#31
Altimeter Setting
On 2010/06/01 04:54 PM, Bob Whelan wrote:
ybe I was just an idiot that particular day. Also, I like to think I'd'a entered the pattern 'by eye' and not at 0' agl had that thermal not worked for me. Legality aside, use agl...*please!!!* Flying's real safe so long as you don't inadvertently hit anything. Though I don't know this for a fact, I'll bet my retirement that at best, it'll be embarrassing to inadvertently hit the earth when your 'field level' altimeter suggests you're still OK. Bob - sometimes 'common sense' isn't - W. My Std Cirrus has an elegant solution - lots of panel space. 2 Altimeters. The metres one is set to QFE. Then I at least have some idea how high the target should be on the final glide, iff the barometer has not moved too much... Helps my puny brain. The "legal" feet altimeter is always set to show MSL. Bruce --- news://freenews.netfront.net/ - complaints: --- |
#32
Altimeter Setting
OK.. MSL it is......But.......
There's a lot more to the story! Funny thing, where is REALLY matters, (collision avoidance) MSL is not used.........such as transponders, PCAS etc.....they use pressure alt, as does IFR flight above 18,000. Also flight recorders use pressure alt. Acrobatic pilots tend to use alt setting zero, since they want to know exactly where the ground is without doing math. Of course all the "experts" say that glider landing, especially off field landing, MUST be done by "visual reference to the ground" not by altimeter at all. Then there's Absolute altitude Calibrated altitude Radar altitude GPS altitude All that "Q" stuff Field elevation So called, (but incorrectly) AGL (really should be "above starting point" as the ground varies as soon as you move!) Non standard pressure lapse rates Flight for high to low pressure, flight from hot to cold, etc Mean sea level Altimeter error....(anybody know how much error is allowed?)(anybody ever go around te airport and note the differences from one altimetier to the other?) Sensitive altimeter, non sensitive altimeter? Then how about "metric" altimiters? 300 meters per revolution How about altimeters with the "zero" on the bottom So.... I trust that all you instructors teach all of this and more to your first-lesson students....don't leave ANYTHING out... law of primacy and all that..... Cookie |
#33
Altimeter Setting
On Jun 2, 11:27*am, "
wrote: snip Of course all the "experts" say that glider landing, especially off field landing, MUST be done by "visual reference to the ground" not by altimeter at all. snip Why put experts in the above in double quotes? Do you doubt that a field landing should be done by visual reference? |
#34
Altimeter Setting
On Jun 2, 7:16*am, Cats wrote:
On Jun 2, 11:27*am, "twocoolglid...@juno. com wrote: snip Of course all the "experts" say that glider landing, especially off field landing, MUST be done by "visual reference to the ground" not by altimeter at all. snip Why put experts in the above in double quotes? *Do you doubt that a field landing should be done by visual reference? No, I quoted "expert" because the same guys who are so big on altimeter setting say don't use the altimeter on landing. I am of the school that says the altimeter is not all that important, (in most common glider flying) so where you set it is not all that important either........you gotta do math in your head one way or the other! My overall point was that in situations where it really matters, like off field landings, the altimeter is not useful. Also MSL is not the "datum" used in collision aviodance. BTW "" double quotes"" would look like this "quotes" look like this.......LOL Cookie |
#35
Altimeter Setting
Just to play devil's advocate on this "zero altimeter" thing.........
Here is a scenario..... Your kid is running in a one mile track race........you want to time the race....... The race begins.....you look at your watch....the time is 12:30: 26.010 As your kid crossed the finish line you look again at you watch...........12:35:49 070 How fast did the kid do the mile? Now, when my kid starts the race, I had my watch set at 0:00:00.000 At the finish it reads.......5:23.060..........done! no math! Altimeter is a TOOL.......tool's are for the ease of use of the user.......My tools work for me, I don't work for my tools. Tools can be used in different ways for different purposes. Using MSL on the altimeter does serve a good purpose for many situations, but not all........ Cookie Cookie |
#36
Altimeter Setting
On Jun 2, 12:39*pm, "
wrote: snip BTW * "" double quotes"" would look like this *"quotes" look like this.......LOL No, those are double double quotes. The Single quote character is this: ' The Double quote character is this: " Double quotes (plural) as you had two of them - one each end of expert. |
#37
Altimeter Setting
On Jun 2, 7:47*am, "
wrote: Just to play devil's advocate on this "zero altimeter" thing......... Here is a scenario..... Your kid is running in a one mile track race........you want to time the race....... The race begins.....you look at your watch....the time is 12:30: 26.010 As your kid crossed the finish line you look again at you watch...........12:35:49 070 How fast did the kid do the mile? Now, when my kid starts the race, I had my watch set at 0:00:00.000 At the finish it reads.......5:23.060..........done! no math! Altimeter is a TOOL.......tool's are for the ease of use of the user.......My tools work for me, I don't work for my tools. Tools can be used in different ways for different purposes. *Using MSL on the altimeter does serve a good purpose for many situations, but not all........ Cookie Cookie So what do you do when on a XC flight, not particularly high, and encounter class D airspace that you'd like to fly over? -T8 |
#38
Altimeter Setting
On Jun 2, 12:38*am, (Alan) wrote:
In article 150flivver writes: On May 31, 10:14=A0pm, GM wrote: Rolf, if memory serves me right, the FARs are clear about it: setting to MSL is required. I don't recall any regulation requiring the altimeter to be set to QNH unless the particular operation requires it (eg. an instrument approach). * 14 CFR 91.121 * (aka FAR 91.121) * For extra credit, note 91.121(a)(1)(i) which says you must use the setting from the local radio source in preference to setting to the field elevation. As was pointed out in this group a couple years ago, the examiner in the back seat knows that regulation. * * * * Alan Yeah, but as for 91.121 you're not maintaining any particular cruising altitude or flight level when operating a glider. I certainly agree that cross country gliders should be operating off QNH but if you're flying locally, you should have the option of setting QFE. I fly a towplane and use QFE 99% of the time--any position calls I make I convert to MSL (I have a table to reference on my legboard). If I have to go and retrieve a landout, I'll use QNH. |
#39
Altimeter Setting
"Yeah, but as for 91.121 you're not maintaining any particular cruising altitude or flight level when operating a glider. " The FAA legal department told me they recognize the problem / confusion with the English language usage used in the regulation. Gliders do not "cruise." However, the intent of the rule is clear. Glider pilots must be aware of airspace altitude restrictions including aircraft cruising. Recognized exceptions to setting the altimeter to MSL include crop dusting and aerobatics. Yesterday, there was a very close near-miss with a glider and commercial jet descending for a landing. The club where the glider flies commonly uses and teaches using AGL altimeter settings. It will only take a very few of these encounters for gliders to be required to have ADS-B transponders and perhaps be banned from certain airspace near airports where larger aircraft fly altogether. A new, highly accurate GPS satellite was launched yesterday. First of a series leading up to the new transponder technology. Tom Knauff |
#40
Altimeter Setting
On Jun 1, 6:11*pm, Dean wrote:
American stopped the practice when Boeing told them they wouldn't build those funky altimeters(mucho twisting up and down each takeoff and landing) for the B777. That's interesting since the same company designed and built the display systems for both the MD-11 and the 777 and that company knew how to make a QFE altimeter work very well on a PFD. Hardly any twisting at all required for the MD-11. Maybe it was the old NIH syndrome, DAC vs Boeing. Andy |
Similar Threads | ||||
WTB: used 57mm Altimeter OR swap for 80mm Altimeter | joesimmers | Soaring | 0 | November 3rd 09 11:59 AM |
setting up a Garmin 296 | Cub Driver | Piloting | 10 | October 29th 04 08:43 PM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
Setting up the workshop.... | Evan Batchelor | Restoration | 3 | March 4th 04 02:54 PM |
