Laister LP-49 TE and polar info
Old April 24th 11, 03:08 AM posted to rec.aviation.soaring
Jim Meade
Default Laister LP-49 TE and polar info
I have a Laister LP-49 and am looking for a polar graph for it. I
would also like to talk to anyone who has added a total energy probe
to the vario on this glider. It has metal flight surfaces and a
plastic body with solid bulkheads. Might be a trick to plumb the line
from the vertical stab.
Old April 24th 11, 03:32 AM posted to rec.aviation.soaring
Mike[_8_]
On Apr 23, 8:08*pm, Jim Meade wrote:
I have a Laister LP-49 and am looking for a polar graph for it. *I
to the vario on this glider. *It has metal flight surfaces and a
plastic body with solid bulkheads. *Might be a trick to plumb the line
Jim,
Check here for an alternative TE solution sans the antenna part.
http://www.soaridaho.com/Schreder/Co...E_ANTENNA.html
Also consider, if all else fails, purchasing a Westerboer vario that
has electronic total energy. They work well and there is at least one
older VW920 for sale on Wings and Wheels. These also give you speed to
fly and final glide info. Used, they are a great deal.
Mike
Old April 25th 11, 12:04 AM posted to rec.aviation.soaring
Jim[_18_]
Mike
I”ve been using the electronic compensation on a cambridge 302 it
works well.
Old April 26th 11, 06:09 AM posted to rec.aviation.soaring
Hi Jim,
I used to own LP-49 #7. I installed an ILEC fuselage TE probe a bit
forward of the tail fin and it seemed to work just fine. I could not
see an easy way to mount one on the fin.
Tim
Old April 26th 11, 06:20 PM posted to rec.aviation.soaring
ray conlon
Hi Jim,
Tim
Oran Nicks published a series of articles in the Soaring Magazine in
the late 70's? about TE probes a Google search or a check of the on-
line version of old Soaring should have them.
Old June 8th 18, 08:14 PM
Jerry A Haynes Jerry A Haynes is offline
Junior Member
First recorded activity by AviationBanter: Jun 2018
Sir I am trying to find a Stabilizer and a Elevator for my LP-49, if you know of any parts or a airframe , please let me get baack in the air.
Jerry haynes. 916-230-6177.
HP-18 Polar info jim Soaring 2 September 25th 09 03:26 PM
Laister LP-15 Nugget [email protected] Soaring 7 May 24th 09 05:41 AM
Bill Laister [email protected] Soaring 1 April 15th 09 04:11 PM
LX1600 polar info Chris Davison Soaring 3 August 5th 06 09:30 PM
Spoilers on Laister Nugget? Stewart Kissel Soaring 1 January 28th 04 12:47 AM
