CHANGING AWC FROM STANDARD TO EXPERIMENTAL AIR RACING
Old February 27th 17, 04:10 PM posted to rec.aviation.soaring
ZZ
Default CHANGING AWC FROM STANDARD TO EXPERIMENTAL AIR RACING
I have a PIK20B which has a Standard Airworthiness certificate. I want to change the AWC to Experimental Air Racing to facilitate two modifications: changing the drum brake to a hydraulic disk type and possibly the addition of winglets.
I would appreciate any advice and/or opinions from those who may have gone through this AWC change process.
Many thanks in advance,
Paul
ZZ
Old February 27th 17, 04:47 PM posted to rec.aviation.soaring
Dan Marotta
Contact your FSDO for the best advice to change the airworthiness
certificate. But, perhaps the brake mod at least, could be done as a
field approval. Ask your mechanic about that.
Paul
ZZ
Dan, 5J
Old March 1st 17, 01:29 AM posted to rec.aviation.soaring
2G
Paul
ZZ
Another option is to keep the Std AWC and do a 337 for these mods. If you go experimental you will have to do an annual program letter. Also, Std A/C can operate in Canada w/o additional paperwork and cost.
Tom
Atlanta FSDO and operational limitations for experimental(exhibition/air racing) sailplanes [email protected] Soaring 1 August 10th 12 11:50 AM
Converting a USA C of A from Standard to Experimental RAS56 Soaring 34 December 10th 10 06:07 AM
Art of Racing, concluded - Langelle - Glen Martin Racing.jpg (1/1) Mitchell Holman[_4_] Aviation Photos 0 February 28th 10 08:22 PM
experimental to standard certificate shkdriver Soaring 20 January 19th 10 09:25 AM
Bell OH-58 changing categories experimental to restricted Jaybird737 Rotorcraft 0 May 31st 06 11:27 PM
