#41
Mike Rapoport wrote:
Since most of the new airplanes and all of the new high performance single engine designs are composite. Metal is a great material for airplanes but it is difficult to produce perfect shapes with in the thin sheets used in light aircraft. If you want to get more performance from your new design it is going to need ripple free compound curves over the entire fusilage and this is really hard to achieve with .025 sheetmetal. In other catagories, like utility aircraft, it doesn't seem (to me anyway) that a new design is going to offer much more than current planes like the 182 or 206. The auto companies seem to have found ways to do this, and Audi even does this with aluminum. Yes, you need some internal structure to provide stiffness, but these structures can be easily stamped or hydroformed as well as the skin. Just look inside a car that has had the interior stripped, or look under your hood or trunk lid. This technology is readily available, it has just never made its way into light aircraft. Matt |
#42
It is hard to do with real thin sheets. Cars are closer to Boeings than
Cessna's. There is a method used by Piaggio where the skin is sucked into a mold and the structure is rivited on, but this process is fairly expensive and, of course, the Piaggio has much thicker skins anyway. Mike MU-2 "Matt Whiting" wrote in message ... Mike Rapoport wrote: Since most of the new airplanes and all of the new high performance single engine designs are composite. Metal is a great material for airplanes but it is difficult to produce perfect shapes with in the thin sheets used in light aircraft. If you want to get more performance from your new design it is going to need ripple free compound curves over the entire fusilage and this is really hard to achieve with .025 sheetmetal. In other catagories, like utility aircraft, it doesn't seem (to me anyway) that a new design is going to offer much more than current planes like the 182 or 206. The auto companies seem to have found ways to do this, and Audi even does this with aluminum. Yes, you need some internal structure to provide stiffness, but these structures can be easily stamped or hydroformed as well as the skin. Just look inside a car that has had the interior stripped, or look under your hood or trunk lid. This technology is readily available, it has just never made its way into light aircraft. Matt |
#43
It is hard to do with real thin sheets. Cars are closer to Boeings than Cessna's. There is a method used by Piaggio where the skin is sucked into a mold and the structure is rivited on, but this process is fairly expensive and, of course, the Piaggio has much thicker skins anyway. It is harder with thin sheet, but I don't know I would say it is hard in an absolute sense. I believe that the Venture kit plane had its wing skins stretch formed and they are aircraft thickness. The reality remains that the sheet metal techniques and technology being used today in aircraft production is essentially unchanged from about 60 years ago. Other industries have moved on to more modern methods, but aircraft manufacturers have not. They may have good reasons for this, certification costs, insurance, initial capital costs, etc., but the fact remains. Composite construction is great for low volume items as the tooling is very inexpensive compared to large metal stamping dies. However, for high volume production, composites actually aren't superior to metals in general. Once you have the tooling in place, you can product finely shaped metal parts at rates that composite makers can only dream of. And you don't have to deal with the environmental hazards that composites pose. I'd love to see an all metal airplane designed and built by one of the big auto makers. It would be nothing like a Cessna or Piper and likely would be indistinguishable from a Lancair. Matt |
#44
Ahh yes, sufficient volume.
"Matt Whiting" wrote in message ... Dude wrote: I would say you took his comments in a way not intended. I have to wonder about the wisdom of a metal fuselage for a new small piston plane anymore though. Wings, sure, but not the fuselage. The composites would seem to have too many advantages. At least until someone can make more progress in ways to get more curves, and more strength, with less money than is currently happening in the metal world. Which, someone likely will. Actually, technology exists to hydroform metal into large and compound curved shapes. It would be easy to eliminate almost all of the rivets in both the fuselage and wings with modern metal forming technology. I can't imagine a new design that would use the rib and skin methods developed more than 60 years ago. A truly modern metal airplane could look just as smooth as a composite and probably be even cheaper to produce given sufficient volume to justify the tooling costs. Matt |
#45
" This is a great expectation for a hobby, but not for a business! :-) Yes, and when you reach a certain point in life, isn't it great that you can make a business your hobby? Carl |
#46
"Dude" wrote in message news I can't figure out how it will get very large unless Sport pilots are allowed under the class B umbrella. I know they are not allowed in the Bravo, but can they go under? Can the LSA's go into B with a PP as PIC? Is that all decided? Sport pilots *can* fly into all classes of controlled airspace with just a logbook endorsement. See http://www.sportpilot.org/becoming/ for full details. They are not overcharging, they are not being discriminating enough. This has too affects. One, it raises claims because it does not discourage the use of poorly designed planes. Two, it reduces overall safety by the same mechanism. I think you may be grossly overestimating the variability of safety here. While one can find interesting point cases of disparity (such as night IFR in Mooneys vs. other makes) overall I suspect the deltas just aren't that significant. Likewise it may be that accidents are distributed pretty evenly throughout the pilot community. Other than an obvious period in the first couple of hundred hours and when transitioning to a new type, it may be that accident pilots-to-be look just like the rest of us most of the time. It's a sobering conclusion. Every time we read about an accident we want to find something that we can say "well I wouldn't have done THAT," when it's more like "there but for the grace of God..." Best, -cwk. |
#47
"Matt Whiting" wrote in message ... Mike Rapoport wrote: It is hard to do with real thin sheets. Cars are closer to Boeings than Cessna's. There is a method used by Piaggio where the skin is sucked into a mold and the structure is rivited on, but this process is fairly expensive and, of course, the Piaggio has much thicker skins anyway. It is harder with thin sheet, but I don't know I would say it is hard in an absolute sense. I believe that the Venture kit plane had its wing skins stretch formed and they are aircraft thickness. The reality remains that the sheet metal techniques and technology being used today in aircraft production is essentially unchanged from about 60 years ago. Other industries have moved on to more modern methods, but aircraft manufacturers have not. They may have good reasons for this, certification costs, insurance, initial capital costs, etc., but the fact remains. Composite construction is great for low volume items as the tooling is very inexpensive compared to large metal stamping dies. However, for high volume production, composites actually aren't superior to metals in general. Once you have the tooling in place, you can product finely shaped metal parts at rates that composite makers can only dream of. And you don't have to deal with the environmental hazards that composites pose. I'd love to see an all metal airplane designed and built by one of the big auto makers. It would be nothing like a Cessna or Piper and likely would be indistinguishable from a Lancair. Matt I agree with your above statements except for the implied notion that there is a high volume market for any airplane. Mike MU-2 |
#48
"Matt Whiting" wrote in message ... Mike Rapoport wrote: It is hard to do with real thin sheets. Cars are closer to Boeings than Cessna's. There is a method used by Piaggio where the skin is sucked into a mold and the structure is rivited on, but this process is fairly expensive and, of course, the Piaggio has much thicker skins anyway. It is harder with thin sheet, but I don't know I would say it is hard in an absolute sense. I believe that the Venture kit plane had its wing skins stretch formed and they are aircraft thickness. The reality remains that the sheet metal techniques and technology being used today in aircraft production is essentially unchanged from about 60 years ago. Other industries have moved on to more modern methods, but aircraft manufacturers have not. They may have good reasons for this, certification costs, insurance, initial capital costs, etc., but the fact remains. Composite construction is great for low volume items as the tooling is very inexpensive compared to large metal stamping dies. However, for high volume production, composites actually aren't superior to metals in general. Once you have the tooling in place, you can product finely shaped metal parts at rates that composite makers can only dream of. And you don't have to deal with the environmental hazards that composites pose. I'd love to see an all metal airplane designed and built by one of the big auto makers. It would be nothing like a Cessna or Piper and likely would be indistinguishable from a Lancair. Matt I agree with your above statements except for the implied notion that there is a high volume market for any airplane. I made no such implication. My comment about "initial capital costs" was actually in recognition that the volume available may not be sufficient to warrant the tooling costs for stamping dies. However, given that tooling costs have dropped a lot with the advent of CAD and CNC, I do wonder if it might be possible even with Cirrus-like volume. I don't know, but I do wonder. :-) Matt |
Similar Threads | ||||
FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | December 30th 04 11:16 AM |
Red Alert: Terrorist build kamikaze planes for attacks | Hank Higgens | Home Built | 5 | April 16th 04 02:10 PM |
FS: 1989 "War Planes" (Of The World) Cards with Box | J.R. Sinclair | Aviation Marketplace | 0 | April 15th 04 06:17 AM |
Conspiracy Theorists (amusing) | Grantland | Military Aviation | 1 | October 2nd 03 12:17 AM |
FS: 1989 "War Planes" (Of The World) Cards with Box | Jim Sinclair | Aviation Marketplace | 0 | August 23rd 03 04:43 AM |
