Looking for user comment : Oil Sump Heater
Old November 24th 03, 10:01 PM
Javier Gorordo
Default Looking for user comment : Oil Sump Heater
If anyone has experience with the Reiff's HotStrip Oil Sump Heater,
will appreciate any input as to its usefulness/performance.
Specifically, I wonder how well (how fast) this pair of 100W heater
strips can warm up a cold-soaked sump (8-qts) in an O-300 (open
hangar, assume low in the 20s overnight).
Plan is to rig it with a thermostat and an outdoor timer to have it
maintain a certain sump temperature, but figure that the ultimate
worst scenario will be to heat up from the 20s. Plane is in an open T
hangar.
Thanks in advance
Javier Gorordo
c/o N1190F
08C, MI
Old November 24th 03, 10:36 PM
Chris Kennedy
I have their 'turbo XP' system on my 540 I can't speak to actual rise
time, since I usually just wander over and plug the thing in the night
before. It _has_ been trouble free and the 540 seems to enjoy being
warmed even when it's not been cold soaked.
I have their engine and prop covers as well. I _have_ done some futzing
with those and find that they _do_ make a difference (without them the
oil pan, cylinders and heads will be warm to the touch, but with them
everything under the cowl is nice and toasty). I'm not sure what the
contribution would be on an engine with a solid crank, but with a
constant speed prop the prop cover seems to make quite a difference.
Old November 24th 03, 11:35 PM
Victor J. Osborne, Jr.
I put the Reiff system on my A36 and it was easier to install than the Tanis
system.
It works as advertised.
Thx, {|;-)
Victor J. (Jim) Osborne, Jr.
take off my shoes to reply
Old November 25th 03, 12:49 AM
MichaelR
I use a Reiff oil sump heater along with a large mover's blanket on the cowl
and prop. Plug it in the night before and everything is in great shape the
next morning. Never had a problem with it.
"Javier Gorordo" wrote in message
m...
hangar.
Thanks in advance
Javier Gorordo
c/o N1190F
08C, MI
Old November 29th 03, 02:40 AM
News Groups
I have the new hotstrip sump heaters in mine and leave it on all the time as
it has a thermostat. Works like a charm and was very easy to install. Do use
a blanket to cover the nose.
Will recommend.
Mani
"MichaelR" wrote in message
cowl
m...
hangar.
Thanks in advance
Javier Gorordo
c/o N1190F
08C, MI
Old December 1st 03, 04:50 PM
Steven P. McNicoll
m...
hangar.
I purchased a Hot Padd heater from Reiff. The heater could not be mounted
on my engine in accordance with the supplied instructions, so I made do as
best I could. The adhesive didn't cure and the pad easily peeled off. I
returned the pad to Reiff for a refund, they sent it back to me with more
adhesive. Apparently I violated the warranty by not following the
instructions to the letter, (the fact that it was impossible to follow them
was of no interest to Reiff). I don't know if the Reiff heater is any good
or not, I do know that their product support and customer relations are
terrible. I won't do business with them again.
Old December 1st 03, 04:56 PM
Steven P. McNicoll
"Ron Rosenfeld" wrote in message
Steve McNicoll (a contributor to this group) had a bad experience with the
Reiff oil sump heater.
My bad experience was with the installation procedure and with Reiff's
customer service. The heater itself may have been a fine product, but as it
could not be installed on my aircraft in accordance with the supplied
instructions and adhesive I never had the opportunity to learn if it was.
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
