DME recommendations
Let me start by admitting my ignorance about DME's.
In my plane I have to KX-170Bs, one indicator has GS. I also have an ADF. I have no DME, and I've never used one. I've started studying for my instrument written test. I've noticed that a large number of approaches would either be more difficult or not possible without one. So, I've been researching getting one. I don't need anything fancy, so I've been looking at older ones. Here's my question... Some DMEs seem to have an indicator, and then a separate receiver box, like the ARC 800 DME. Others I've seen just seem to be an in-panel job, like the Narco DME 190 or the King KN62A. I've seen some on Ebay, and wanted to make sure that the Narco 190/ King KN62A don't require an additional recieving unit, like the ARC 800. That is, if I were to purchase a yellow-tagged Narco 190 (and tray and connectors), would that be all I need? Antenna? Thanks, Adam N7966L Beech Super III |
Don't waste your money on a DME. Too much maintenance.
Purchase a good used IFR GPS. mindenpilot wrote: Some DMEs seem to have an indicator, and then a separate receiver box, like the ARC 800 DME. Others I've seen just seem to be an in-panel job, like the Narco DME 190 or the King KN62A. I've seen some on Ebay, and wanted to make sure that the Narco 190/ King KN62A don't require an additional recieving unit, like the ARC 800. That is, if I were to purchase a yellow-tagged Narco 190 (and tray and connectors), would that be all I need? Antenna? |
"jsmith" wrote in message ... Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. What he said! I am presently looking to replace my RNAV/DME with a new GPS. By the time you buy and install a used DME system you will be getting pretty close to a used IFR GPS. |
"Dude" wrote: "jsmith" wrote in message ... Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. What he said! I am presently looking to replace my RNAV/DME with a new GPS. By the time you buy and install a used DME system you will be getting pretty close to a used IFR GPS. What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). Unless you have some very specific reason to need DME for one of the very few things GPS can't replace it for, I think it would be foolish to invest in DME these days. |
"Roy Smith" wrote in message ... In article , "Dude" wrote: "jsmith" wrote in message ... Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. What he said! I am presently looking to replace my RNAV/DME with a new GPS. By the time you buy and install a used DME system you will be getting pretty close to a used IFR GPS. What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). Unless you have some very specific reason to need DME for one of the very few things GPS can't replace it for, I think it would be foolish to invest in DME these days. I think I'm sold on the GPS idea. Do you think it is safe to say that an airport that has an ILS-DME approach also has a GPS one? Thanks, Adam N7966L Beech Super III |
"mindenpilot" wrote:
Do you think it is safe to say that an airport that has an ILS-DME approach also has a GPS one? GPS approaches are getting more and more common. My guess is it would be pretty rare to find any airport with an ILS that didn't also have some sort of GPS approach. If you have some specific airports you plan on visiting a lot, check out specifically what approaches they have. You might even discover that the DME fixes on the ILS have GPS waypoints superimposed. For example, the ILS or LOC/DME 17 into (MHT http://204.108.4.16/d-tpp/0503/00246ILD17.PDF) |
On Sun, 03 Apr 2005 14:04:21 -0400, Roy Smith wrote:
In article , "Dude" wrote: "jsmith" wrote in message ... Don't waste your money on a DME. Too much maintenance. Purchase a good used IFR GPS. What he said! I am presently looking to replace my RNAV/DME with a new GPS. By the time you buy and install a used DME system you will be getting pretty close to a used IFR GPS. What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). FWIW, the KLN94 has the I-xxx stations in the database for doing DME to ILS stations. |
Peter Clark wrote: What he said, squared. About the only thing I can think of that you can do with a DME that you can't with a terminal-certified GPS is use it to fly an ILS-DME (because you don't have the location of the ILS DME ground station in the GPS database). FWIW, the KLN94 has the I-xxx stations in the database for doing DME to ILS stations. Cool, I didn't know that. I wonder why those fixes were dropped from the databases of more modern units? It seems like such an obvious and useful thing to have them in there. |
Roy Smith wrote:
Cool, I didn't know that. I wonder why those fixes were dropped from the databases of more modern units? It seems like such an obvious and useful thing to have them in there. The GX-50/55/60 has most, but not all, of the localizer fixes in it's database. I could never figure out their logic of leaving some out, though. Happy Flying! Scott Skylane N92054 |
The only argument for a DME is if you have an IFR GPS, there are
requirements for being able to fly your alternate with no GPS, so a DME allows you to fly VOR/DME approaches as well as ILS's requireing DME with your GPS out. |
Similar Threads | ||||
Phoenix FBO Recommendations | Robert Easton | Piloting | 5 | February 3rd 05 07:22 AM |
FBO Recommendations - Montreal | Jay Somerset | Piloting | 3 | February 1st 05 10:31 PM |
TSA's General Aviation Airport Security Recommendations Might Become Requirements | Larry Dighera | Piloting | 1 | February 25th 04 05:11 PM |
paint shop recommendations wanted (SE) | Stephen N Mills | Owning | 0 | January 29th 04 03:44 PM |
Extra Headset recommendations? | Mike Z. | Piloting | 1 | June 30th 03 10:02 PM |
