Wing Tape - Does Thickness Affect Performance?
Old January 22nd 07, 11:13 PM posted to rec.aviation.soaring
ContestID67
Default Wing Tape - Does Thickness Affect Performance?
No, this is not SPAM as the subject line might lead one to believe.
I have seen lots of wing tape. Many of the advertisements are for very
thin and flexible tape which conforms to the curves of the wing.
However, the cost can be prohibitive, especially if you assemble often.
A friend of mine (very high time & competitive pilot) uses 3M
electrical tape. We got to talking about it and we agreed that this
high quality tape is very flexible, has good temperature properties and
not very expensive. Easy to find also.
The only issue then was the thickness. Wouldn't the edge of the think
tape affect performance? The friend pointed out (correctly) that the
tape runs perpenticular to the span of the wing and thus the tape's
edge is parallel to the air flow. Thus no performance issues.
Any thoughts? What about with bug whippers?
Enjoy, John
PS There is one issue with 1/2" wide electrical tape - whether it is
wide enough to bridge the gap. It all depends, I suppose, on the fit
and finish of your glider.
Canard planes swept wing outer VG's? Paul Lee Home Built 8 January 4th 04 08:10 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) The Revolution Will Not Be Televised Military Aviation 161 September 25th 03 07:35 AM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
