DG 800b/808b
Hi all,
Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben |
DG 800b/808b
DG 800b/808b
Hi all, Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben Yeah... 8 ;-) Pete |
DG 800b/808b
The 8 means a lot if you need parts.
Jim |
DG 800b/808b
I don't know about the 800/808 but, a while back, I had a reasonable amount
of time in a DG500M, then I had a flight in the, "new, much improved" DG505M. The only differences I could find were, the engine instruments were on the right side of the panel instead of the left and the front seat head-rest was a different shape. At 03:23 14 March 2014, Peter von Tresckow wrote: wrote: Hi all, Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben Yeah... 8 ;-) Pete |
DG 800b/808b
At 07:33 14 March 2014, Chris Rollings wrote:
I don't know about the 800/808 but, a while back, I had a reasonable amount of time in a DG500M, then I had a flight in the, "new, much improved" DG505M. The only differences I could find were, the engine instruments were on the right side of the panel instead of the left and the front seat head-rest was a different shape. At 03:23 14 March 2014, Peter von Tresckow wrote: wrote: Hi all, Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben Yeah... 8 ;-) Pete hello Chris, Could you give the works number of the 2 DG500 series you are commenting on. Regards Karen |
DG 800b/808b
At 21:58 14 March 2014, Bob McLean wrote:
At 07:33 14 March 2014, Chris Rollings wrote: I don't know about the 800/808 but, a while back, I had a reasonable amount of time in a DG500M, then I had a flight in the, "new, much improved" DG505M. The only differences I could find were, the engine instruments were on the right side of the panel instead of the left and the front seat head-rest was a different shape. At 03:23 14 March 2014, Peter von Tresckow wrote: wrote: Hi all, Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben Yeah... 8 ;-) Pete hello Chris, Could you give the works number of the 2 DG500 series you are commenting on. Regards Karen Afraid not, it was nearly 20 years ago, in Australia. |
DG 800b/808b
The 808b has changes at the back of the fuselage to improve the rudder
authority... which was acceptable on the 800 but not stunning. A friend has an 808b and it is difficult to see the differences, but I think the fin might be a bit taller... as will the rudder... hence better rudder authority. At the time I changed the tailwheel assembly from the plain bearing type to the ball bearing version, and whilst this could clearly have no impact on the rudder authority, it felt much better as the rudder forces were reduced... I think the energency switch which is near the pilots right knee on the 800b is moved to the instrument panel... The switch from the conventional DEI to the DEI NT did not come with the DG808b, although I thing later DG808b's got this.... They are all pretty good gliders with a good performance... I did my UK750km diploma in mine and flew the UK 18m Nationals with reasonable results... Craig At 07:33 14 March 2014, Chris Rollings wrote: I don't know about the 800/808 but, a while back, I had a reasonable amount of time in a DG500M, then I had a flight in the, "new, much improved" DG505M. The only differences I could find were, the engine instruments were on the right side of the panel instead of the left and the front seat head-rest was a different shape. At 03:23 14 March 2014, Peter von Tresckow wrote: wrote: Hi all, Does anyone here know if there is a difference between a DG800b and DG808b? Thanks Ben Yeah... 8 ;-) Pete |
Similar Threads | ||||
Flight Manual For DG-400 and DG-800B | Ernst | Soaring | 6 | August 12th 10 02:34 PM |
FS DG-808B | Ed Hollestelle | Soaring | 0 | June 8th 09 01:14 AM |
DG 800B Power plug | HL Falbaum | Soaring | 3 | October 3rd 05 12:54 PM |
DG 808B | Mal | Soaring | 7 | July 23rd 05 02:47 AM |
FS DG-800B | 11w | Soaring | 0 | November 7th 03 04:15 AM |
