flaps again
On Wed, 2 Jan 2008 02:25:19 +0000, rotor&wing
wrote: Ron Rosenfeld;588240 Wrote: On Tue, 1 Jan 2008 14:51:57 -0800 (PST), I've used 0 flaps once out of necessity (landing with an iced up airplane after getting into unforecast icing conditions); and I use 1/2 flaps landing out of a CATII approach to minimums. Otherwise its full flaps. --ron You have a Mooney certified for Cat2 approaches? There is a special procedure for category A aircraft used under Part 91. There are separate certifications required for the pilot and the airplane. And the pilot will only be certified in designated airplanes (not designated make and model, but designated by N#). It is not currently certified, but was some years ago. If I recall correctly, the aircraft certifcation is good for two years; the pilot certification (in that aircraft) is good for six months. The six month check rides are taken with an FAA examiner (NOT a DE) and consist of both an oral exam and also demonstrating two approaches to CAT II minimums (100'DH), one with a missed approach, and one with a full stop landing. The airplane is also checked by the FAA in order for it to be certified. I had the certification for, oh, six or seven years. I have not bothered renewing the certification for a while now. Going through the process, including the IFR practice and flying with the FAA twice a year, made me a better instrument pilot, in my opinion. --ron |
Similar Threads | ||||
flaps again | Kobra | Piloting | 107 | January 5th 08 04:31 PM |
flaps | Kobra[_4_] | Piloting | 84 | July 16th 07 06:16 PM |
flaps | Kobra[_4_] | Owning | 85 | July 16th 07 06:16 PM |
Cowl Flaps | N114RW | Home Built | 0 | June 27th 07 09:25 PM |
FLAPS | skysailor | Soaring | 36 | September 7th 05 05:28 AM |
