#11
I have problem. I correct the aileron the wrong way at takeoff
On Jan 19, 6:58*pm, bildan wrote:
You guys can't believe how nasty a ground loop can be when a wing tip catches and the glider is being pulled with he CG hook. *A nose hook will help keep you straight if a tip digs in. *A CG hook will just accelerate the ground loop. *If it happens with enough speed (or power in the case of a winch launch), you'll likely end up inverted - and dead. I'd guess from your reply that your glider has both CG and nose hooks. Many pilots have flown hundreds of aerotows without incident despite the fact that their gliders only had CG hooks. I had a few wing drop incidents with aerotow using a CG hook but those were all when using a wing runner. Most I immediately released, one or two I recovered and completed the takeoff. As a general rule I'll release as soon as the wing drops. At the start of an aerotow takeoff the probability of a high energy ground loop is very low since the ground speed is low and the acceleration is fairly low. The risk of a high energy ground loop is later in the takeoff roll and is there whether a wing runner is used or not. It is a very different situation for a winch launch. The yaw restoring moment of the tow rope is directly related to the distance from the main wheel, or from the CG once airborne. A typical CG hook is forward of both the main gear and the CG, so the moment of the tow rope is in the same sense as for a nose or belly hook and, although smaller, is still stabilizing rather than destabilizing. Given that, can you please explain why you believe a CG hook will accelerate a ground loop. Andy |
On Jan 20, 9:04*am, Andy wrote:
On Jan 19, 6:58*pm, bildan wrote: You guys can't believe how nasty a ground loop can be when a wing tip catches and the glider is being pulled with he CG hook. *A nose hook will help keep you straight if a tip digs in. *A CG hook will just accelerate the ground loop. *If it happens with enough speed (or power in the case of a winch launch), you'll likely end up inverted - and dead. I'd guess from your reply that your glider has both CG and nose hooks. *Many pilots have flown hundreds of aerotows without incident despite the fact that their gliders only had CG hooks. I had a few wing drop incidents with aerotow using a CG hook but those were all when using a wing runner. Most I immediately released, one or two I recovered and completed the takeoff. *As a general rule I'll release as soon as the wing drops. At the start of an aerotow takeoff the probability of a high energy ground loop is very low since the ground speed is low and the acceleration is fairly low. * The risk of a high energy ground loop is later in the takeoff roll and is there whether a wing runner is used or not. *It is a very different situation for a winch launch. The yaw restoring moment of the tow rope is directly related to the distance from the main wheel, or from the CG once airborne. *A typical CG hook is forward of both the main gear and the CG, so the moment of the tow rope is in the same sense as for a nose or belly hook and, although smaller, *is still stabilizing rather than destabilizing. Given that, can you please explain why you believe a CG hook will accelerate a ground loop. Andy Andy you assume too much. I don't have a nose hook. I wrote, "If it happens with enough speed (or power in the case of a winch launch)". I think that makes the distinction between aero tow and winch launch. So, how would a CG hook accelerate a ground loop? If a wing tip catches the ground loop pivot point is now the wing tip. The pull at the CG hook will rapidly accelerate the other wing so it lightens up the weight on the main wheel. Basically, it's a Frisbee launch. Yes, it could happen with either nose or CG hooks but the CG hook will produce a more violent ground loop. If it's violent enough, the glider will roll inverted. The wing tip doesn't have to actually catch and stop. If it is retarded enough by ground friction, the pivot point shifts toward that tip enough to amplify the ground loop. |
On Jan 20, 8:42*am, bildan wrote:
On Jan 20, 9:04*am, Andy wrote: On Jan 19, 6:58*pm, bildan wrote: You guys can't believe how nasty a ground loop can be when a wing tip catches and the glider is being pulled with he CG hook. *A nose hook will help keep you straight if a tip digs in. *A CG hook will just accelerate the ground loop. *If it happens with enough speed (or power in the case of a winch launch), you'll likely end up inverted - and dead. I'd guess from your reply that your glider has both CG and nose hooks. *Many pilots have flown hundreds of aerotows without incident despite the fact that their gliders only had CG hooks. I had a few wing drop incidents with aerotow using a CG hook but those were all when using a wing runner. Most I immediately released, one or two I recovered and completed the takeoff. *As a general rule I'll release as soon as the wing drops. At the start of an aerotow takeoff the probability of a high energy ground loop is very low since the ground speed is low and the acceleration is fairly low. * The risk of a high energy ground loop is later in the takeoff roll and is there whether a wing runner is used or not. *It is a very different situation for a winch launch. The yaw restoring moment of the tow rope is directly related to the distance from the main wheel, or from the CG once airborne. *A typical CG hook is forward of both the main gear and the CG, so the moment of the tow rope is in the same sense as for a nose or belly hook and, although smaller, *is still stabilizing rather than destabilizing. Given that, can you please explain why you believe a CG hook will accelerate a ground loop. Andy Andy you assume too much. *I don't have a nose hook. I wrote, "If it happens with enough speed (or power in the case of a winch launch)". *I think that makes the distinction between aero tow and winch launch. So, how would a CG hook accelerate a ground loop? *If a wing tip catches the ground loop pivot point is now the wing tip. *The pull at the CG hook will rapidly accelerate the other wing so it lightens up the weight on the main wheel. *Basically, it's a Frisbee launch. Yes, it could happen with either nose or CG hooks but the CG hook will produce a more violent ground loop. *If it's violent enough, the glider will roll inverted. The wing tip doesn't have to actually catch and stop. *If it is retarded enough by ground friction, the pivot point shifts toward that tip enough to amplify the ground loop. Interesting point - I would think it would depend on the relative stabilizing moment along the hook-to cg pivot (inertial) and the hook- to wheel pivot versus the destabilizing moment from the wing tip to wheel pivot and the wing tip to hook pivot. Unless your wing tip hits a ton of friction (not so likely with the tip wheel Andy describes) or a relatively immovable object I doubt the glider would totally pivot around the tip. If the tip did really dig in a 25 foot moment arm is going to matter a lot more than the inches of difference between a belly hook and a cg hook for the first 15 degrees or so of rotation that are going to decide your fate. I agree that there is a bigger restoring moment arm the further forward the hook is, but it would be a pretty narrow set of circumstances where the tow rope force helps more than it hurts with the tip totally dug in. THis line of thinking does raise a question in my mind on whether tapping the wheel brake would help pull the nose straight in a wing down situation - it slows your acceleration so it's a bit of a tradeoff. I'm normally on the divebrakes until I have positive aileron control - partly for improved aileron effectiveness (not sure this has ever been proven but it doesn't seem to hurt) and partly to have them unlocked in case I need to pull the plug and get stopped. From experience I will say if the wing goes down (tip skids, not wheels) and you are on a typical asphalt runway you will have only a 2-count to get it back up before your are sure to end up in the weeds - be ready and don't try to save it - once you get 15-degrees off runway heading you just won't get it straightened out in time. Excellent point on wing running technique - I always tell wing runners to let the wing go up or down in response to the force they feel - a foot or two so I can notice and correct, but not all the way to the ground. They don't always get it. If you don't trust your wing runner consider your options. One day last year I had a choice between three wing runners - one in flip-flops, one with a bad hip and one who'd never run a wing before. Who would you choose? 9B |
I see nothing in your reply that convinces me that making a wing low
aerotow retrieve from a paved runway using a wing tip wheel and a CG hook is an unacceptable risk. Andy |
Although slightly off-topic, the gyro effect of the wheel on bicycles
and motorbikes is not nearly as important as most people think. Check out tests run with a contra-rotating wheel attached to the front wheel of a bicycle: http://www2.eng.cam.ac.uk/~hemh/gyrobike.htm Mike |
On Jan 20, 10:46*am, wrote:
On Jan 20, 8:42*am, bildan wrote: Excellent point on wing running technique - I always tell wing runners to let the wing go up or down in response to the force they feel - a foot or two so I can notice and correct, but not all the way to the ground. They don't always get it. If you don't trust your wing runner consider your options. *One day last year I had a choice between three wing runners - one in flip-flops, one with a bad hip and one who'd never run a wing before. Who would you choose? 9B I'd take any of them but give special instructions. 1. Balance the glider carefully so it takes 5 or 6 seconds for the wing to drop when released. 2. Don't run, just stand there and let the tip go as the glider starts to move. I will carefully center the ailerons so the wing runner can precisely balance the glider and not move them again until the glider starts to move and then only if a wing starts down. I'm often airborne before any serious aileron inputs are needed. This technique works extremely well and is easy to teach - please give it a try. The current system doesn't properly divide the task between pilot and runner and they often fight each other. Bill Daniels |
On Jan 20, 2:07*pm, bildan wrote:
On Jan 20, 10:46*am, wrote: On Jan 20, 8:42*am, bildan wrote: Excellent point on wing running technique - I always tell wing runners to let the wing go up or down in response to the force they feel - a foot or two so I can notice and correct, but not all the way to the ground. They don't always get it. If you don't trust your wing runner consider your options. *One day last year I had a choice between three wing runners - one in flip-flops, one with a bad hip and one who'd never run a wing before. Who would you choose? 9B I'd take any of them but give special instructions. 1. *Balance the glider carefully so it takes 5 or 6 seconds for the wing to drop when released. 2. Don't run, just stand there and let the tip go as the glider starts to move. I will carefully center the ailerons so the wing runner can precisely balance the glider and not move them again until the glider starts to move and then only if a wing starts down. *I'm often airborne before any serious aileron inputs are needed. This technique works extremely well and is easy to teach - please give it a try. *The current system doesn't properly divide the task between pilot and runner and they often fight each other. Bill Daniels I should have added some more context to my multiple-choice question: - 10 kt crosswind with gusting - 6,000 field elevation - 90+ degrees F That's not a circumstance where I recommend just letting go of the tip. I do always direct wing runners to hold the tip by the trailing edge so it's hard to push or pull the nose around. Another decent piece of advice to to have the towplane run the engine up before releasing the brakes - even if you get a little catapult from the stretch in the tow rope you'll still get to Vmc more quickly. 9B |
On Jan 20, 4:48*pm, wrote:
On Jan 20, 2:07*pm, bildan wrote: On Jan 20, 10:46*am, wrote: On Jan 20, 8:42*am, bildan wrote: Excellent point on wing running technique - I always tell wing runners to let the wing go up or down in response to the force they feel - a foot or two so I can notice and correct, but not all the way to the ground. They don't always get it. If you don't trust your wing runner consider your options. *One day last year I had a choice between three wing runners - one in flip-flops, one with a bad hip and one who'd never run a wing before. Who would you choose? 9B I'd take any of them but give special instructions. 1. *Balance the glider carefully so it takes 5 or 6 seconds for the wing to drop when released. 2. Don't run, just stand there and let the tip go as the glider starts to move. I will carefully center the ailerons so the wing runner can precisely balance the glider and not move them again until the glider starts to move and then only if a wing starts down. *I'm often airborne before any serious aileron inputs are needed. This technique works extremely well and is easy to teach - please give it a try. *The current system doesn't properly divide the task between pilot and runner and they often fight each other. Bill Daniels I should have added some more context to my multiple-choice question: - 10 kt crosswind with gusting - 6,000 field elevation - 90+ degrees F That's not a circumstance where I recommend just letting go of the tip. *I do always direct wing runners to hold the tip by the trailing edge so it's hard to push or pull the nose around. Another decent piece of advice to to have the towplane run the engine up before releasing the brakes - even if you get a little catapult from the stretch in the tow rope you'll still get to Vmc more quickly. 9B That would take a little more skill from the wing runner but the basic balancing technique still works better than the traditional way. 10,000' + density altitudes are routine for me as are gusty crosswinds. The only change I would make is to ask the wing runner to run a bit. The glider can be balanced against a crosswind even if it's gusty - just not as precisely which is why he needs to run a little. It's frustrating for me as a wing runner to be trying to balance a glider and the pilot won't let me do it. If they will just put the ailerons in neutral long enough for me to find the balance point, the takeoff will go a lot better. Bill Daniels |
Similar Threads | ||||
I have problem. I correct the aileron the wrong way at takeoff | bildan | Soaring | 3 | January 19th 09 08:04 PM |
I have problem. I correct the aileron the wrong way at takeoff | Doug Hoffman | Soaring | 0 | January 19th 09 05:38 PM |
Problem on takeoff | AAS | Simulators | 4 | September 30th 04 08:39 AM |
Flap/aileron don't line up -- always a problem? | Ben Jackson | Owning | 4 | April 13th 04 01:53 AM |
Takeoff with a problem? | Rocky | Piloting | 14 | January 23rd 04 02:26 PM |
