Oudie Supplemental Power Pack
Friends:
I am looking for a supplemental power pack that is easily rechargeable, reasonably compact, and will run my Oudie for 5+ hours on a single charge. Any suggestions? ROY |
On Monday, September 25, 2017 at 5:31:19 PM UTC-7, Roy B. wrote:
Friends: I am looking for a supplemental power pack that is easily rechargeable, reasonably compact, and will run my Oudie for 5+ hours on a single charge. Any suggestions? ROY https://www.amazon.com/Jackery-Premi...FNV9V9NYGRYKKQ Less than $30 from Amazon. I've had mine for a year and have been very satisfied with it. Craig |
On Monday, September 25, 2017 at 6:31:19 PM UTC-6, Roy B. wrote:
Friends: I am looking for a supplemental power pack that is easily rechargeable, reasonably compact, and will run my Oudie for 5+ hours on a single charge. Any suggestions? ROY Anything over a 3,000 mAh battery will run it for the longest of flights. The one Craig suggested is perfect. Will last multiple flights probably. |
There are many of these on eBay, but with the addition of solar charging.
Do a search on solar power bank👠I fixed mine on top of the instrument panel using Velcro. Excellent for your 5 hour flight. |
At 07:24 26 September 2017, Michael Tinkler wrote:
There are many of these on eBay, but with the addition of solar charging. Do a search on solar power bank👠I fixed mine on top of the instrument panel using Velcro. Excellent for your 5 hour flight. Add a ferrite to the power cable if it causes radio interference. Most do. |
On Tuesday, September 26, 2017 at 2:31:19 AM UTC+2, Roy B. wrote:
Friends: I am looking for a supplemental power pack that is easily rechargeable, reasonably compact, and will run my Oudie for 5+ hours on a single charge. Any suggestions? ROY I am using a very generic one I bought online called 'UNIFUN'. It has 10,400mAh plus a built in LED flashlight, in case you have to land in the dark! ;-) The size is just about the same than the Oudie and I connect the two with a short power cable and Velcro. Never ran out of juice on even the longest flights. Uli 'AS' |
If it is not a constant load then some of the "external power packs" may shut themselves off when they see no load. I don't know about the Oudie, but I've had such problems with other devices. Those battery packs that you have to start with a button push (the vast majority) are the ones to avoid. There are a few models that either have an on/off slide switch, or sense the load and automatically turn themselves on.
Similar Threads | ||||
Oudie starved for power | Matt Herron Jr. | Soaring | 11 | February 21st 17 07:34 AM |
Power pack for camping? | LincTex | General Aviation | 2 | June 26th 06 12:40 PM |
Power pack for camping? | LincTex | General Aviation | 0 | May 31st 06 11:09 PM |
Supplemental O2 and children | Peter R. | Piloting | 23 | April 18th 06 01:47 PM |
Power pack for camping? | Paul Tomblin | General Aviation | 6 | February 27th 06 03:17 PM |
