'A' or 'B' circuit generator?
Old August 7th 06, 10:46 PM posted to rec.aviation.homebuilt
Default 'A' or 'B' circuit generator?
This is so embarrassing, I must just be getting old; I can't remember
if the generator in my '61 C-172 is an A or B circuit. Worse, I
forget which one is which. Does the 'A' supply controlled voltage
to the field and the 'B' does a controlled "ground out" of
voltage coming from the field or do I have it backwards? My system
seems to be charging, just not enough. It might be OK and I'm just
taking too many short hops with too many bells and whistles on. Can
someone refresh my memory so my checks are correct?
Old August 8th 06, 08:38 PM posted to rec.aviation.homebuilt
Tri-Pacer[_1_]
A circuit field tied to voltage source inside generator and regulator
switches resistance in and out of circuit to ground to control field
current. Grounding field terminal produced full output.
B circuit field is grounded inside generator and regulator switches
resistance between field terminal and voltage source to control field
current.
Cheers:
Paul
N1431A
Old August 8th 06, 10:45 PM posted to rec.aviation.homebuilt
current.
Cheers:
Paul
N1431A
Excellent! Now...which one does the Cessna have?
Old August 9th 06, 06:05 PM posted to rec.aviation.homebuilt
Tri-Pacer[_1_]
Is the generator a Delco?
Post the part number & I'll look it up
Paul
N1431A
Old August 9th 06, 09:42 PM posted to rec.aviation.homebuilt
Paul
N1431A
Well Paul, The Cessna/Continental part # is listed as 534111 and
Delco-Remy as 1101890. That is for the stock 20 amp generator. Mine was
replaced with a 30 amp about 40+ years ago and I can't read the number
in the log book. However, I have every reason to believe that if it was
an "A" it would have been replaced with an "A" and B for B. Any help
would be appreciated.
Old August 10th 06, 03:44 AM posted to rec.aviation.homebuilt
Tri-Pacer[_1_]
..com...
Paul
N1431A
1101890 is an "A" type circuit.
Cheers:
Paul
Old November 17th 10, 02:21 PM
interzis interzis is offline
Junior Member
First recorded activity by AviationBanter: Jul 2010
Cheers:
Paul
Hello,
I have a problem, related to this topic:
I have an 1101890 generator but I don't have an original regulator for it.
Because in my country (Romania) this things are very rare I intend to adapt a car regulator.
Unfortunately I don't find a regulator for "A type" generators, just for "B type".
I have two possibilities (in my mind):
1. to switch the field's coil to ground, inside generator, making it a B type
2. to modify the regulator to provide "ground" instead "voltage" on the F pin
in attachment, the regulator's schematic BEFORE and AFTER
I suppose will work.
what should I try? 1 or 2?
I know, the best variant is to buy an original regulator, and I'll do it... but until then...
Regards,
Seb
Click image for larger version
'A' or 'B' generator circuit? jim Owning 1 August 8th 06 02:02 AM
LED and PCBs Stuart & Kathryn Fields Home Built 19 March 21st 06 09:30 AM
Need Advice: Generator in Campsite at OSH? Bob Chilcoat Piloting 4 June 27th 05 06:56 PM
C-172 landing light switch JFLEISC Piloting 16 May 6th 04 01:15 AM
Generators, redundancy, and old stories Michael Owning 2 March 3rd 04 06:25 PM
