#71
Robert wrote: That should be a cost for the FBO to eat, since it was their maintenance that didn't find the problem to begin with. And once they eat the cost a few times, you can bet the maintenance of the planes would improve. The radio would be replaced more regularly, etc. Or they'd go out of business or charge $20/hr more for the plane. They probably already lose money on trip rentals. I'm convinced that most FBOs only do it at all because it would be hard to sell people on flight training if they knew up front they couldn't fly beyond the hundred dollar hamburger. This $1000 thing is psycological anyway. What if it was a club with a non-refundable $1000 buy-in? No one would call that "unfair". If you fly 100 hours a year the total rental on a 172 could vary by more than $1000 easily! No one says the $85/hr 172 is unfair when compared to the $75/hr 172. Heck, you didn't even say what the rate was! That could dwarf this $1000 risk. I paid $2600 for insurance this year and they won't do a damn thing for me if I break an alternator away from home. -- Ben Jackson http://www.ben.com/ |
#72
What if it was a club with a non-refundable $1000 buy-in? An FBO exists to make money FOR THEM. A club does not. As a member of a club, YOU get to determine policy. Jose -- (for Email, make the obvious changes in my address) |
#73
John Theune wrote in
1: (Teacherjh) wrote in : My interpertation of this clause is if you take the plane somewhere and it breaks, then you must stay for 3 days while it's repaired then bring it back or else they will charge you to send someone to get it and bring it back. If it needs more then 3 days to be repaired then your not on the hook for getting it back. Seems pretty reasonable to me. They don't want you to leave a plane hundreds of miles way for a short repair and then they have to go get it. It does not mention how long the repair is scheduled to take, implying to me that regardless of whether the plane is scheduled to require 2 weeks to repair, the renter still has to stay with it for 3 days. That is an unfair policy. Also, I agree with Peter - 3 days is a bit excessive. Overnight might be appropriate... |
#74
Hi Peter,
Do the math. Using HPN FBO rates, the cost for to hire a plane and a CFI round trip to come "save" you works out to pretty close to $5/mi... But I do agree - they should put in actual cost recovery. Not a flat rate. If you get stuck in Bridgeport and the CFI can rent a one-way car for $40 to get there? "Peter Gottlieb" wrote in .net: "John Harlow" wrote in message news Now if I could only afford my own plane....... What would you do differently in this scenario if you had your own plane? You can do whatever you want. You can leave it there a week before even calling a mechanic; you can just find a way home and deal with it whenever you want. $5 a mile? Hire a plane and CFI from another FBO to get you there cheaper. This is a rip-off, plain and simple. If every FBO did that and I didn't own a plane I would give up flying before renting under such terms. How esle could they "have" you? I wouldn't trust those guys in the least. I have yet to see a contract with ONE onerous clause. Either there are none or there are a whole bunch in there, sometimes hidden. |
#75
"Judah" wrote in message ... Hi Peter, Do the math. Using HPN FBO rates, the cost for to hire a plane and a CFI round trip to come "save" you works out to pretty close to $5/mi... Arrrgggghhhh. "HPN, doing their part to show that Europe is NOT the most expensive location for aviation..." |
#76
"David Megginson" wrote in message le.rogers.com... Shiver Me Timbers wrote: If you take off in a plane you know needs to be repaired, you are violating the FARs as well as the rental policy. If anyone takes of in a plane that needs to be repaired this armchair pilot and lurker says you are dumber than a sack of hammers and a prime candidate for the darwin award. That depends on the repair. Would you take off in a rental plane with a badly-fit door seal that makes a whistling noise? What about one with a U/S ADF when you're flying VFR? Neither one of those is Darwin material or a violation of regs (since the aircraft is still airworthy). All the best, David What about duct tape on a load bearing structure? |
#77
Hahaha.
Could be worse - could be TEB! "Peter Gottlieb" wrote in .net: "Judah" wrote in message ... Hi Peter, Do the math. Using HPN FBO rates, the cost for to hire a plane and a CFI round trip to come "save" you works out to pretty close to $5/mi... Arrrgggghhhh. "HPN, doing their part to show that Europe is NOT the most expensive location for aviation..." |
#78
"Darkwing Duck (The Duck, The Myth, The Legend)" wrote in message ... "David Megginson" wrote in message le.rogers.com... That depends on the repair. Would you take off in a rental plane with a badly-fit door seal that makes a whistling noise? What about one with a U/S ADF when you're flying VFR? Neither one of those is Darwin material or a violation of regs (since the aircraft is still airworthy). What about duct tape on a load bearing structure? What COLOR duct tape? |
#79
"Peter Gottlieb" wrote in message .net... "Darkwing Duck (The Duck, The Myth, The Legend)" wrote in message ... "David Megginson" wrote in message le.rogers.com... That depends on the repair. Would you take off in a rental plane with a badly-fit door seal that makes a whistling noise? What about one with a U/S ADF when you're flying VFR? Neither one of those is Darwin material or a violation of regs (since the aircraft is still airworthy). What about duct tape on a load bearing structure? What COLOR duct tape? Gray of course! |
#80
"Darkwing Duck (The Duck, The Myth, The Legend)" wrote in message ... "Peter Gottlieb" wrote in message .net... "Darkwing Duck (The Duck, The Myth, The Legend)" wrote in message ... "David Megginson" wrote in message le.rogers.com... That depends on the repair. Would you take off in a rental plane with a badly-fit door seal that makes a whistling noise? What about one with a U/S ADF when you're flying VFR? Neither one of those is Darwin material or a violation of regs (since the aircraft is still airworthy). What about duct tape on a load bearing structure? What COLOR duct tape? Gray of course! Then you're cleared to go. I was just worried about those "designer" color tapes. |
Similar Threads | ||||
Bush's Attempt to Usurp the Constitution | WalterM140 | Military Aviation | 20 | July 2nd 04 04:09 PM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Military Aviation | 1 | April 9th 04 11:25 PM |
No US soldier should have 2 die for Israel 4 oil | Ewe n0 who | Naval Aviation | 0 | April 7th 04 07:31 PM |
CBS Newsflash: Rental trucks pose imminent and grave danger to national security | Ron Lee | Piloting | 4 | January 15th 04 03:07 PM |
