbons were straight back in normal
flight? What did they do during the stall? Sideways, upwards,
forwards, random?
-Nathan
It would get even better if you add some vortex generators .
Straight back and no flutter during normal flight.
Ribbons lifted off the wing and did random lazy circles in stall.
What does "even better" mean? I liked what I saw. Vortex generators (don't
think they are STCed for the Archer) would make the flow stick longer and the
wing break more sudden, wouldn't it.
Chuck
VG details, look at the steep climbout of the cherokee .
/www.pipermods.com/SEATBELT.html
Old December 10th 03, 02:53 AM
PaulaJay1
In article , "ShawnD2112"
writes:
Chuck,
talked about.
Shawn
Sorry Shawn, I didn't but it sure would be easy to duplicate yourself. I used
8 ribbons - 4 along the lead edge and 4 aft. Actually 6 inch pieces of yarn
and a bit of duct tape at the front. Eight or ten ribbons are plenty to show
the progressing stall. Pretty obvious to see the effect as you approach stall.
Chuck
Old December 10th 03, 08:10 AM
ShawnD2112
Cheers, Chuck. I may do that (one of these days, when I get around to it,
etc, etc, etc)
Shawn :-)
writes:
Chuck,
that
talked about.
Shawn
used
yarn
show
stall.
Chuck
Old December 11th 03, 03:59 AM
resident cynic
On Tue, 09 Dec 2003 03:49:40 GMT, Michelle P
Chuck,
You were conducting the this "experiment" in a Experimental Certified
aircraft right? ;-) Otherwise you violated the type certificate of the
aircraft.
I hope you were alone and the FAA was not watching.
It's OK if he was not carrying passengers.
Michelle
PaulaJay1 wrote:
I did an interesting experiment in my Archer yesterday. I've read about the
Using small pieces of duct tape, I put eight, six inch ribbons on the left wing
At 3,000 AGL, I slowly decreased speed while holding altitude. For the longest
time they all streamed. Then the most inboard aft "came loose". Just before
the break for the stall, all four close in ribbons were stalling and the four
out ribbons were still streaming. The Archer stall is mild and is a series of
scollops. The outside ribbons, in the area of the ailerons kept streaming.
I saw what makes this a forgiving plane and a good choice for the occasional
pilot.
Chuck
Old December 11th 03, 07:46 PM
Jim Fisher
"Bill J" wrote in message
"Papa Alpha" or something like that, wasn't it?
Jim Fisher
ANG Woman Wing Commander Doesn't See Herself as Pioneer, By Master Sgt. Bob Haskell Otis Willie Military Aviation 0 March 18th 04 08:40 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
Wing Extensions Jay Home Built 22 July 27th 03 12:23 PM
