Manual
Hi
I have to bring the owner manual when I fly my LS 6. I have a copy on a memory key. Is it acceptable? Regards S6 |
Manual
On Jan 17, 4:40 pm, bish wrote:
Hi I have to bring the owner manual when I fly my LS 6. I have a copy on a memory key. Is it acceptable? Regards S6 I don't know for certain, but I'd guess that the FAA would say if you can't read it on the spot, anywhere, anytime, it isn't acceptable. I printed my LS8 manual out double sided with 4 pages on each surface of a 8.5 by 11 sheet, and I carry that. It's a bit small, but very readable. I also carry a PDF copy of the manual on my iPhone. Good luck! -John |
Manual
On Jan 17, 3:56*pm, jcarlyle wrote:
On Jan 17, 4:40 pm, bish wrote: Hi I have to bring the owner manual when I fly my LS 6. I have a copy on a memory key. Is it *acceptable? Regards S6 I don't know for certain, but I'd guess that the FAA would say if you can't read it on the spot, anywhere, anytime, it isn't acceptable. I printed my LS8 manual out double sided with 4 pages on each surface of a 8.5 by 11 sheet, and I carry that. It's a bit small, but very readable. I also carry a PDF copy of the manual on my iPhone. Good luck! -John I took my manual to a Kinkos and had them reduce copy it at about 1/4 size, then laminated the front and back covers, and spiral bound the little thing. Now small enough to stick anywhere in the cockpit, and still fully usable. It's lasted over 10 years stuck in the pouch that comes with the LS6... Kirk 66 |
Manual
On Jan 17, 7:05*pm, "kirk.stant" wrote:
On Jan 17, 3:56*pm, jcarlyle wrote: On Jan 17, 4:40 pm, bish wrote: Hi I have to bring the owner manual when I fly my LS 6. I have a copy on a memory key. Is it *acceptable? Regards S6 I don't know for certain, but I'd guess that the FAA would say if you can't read it on the spot, anywhere, anytime, it isn't acceptable. I printed my LS8 manual out double sided with 4 pages on each surface of a 8.5 by 11 sheet, and I carry that. It's a bit small, but very readable. I also carry a PDF copy of the manual on my iPhone. Good luck! -John I took my manual to a Kinkos and had them reduce copy it at about 1/4 size, then laminated the front and back covers, and spiral bound the little thing. *Now small enough to stick anywhere in the cockpit, and still fully usable. It's lasted over 10 years stuck in the pouch that comes with the LS6... Kirk 66 You know that in the US the manual is not required to be on board if the limitations are properly marked via placards and decals. XF |
Manual
I don't think I ever carried the manual in my LS-6, but I know that it would
easily slip behind the seat. Seriously, if you need to be reading the manual in flight, you shouldn't be flying... "lanebush" wrote in message ... On Jan 17, 7:05 pm, "kirk.stant" wrote: On Jan 17, 3:56 pm, jcarlyle wrote: On Jan 17, 4:40 pm, bish wrote: Hi I have to bring the owner manual when I fly my LS 6. I have a copy on a memory key. Is it acceptable? Regards S6 I don't know for certain, but I'd guess that the FAA would say if you can't read it on the spot, anywhere, anytime, it isn't acceptable. I printed my LS8 manual out double sided with 4 pages on each surface of a 8.5 by 11 sheet, and I carry that. It's a bit small, but very readable. I also carry a PDF copy of the manual on my iPhone. Good luck! -John I took my manual to a Kinkos and had them reduce copy it at about 1/4 size, then laminated the front and back covers, and spiral bound the little thing. Now small enough to stick anywhere in the cockpit, and still fully usable. It's lasted over 10 years stuck in the pouch that comes with the LS6... Kirk 66 You know that in the US the manual is not required to be on board if the limitations are properly marked via placards and decals. XF |
Manual
You know that in the US the manual is not required to be on board if the limitations are properly marked via placards and decals. XF That's news to me! Last I read, if it was listed in the TCDS or if the manual (POH) said it had to be in the glider, then it needs to be in the glider regardless of what is placarded. And the POH specifies the minimum placards. T |
Manual
On 1/17/2012 6:48 PM, T wrote:
You know that in the US the manual is not required to be on board if the limitations are properly marked via placards and decals. XF That's news to me! Last I read, if it was listed in the TCDS or if the manual (POH) said it had to be in the glider, then it needs to be in the glider regardless of what is placarded. And the POH specifies the minimum placards. I've been flying gliders in the US since 1976, and I don't recall having the manual on board ever being a safety or enforcement issue. Does anyone know of an incident involving having a manual on board? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
Manual
On Jan 17, 9:55 pm, Eric Greenwell wrote:
I've been flying gliders in the US since 1976, and I don't recall having the manual on board ever being a safety or enforcement issue. Does anyone know of an incident involving having a manual on board? It turns out that the LS8 manual is listed on the Minimum Equipment list, in an approved section of the manual. Since in 4-up format it only measures 4.25 by 5.5 inches, weighs just a few ounces, and disappears in the pouch behind the seat, it's easy to carry it. Why risk exposing yourself to bureaucratic grief over something that inconsequential? Even if the lack of a manual hasn't been the subject of a safety or enforcement action in the US yet, Mr. Murphy never rests... -John |
Manual
"T" is correct. Check the TCDS and the AFM. I would not be suprised
if they say an "approved copy" of the AFM must be carried on board, and accessible to the pilot. That would eliminate reduced size or electronic copies in my "book". That said, do what is safe, then try to be legal. Know the difference and consequences of the Rules of Nature vs the Rules of Man! |
Manual
On Jan 17, 6:55*pm, Eric Greenwell wrote:
On 1/17/2012 6:48 PM, T wrote: You know that in the US the manual is not required to be on board if the limitations are properly marked via placards and decals. XF That's news to me! Last I read, if it was listed in the TCDS or if the manual (POH) said it had to be in the glider, then it needs to be in the glider regardless of what is placarded. And the POH specifies the minimum placards. I've been flying gliders in the US since 1976, and I don't recall having the manual on board ever being a safety or enforcement issue. Does anyone know of an incident involving having a manual on board? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz I know the LS4 and most LS are probably included, also the Grob 103 Twin II require the POH in the glider. Never know when the ramp check agent will show up. T |
Similar Threads | ||||
G 103 Manual | Charlie Papa | Soaring | 2 | June 8th 09 10:12 AM |
FA: B-737 OPERATIONS MANUAL - Ops Manual for a B-737 Jet | Peter | Aviation Marketplace | 0 | December 28th 04 02:08 AM |
Manual PA-46 | Gerard Ververs | Instrument Flight Rules | 0 | November 23rd 04 08:50 PM |
Manual PA-46 | Gerard Ververs | Products | 0 | November 22nd 04 11:41 PM |
LX1000 Manual & Speed Astir Manual | Avron Tal | Soaring | 1 | June 20th 04 07:15 AM |
