Panel Materials
I am getting ready to replace the panel in my Ventus B. Are there any
standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? |
Panel Materials
On Sep 27, 9:39 am, Tim Taylor wrote:
I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? There is a company: Aerospace Composite Products, that has various types of pre-make composite panels. All are carbon or glass with various "fillers" of foam, glass, and something they call Corelite Other panels of thicknesses over .5 inch are done with foam and balsa. http://www.acp-composites.com/ I would check with them regarding using one of their panels to make the blank. I used many of their products in the past and they're always top of the line. Mike |
Panel Materials
On Sep 27, 10:39 am, Tim Taylor wrote:
I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? For a panel I wouldn't bother with a core. I would just make it about 1/8 of Glass. Depending on the Glass this usually only about 4 to 6 layers of glass if I recall correctly. Maybe a few more if you vacuum bag it. If you really need a thin core you might look at just using a peice of aircraft plywood. Brian Case CFIIG/ASEL |
Panel Materials
I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? For General purpose Epoxy fiberglass work I would recommend MGS Epoxy. If you saw the floorpan in my HP16, that is what was made with. For the Glass I would just use Rutan Bidirectional Cloth. This is very simlar to some of german cloth used in sailplanes (Also simlar to what I used on my floorpan) Both are available from Aircraft Spruce and are reasonably priced. Brian Case HP16T N16VP |
Panel Materials
Tim Taylor wrote:
I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? Fixed panels are sometimes part of the cockpit structure or safety design of the glider; e.g., to break instead of injuring the pilot's legs. Check with the manufacturer before using a different material, or if the glider is old enough, they might now recommend a different material than the original material. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Panel Materials
I just looked a the MGS Resin, It has just about doubled in price
since I last bought some. Aeropoxy is good as well but the MGS is much nicer to use and probably a bit stronger IMO than the Aeropoxy |
Panel Materials
On Sep 27, 4:36 pm, SoaringXCellence wrote:
On Sep 27, 9:39 am, Tim Taylor wrote: I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? There is a company: Aerospace Composite Products, that has various types of pre-make composite panels. All are carbon or glass with various "fillers" of foam, glass, and something they call Corelite Other panels of thicknesses over .5 inch are done with foam and balsa. http://www.acp-composites.com/ I would check with them regarding using one of their panels to make the blank. I used many of their products in the past and they're always top of the line. Mike Make sure you have some kind of rounded flange around your legs, lest the panel turn into a knife in an accident. You'll note all new gliders have this feature. Make a mold with a thick piece of wood, rounding the corners, and lay up a non-sandwich panel for best results. Its easy and much safer than a simple panel (especially a metal panel). Hope this helps, Best Regards, Dave "YO" |
Panel Materials
I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? Tim, The ventus b uses the panel as a part of the structure of the fuselage. I molded a panel of fiberglass using a plywood mold, installed and found that the canopy made strange creeking sounds when under load in a pull up. I installed a 1/4" X 2.5" bar approximatle 8 inches in front of the panel attached to the sides of the fuselage rail to provide support so the fuselage would not flex. Richard www.craggyaero.com |
Panel Materials
On Sep 27, 1:36 pm, SoaringXCellence wrote:
On Sep 27, 9:39 am, Tim Taylor wrote: I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? There is a company: Aerospace Composite Products, that has various types of pre-make composite panels. All are carbon or glass with various "fillers" of foam, glass, and something they call Corelite Other panels of thicknesses over .5 inch are done with foam and balsa. http://www.acp-composites.com/ I would check with them regarding using one of their panels to make the blank. I used many of their products in the past and they're always top of the line. Mike The carbon fiber will be hard to cut and drill and will probably require carbide tools. I would recommend fiberglass. Also if you mold a fiberglass panel you can mold one with out the sharp edges. Richard www.craggyaero.com |
Panel Materials
"Richard" wrote in message oups.com... On Sep 27, 1:36 pm, SoaringXCellence wrote: On Sep 27, 9:39 am, Tim Taylor wrote: I am getting ready to replace the panel in my Ventus B. Are there any standard materials (especially the core) and recommended glass and core thickness used to layup a new one? This is a fixed panel, does not pop up when the canopy is opened. I was thinking of using a 1/16" to 1/8" core of DIVINYCELL. So far the thinest I can find is 1/8", is this too thick and will it handle the compression of mounting screws through it? There is a company: Aerospace Composite Products, that has various types of pre-make composite panels. All are carbon or glass with various "fillers" of foam, glass, and something they call Corelite Other panels of thicknesses over .5 inch are done with foam and balsa. http://www.acp-composites.com/ I would check with them regarding using one of their panels to make the blank. I used many of their products in the past and they're always top of the line. Mike The carbon fiber will be hard to cut and drill and will probably require carbide tools. I would recommend fiberglass. Also if you mold a fiberglass panel you can mold one with out the sharp edges. Richard www.craggyaero.com I've drilled and cut carbon fiber/epoxy structures with ordinary wood and metal tools. They work fine but do require more frequent sharpening. Do wear a good respirator and eye protection when working with either fiberglass or carbon. Bill Daniels |
Similar Threads | ||||
Grounded - Where to get rid of the Building Materials? | Rocketeer | Home Built | 49 | July 22nd 06 11:43 PM |
CFI training materials | Steven Barnes | Piloting | 6 | May 8th 06 03:20 PM |
CANADIAN IFR TRAINING MATERIALS | [email protected] | Instrument Flight Rules | 1 | January 29th 05 11:51 AM |
Instrument training materials | Paul Folbrecht | Instrument Flight Rules | 3 | July 15th 04 06:01 PM |
Mixing construction materials | Neal Fulco | Home Built | 3 | October 7th 03 01:55 PM |
