#31
787 Story by Dan Rather
Mxsmanic wrote in
: Larry Dighera writes: While it is evident that Mr. Vincent A. Weldon is qualified to issue his concerns in his comment on this issue, I fail to see how the carbon-fiber composite construction of the Boeing 787-8 is significantly different from that used in many military aircraft. It's not ... but military aircraft and personnel are considered much more expendable than civilian aircraft and personnel, so the threshold of acceptable risk is much higher. Hmm. He raises some points about Boeing's cost cutting to reduce assembly time and weight, but those should be easily addressed. My major concern about the 787 is that so little of it is actually produced by Boeing, and is actually farmed out to all sorts of foreign contractors of questionable reliability, either to increase profit margins or for political reasons. You are an idiot Bertie |
#32
#33
On Sep 20, 11:59 am, Mxsmanic wrote:
My major concern about the 787 is that so little of it is actually produced by Boeing, and is actually farmed out to all sorts of foreign contractors of questionable reliability.... How could you possibly know this? F-- |
#34
On Sep 20, 2:55 pm, Mxsmanic wrote:
writes: Which is different from the 777 how? Most of the 777 is made by external suppliers. I was under the impression that this was much more extreme in the case of the 787. Does Boeing build the wing for the 777? Yes, Boeing makes the wing and the 41 section on the 777, but most of the fuselage sections and empenage are made by suppliers, as are the engines, avionics, hydraulics system components, etc. etc. Boeing designs it, contract suppliers build most of the sub assemblies, and then Boeing puts all the pieces together to make the airplane. The 787 is not much different in this regard except for doing the wings in Japan this time, mostly because they are composite. |
#35
Mxsmanic wrote in
: writes: Which is different from the 777 how? Most of the 777 is made by external suppliers. I was under the impression that this was much more extreme in the case of the 787. Does Boeing build the wing for the 777? Yes, that's why they call it a Boeing Aircraft fjukktard. Does Citroen forge the wrist pins for youe 2CV? Bertie |
#36
#37
#38
Bertie the Bunyip writes:
Yes, that's why they call it a Boeing Aircraft fjukktard. So, given that Boeing doesn't build the wing for the 787, what should it be called? The Mitsubishi 787? Does Citroen forge the wrist pins for youe 2CV? The 2CV ended production long ago. I've been in one, but I've never driven one, and I have no desire to do so. |
#39
Mxsmanic wrote in
: writes: The 787 is not much different in this regard except for doing the wings in Japan this time, mostly because they are composite. That's a really huge difference. The wings are the aircraft. No there isn't, fjukkwit. Which explains why you aren't welcome at EADS, eh? Does Boeing still do much of anything, other than print the invoice? Fjukkwit Bertie |
#40
Mxsmanic wrote in
: Bertie the Bunyip writes: Yes, that's why they call it a Boeing Aircraft fjukktard. So, given that Boeing doesn't build the wing for the 787, what should it be called? The Mitsubishi 787? Doesn't matter, fjukktard. Boeing designed it and Boeing oversee it's manufacture. The place of manufacture is unimportant. Your dearth of knowledge about manufacturing is simply breathtaking, fjukkwit. Does Citroen forge the wrist pins for youe 2CV? The 2CV ended production long ago. So what, that doesn't anser the question, fjukkwit. I've been in one, but I've never driven one, and I have no desire to do so. Because you couldn't. Bertie |
Similar Threads | ||||
story behind | Mal[_4_] | Soaring | 8 | July 18th 07 05:07 AM |
Another Story | Michelle P | Piloting | 8 | September 28th 05 02:13 PM |
another "either you are with us ..." story | Jeff Franks | Piloting | 2 | December 31st 03 12:04 AM |
WW2 Story | Mike Marron | Military Aviation | 2 | September 15th 03 05:45 PM |
WW2 Story | Mike Marron | Military Aviation | 1 | September 1st 03 10:25 PM |
