#51
How come the wings bank when I use the rudder
On Oct 26, 2:25 am, Bertie the Bunyip wrote:
Rich Ahrens wrote phouse.com: Bertie the Bunyip wrote: Actually, are you sure the 195 is zero dihedral? Most high wing airplanes that have zero dihedral look like they have anhedral. (Swick T-cart, f'rinstance) It's tapered as well. so even zero dihedral on top would still give some below! He's right, Bertie. Zero. Here's a copy of an old Cessna brochure which states so explicitly: http://cessna195.org/classic/brochur...chure=7&page=2 Yeah, zero in the top, but since it's tapered, there can't be zero on the bottom... Bertie I was looking at a 195 just Wednesday - which was having a heater installed - as I was having service on my heater at the factory... The centerline of the wing/spar has zero dihedral... And the top surface is tapered down to the tip as much as the bottom surface is tapered up... denny |
#52
Denny wrote in
oups.com: On Oct 26, 2:25 am, Bertie the Bunyip wrote: Rich Ahrens wrote phouse.com: Bertie the Bunyip wrote: Actually, are you sure the 195 is zero dihedral? Most high wing airplanes that have zero dihedral look like they have anhedral. (Swick T-cart, f'rinstance) It's tapered as well. so even zero dihedral on top would still give some below! He's right, Bertie. Zero. Here's a copy of an old Cessna brochure which states so explicitly: http://cessna195.org/classic/brochur...chure=7&page=2 Yeah, zero in the top, but since it's tapered, there can't be zero on the bottom... Bertie I was looking at a 195 just Wednesday - which was having a heater installed - as I was having service on my heater at the factory... The centerline of the wing/spar has zero dihedral... And the top surface is tapered down to the tip as much as the bottom surface is tapered up... Dunna thin so. I'll have ot look at one next time I pass one, though. Only way you could tell for sure is to sight along the top of the wing.. I usd to fly one and it was a very nice flying airplane whichever way it is arranged! Bertie |
#53
BT wrote:
Isn't interesting that entry level RC Aircraft only have rudder and elevator controls.. and then turn just fine. When the rudder is applied, a skid and a turn follow. The skid is of no consequence, but any turn rate at all is of great consequence, since tht makes the outside wing fly faster, creating more lift, and a bank is the result; a two-stage event where succession is important. Sort of like turning a bicycle, where a small jink to the outside of the intended turn is required to establish the bank needed for the turn. In a stall, you pick up the low wing with rudder, not aileron, that only adds adverse yaw, more drag on the low wing, and fights the rudder. Aileron action, following the wright Brothers wing warping, was intentionally symmetrical (same magnitude both sides) and all pilot training through and after WWII were taught "Coordination"; one applied rudder and aileron simultaneously. After WWII, civil airplane designers acted to make life simpler for the pilot by tweaking aileron action. The adverse yaw is caused by the extra induced* drag of a wing that is obliged to lift more ends up also dragging more, The inbord wing is casued to drop by an up-aileron, and any increase in parasite (non-lift) drag is exceeded by the lack of induced drag. One day the light came on and it was deduced that if only the inbirad aileron deflected up, the adverse yaw would ve greately reduced if not eliminated. Sa ther wwas born "differential movement" and belcrakx and levers were rigged such that the inbord aileron deflected up a lot, while the outboard aileron deflected very little. [*"Induced" means that it is not real friction or turbulence drag, but a new rearward force that results from a wing or aileron that is creating extra lift.] So today, most civit aircraft can be put into and out of gentle turns with aileron alone, and that's what makes single-axis autopilots (aileron only) so successful. Angelo Campanella |
#54
Angelo Campanella wrote in
: BT wrote: Isn't interesting that entry level RC Aircraft only have rudder and elevator controls.. and then turn just fine. When the rudder is applied, a skid and a turn follow. The skid is of no consequence, but any turn rate at all is of great consequence, since tht makes the outside wing fly faster, creating more lift, and a bank is the result; a two-stage event where succession is important. Not true. All the evidence you need to the contrary can be supplied by simply yawing the airplane while holding opposite aileron, thus inducing a skid, and then neutralising the ailerons. the airplane will roll left and nothing to do with the differntial speed of the wing, because there won;t be any! Bertie |
#55
....but if the wing has any significant dihedral, the 'upwind' wing will be
flying at a higher angle of attack than the 'downwind' wing, causing a roll towards the downwind wing. The 'downwind' wing inboard section will also be partially blanked by the fuselage which will also produce asymmetrical lift on the wing. -- Best Regards, Mike http://photoshow.comcast.net/mikenoel "Bertie the Bunyip" wrote in message .. . Angelo Campanella wrote in : BT wrote: Isn't interesting that entry level RC Aircraft only have rudder and elevator controls.. and then turn just fine. When the rudder is applied, a skid and a turn follow. The skid is of no consequence, but any turn rate at all is of great consequence, since tht makes the outside wing fly faster, creating more lift, and a bank is the result; a two-stage event where succession is important. Not true. All the evidence you need to the contrary can be supplied by simply yawing the airplane while holding opposite aileron, thus inducing a skid, and then neutralising the ailerons. the airplane will roll left and nothing to do with the differntial speed of the wing, because there won;t be any! Bertie |
#56
"Mike Noel" wrote in
: ...but if the wing has any significant dihedral, the 'upwind' wing will be flying at a higher angle of attack than the 'downwind' wing, causing a roll towards the downwind wing. The 'downwind' wing inboard section will also be partially blanked by the fuselage which will also produce asymmetrical lift on the wing. Xactly. Bertie |
Similar Threads | ||||
GPS instead of turn and bank | Danny Deger | Piloting | 52 | February 8th 07 02:03 PM |
X-Wings and Canard Rotor Wings. | Charles Gray | Rotorcraft | 1 | March 22nd 05 12:26 AM |
Bank Check Aviation | Ron R | Piloting | 68 | January 19th 05 01:30 AM |
BREAKING THE BANK | Cribsheet | Piloting | 0 | December 22nd 04 06:27 PM |
key bank | CSA722 | Piloting | 0 | July 14th 03 07:04 AM |
