PowerFLARM and GPS Antenna
On 8/15/11 3:11 PM, Cliff Hilty wrote:
I like matt's idea of putting it under the seat pan though and might consider that if you can remotely mount the flarm antenna. I'm not following what antenna you are talking about, but you need the Flarm A antenna up front on the glider, really preferably top side on the glareshield area to provide forward and upward visibility to threat aircraft. I think its the optional Flarm B antenna that Matt was talking about and that is intended to be mounted underneath the fuselage to provide improved range/coverage. There may be proximity issues with under-mounted transponders antennas and an external Flarm B/aux antenna. I certainly plan doing some playing before drilling holes for that antenna. I would make no assumptions about how any Flarm antennas are mounted on what box or via what type of coax until Flarm makes an announcement and/or has FCC approval. Darryl |
On Aug 15, 6:56*pm, Darryl Ramm wrote:
On 8/15/11 3:11 PM, Cliff Hilty wrote: I like matt's idea of putting it *under the seat pan though and might consider that if you can remotely mount the flarm antenna. I'm not following what antenna you are talking about, but you need the Flarm A antenna up front on the glider, really preferably top side on the glareshield area to provide forward and upward visibility to threat aircraft. I think its the optional Flarm B antenna that Matt was talking about and that is intended to be mounted underneath the fuselage to provide improved range/coverage. There may be proximity issues with under-mounted transponders antennas and an external Flarm B/aux antenna. I certainly plan doing some playing before drilling holes for that antenna. I would make no assumptions about how any Flarm antennas are mounted on what box or via what type of coax until Flarm makes an announcement and/or has FCC approval. Darryl Well, actually, I've been thinking of putting the brick behind the bulkhead in my plane since there just isn't enough room up front, and then putting the B antenna far forward in the nose where there is just enough room. The Schleicher mount point for a transponder antenna in an asw-19 is behind the gear in front of the rear bulkhead, and I'd like to put the unit near there. This means running the coax for the B antenna and the two data/power cables under the seat pan, which has to be removed for the annual but is a major pain to do in any case. -- Matt |
Seat pan removal on an ASW-19 is indeed tedious, because of all the
screws. But compared to the LS8, the ASW-19 seat removal is a breeze! I've got to remove bolts, screws and the rudder adjustment handle, and then figure out how to bend the very stiff, extremely hard, rigid, awkward, structural component seat pan around the spoiler rod. Re- installation is much, much worse! I do like the idea of moving the PowerFLARM brick away from the panel area. Of course, it will all depend on its dimensions, the antenna cable lengths, the antenna sizes, electrical and mechanical interference issues, etc. The PowerFLARM manual seems to me to be a bit light on installation advice (as compared, say, to the Trig manual). Am I the only one who thinks PowerFLARM brick installation is going to be a bit of a science project? Hopefully the FLARM team will address this deficiency when they release the hardware. -John On Aug 15, 10:49 pm, mattm wrote: The Schleicher mount point for a transponder antenna in an asw-19 is behind the gear in front of the rear bulkhead, and I'd like to put the unit near there. This means running the coax for the B antenna and the two data/power cables under the seat pan, which has to be removed for the annual but is a major pain to do in any case. -- Matt |
On Aug 16, 11:52*am, jcarlyle wrote:
The PowerFLARM manual seems to me to be a bit light on installation advice (as compared, say, to the Trig manual). Am I the only one who thinks PowerFLARM brick installation is going to be a bit of a science project? Hopefully the FLARM team will address this deficiency when they release the hardware. -John I'm a fan of the technology, but I've been a bit mystified at the implementation and commentary along the way. I ordered a portable way back, but had second thoughts when I got out the ruler and finally built a mockup of the thing. It isn't small (imo) and it sure didn't go well on my Schleicher instrument cowl. I thought I'd probably end up making a custom panel with the flarm device behind, taking up a lot of space. The brick + 2 1/4" Butterfly display potentially solves all those problems... unless of course the brick has a fixed antenna (let's hope not). -Evan Ludeman / T8 |
Roger that - I ordered a brick and the Butterfly 2.25" display as
well. I, too, had built a mock up and saw immediately that the PowerFLARM portable and the LS8 cockpit/panel were mutually exclusive. Now I'm trying to figure out where (and how) the antenna farm will get mounted. I agree that it won't be good if the brick has a fixed antenna... -John On Aug 16, 12:36 pm, T8 wrote: I'm a fan of the technology, but I've been a bit mystified at the implementation and commentary along the way. I ordered a portable way back, but had second thoughts when I got out the ruler and finally built a mockup of the thing. It isn't small (imo) and it sure didn't go well on my Schleicher instrument cowl. I thought I'd probably end up making a custom panel with the flarm device behind, taking up a lot of space. The brick + 2 1/4" Butterfly display potentially solves all those problems... unless of course the brick has a fixed antenna (let's hope not). -Evan Ludeman / T8 |
On Aug 16, 2:30*pm, jcarlyle wrote:
Roger that - I ordered a brick and the Butterfly 2.25" display as well. I, too, had built a mock up and saw immediately that the PowerFLARM portable and the LS8 cockpit/panel were mutually exclusive. Now I'm trying to figure out where (and how) the antenna farm will get mounted. I agree that it won't be good if the brick has a fixed antenna... -John On Aug 16, 12:36 pm, T8 wrote: I'm a *fan of the technology, but I've been a bit mystified at the implementation and commentary along the way. *I ordered a portable way back, but had second thoughts when I got out the ruler and finally built a mockup of the thing. *It isn't small (imo) and it sure didn't go well on my Schleicher instrument cowl. *I thought I'd probably end up making a *custom panel with the flarm device behind, taking up a lot of space. *The brick + 2 1/4" Butterfly display potentially solves all those problems... unless of course the brick has a fixed antenna (let's hope not). -Evan Ludeman / T8 I poked around a bit today. Butterfly aero has a "high performance antenna" listed in the German language section of their web page. It seems to be the same as the antenna described he http://sites.google.com/site/p01antenna/home This antenna looks like a good fit for what I want to do; it would be fairly easy to mount it far forward in the nose of my plane, beyond the rudder pedals. The "A" antenna would be behind the gear in my plans so therefore would be blocked from seeing forward. -- Matt |
On Aug 16, 7:46*pm, mattm wrote:
*The "A" antenna would be behind the gear in my plans so therefore would be blocked from seeing forward. If it is blocked from "seeing" forward it will also be blocked from being "seen". The transmitting antenna has to be positioned to that it radiates effectively into the highest threat volume. That seems to demand placing it in the nose of the glider. The constraints on positioning the main TX/RX antenna will be unknown until the design is approved. The available documentation indicates that the auxiliary FLARM antenna is receive only. Andy |
Similar Threads | ||||
P-51 Question | David Pride[_2_] | Aviation Photos | 3 | February 10th 08 09:53 AM |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
ILS question | Chris Brooks | Instrument Flight Rules | 71 | June 23rd 04 01:57 PM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
