Head orientation in turns--how is it taught for aviation?
On Jun 10, 1:33 pm, Mxsmanic wrote:
I can't find 61-104; do you have a pointer to it? Can't successfully Google anymore? Suicide watch for you. F-- |
On Jun 10, 1:26 pm, Mxsmanic wrote:
Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). That means real pilots get disoriented in visual flight. Amazing factoid. Here you go again. F-- |
Mxsmanic,
When you learn to ride a motorcycle, you're taught to keep your head normal to the horizon in turns ... because turning your head with the bike as you lean into a turn results in disorientation. So what is the difference between a bike and a plane in a turn? And why would your idea below lead to more disorientation in a plane, not less? You can figure it out. Just try. Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). Ah, I was wondering what angle you would come up with this time to present a really stupid idea as wisdom superior to what actual pilots do. You never fail to deliver. I guess it requires some kind of intellect... -- Thomas Borchert (EDDH) |
Mxsmanic wrote
I note from in-cockpit videos of aerobatic pilots that they keep their heads level with the horizon, not level with the aircraft. Because they are not normally operating in coordinated flight. Bob Moore |
Mxsmanic wrote
but if your head is level with the wings (and the turn is coordinated), you'll incorrectly perceive the turn as a climb or descent. I can easily see how this latter policy would encourage disorientation. The perception of a climb or descent is primarily through your butt not the head. Bob Moore |
In rec.aviation.piloting Mxsmanic wrote:
Bob Moore writes: Head and body should remain perpendicular to the floor of the cockpit. This comes naturally if the turn is coordinated. Interesting. When you learn to ride a motorcycle, you're taught to keep your head normal to the horizon in turns ... because turning your head with the bike as you lean into a turn results in disorientation. How relevant. Next you want to tell us what you do in a sailboat? Perhaps pilots would be less prone to disorientation if they kept their heads normal to the horizon, even in turns (for instrument flight, this would mean keeping one's head level with the horizon of the attitude indicator). You really are terrified by the thought of disorientation, aren't you? I note from in-cockpit videos of aerobatic pilots that they keep their heads level with the horizon, not level with the aircraft. Did you bother to note whether or not the manuever was cooridinated or do you think all aerobatic manuevers are coordinated 100% of the time? -- Jim Pennino Remove .spam.sux to reply. |
Viperdoc writes: Now, please proceed to impress us with your knowledge about the vestibular system. I know that if it isn't disturbed, it isn't confused. I also know that if your head is level with the horizon, you'll feel turns as a sideways movement, but if your head is level with the wings (and the turn is coordinated), you'll incorrectly perceive the turn as a climb or descent. I can easily see how this latter policy would encourage disorientation. And just how would you "know" this, simulator boy? If a turn is coordinated, you don't feel a turn no matter how your head is oriented. Abrupt climbs or descents are perceived in your butt. Continuous climbs or descents are perceived by the location of the horizon relative to the nose of the aircraft. -- Jim Pennino Remove .spam.sux to reply. |
Thomas Borchert writes:
So what is the difference between a bike and a plane in a turn? None, if the turn is level and coordinated, from a vestibular standpoint. And why would your idea below lead to more disorientation in a plane, not less? You can figure it out. Just try. Explain it to me. |
Bob Moore writes:
Because they are not normally operating in coordinated flight. Why would that make a difference? What they seem to be doing is minimizing the tilting of their heads, just as motorcycle racers, ballet dancers, and ice skaters do. |
Similar Threads | ||||
Question: Standard rate turns, constant rate turns, and airspeed | Robert Barker | Piloting | 5 | April 15th 07 04:47 PM |
CAP Orientation Pilot? | Robert M. Gary | Piloting | 7 | August 3rd 05 02:22 AM |
ADV: AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | General Aviation | 0 | December 30th 03 11:37 AM |
ADV: GREAT AVIATION T-SHIRTS & HEAD GEAR | Kates Saloon and Knife Emporium | Aviation Marketplace | 0 | December 30th 03 11:36 AM |
sounds of aviation navigation equipment as head on a scanner radio | Dan Jacobson | Instrument Flight Rules | 5 | December 4th 03 07:27 PM |
