"Mark Hansen" wrote in message ... On 5/17/2005 17:28, Mike Ferrer wrote: "A Lieberman" wrote in message ... Unpleasant surprise on my .411 .413 check. Person doing the check would not certify the inspection. He said that the VSI is not connected to the pitot static system. Interesting point. Although the VSI should be connected to the static system, it is not required by 91.411 or FAR Appendix E. In other words, he could have certified the system and you could have had an A&P investigate why the VSI wasn't hooked to the static system afterwards. But if the VSI is not connected to the static system, what has happed to the point where it was connected? Is the static line simply venting to the area behind the panel? Won't this affect all the other static-based instruments? ... unless someone took the time to plug the hole in the static line... The VSI will operate even though it is not connected the the official static system. However, it should be fixed. Mike -- Mark Hansen, PP-ASEL, Instrument Student Sacramento, CA Or if it was never connected to the static port. Miie MU-2 Or |
Similar Threads | ||||
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
A question on Airworthiness Inspection | Dave S | Home Built | 1 | August 10th 04 05:07 AM |
Home Inspection Listings | Patrick Glenn | Home Built | 4 | April 26th 04 11:52 AM |
100 Hour Inspection Question | FryGuy | General Aviation | 59 | November 19th 03 04:01 AM |
100 Hour Inspection Question | FryGuy | Piloting | 58 | November 19th 03 04:01 AM |
