#51
Dizziness disorientation
New Pilot wrote in
news The turning effect seems to happen over about 8 to 10 seconds to turn the aircraft 15 degrees. Once turned it seems to remain stable now pointing in a different direction. I then see that the balance ball is a little off centre. I did try turning the ruddder trim knob to the right and left but it did not seem to have much if any effect. Sounds awfully slow and consistent to be weathervaning to me. As others have said, weathervaning happens with wind gusts and you'd feel the plane being "pushed" a few degrees left or right as it was happening. More than likely it's a coordination issue. Either the rudder and/or aileron trim is off, or you're letting your feet and fingers do things that your head isn't paying attention to. You're the pilot, man. Control the plane! Watch the ball! Steep turns 45 degees or more to the right are fine, Have some trouble with turns to the left usually kicks in after one full circuit almost if the fluid in my ears is delayed in some way - Thogh i fight the sensation and can do satisfactory steep turns to the left. maybe having just done a few 45degree turns to the right and then pretty much banking to the left without stopping at the straight and level for a rest may not help. Have you tried starting with a left turn? I don't think it's completely outrageous for you to have a momentary queasy sensation as you do the 90* switch (from right 45 to left 45). It doesn't happen to me, but I can see how it might be uncomfortable for some. Loosing height quickly is no problem the ears do equalise to the pressure change - gaining height quickly in a worn PA28 does not really happen max = 750 feet/minute thats with just me fueled to tabs and no baggage. The concept of the short approach is that you're going to be doing an aggressive descent in a 30* bank turn... I'm guessing you may have some "queasiness" issues (my sister has them) and may want to talk to your AME about it. I think your "weathervaning" issues are really just letting yourself be the passenger instead of the pilot. |
#52
On 20 Jan 2008 20:44:55 GMT, Judah wrote:
New Pilot wrote in news The turning effect seems to happen over about 8 to 10 seconds to turn the aircraft 15 degrees. Once turned it seems to remain stable now pointing in a different direction. I then see that the balance ball is a little off centre. I did try turning the ruddder trim knob to the right and left but it did not seem to have much if any effect. Sounds awfully slow and consistent to be weathervaning to me. As others have said, weathervaning happens with wind gusts and you'd feel the plane being "pushed" a few degrees left or right as it was happening. More than likely it's a coordination issue. Either the rudder and/or aileron trim is off, or you're letting your feet and fingers do things that your head isn't paying attention to. You're the pilot, man. Control the plane! Watch the ball! Steep turns 45 degees or more to the right are fine, Have some trouble with turns to the left usually kicks in after one full circuit almost if the fluid in my ears is delayed in some way - Thogh i fight the sensation and can do satisfactory steep turns to the left. maybe having just done a few 45degree turns to the right and then pretty much banking to the left without stopping at the straight and level for a rest may not help. Have you tried starting with a left turn? I don't think it's completely outrageous for you to have a momentary queasy sensation as you do the 90* switch (from right 45 to left 45). It doesn't happen to me, but I can see how it might be uncomfortable for some. Loosing height quickly is no problem the ears do equalise to the pressure change - gaining height quickly in a worn PA28 does not really happen max = 750 feet/minute thats with just me fueled to tabs and no baggage. The concept of the short approach is that you're going to be doing an aggressive descent in a 30* bank turn... I'm guessing you may have some "queasiness" issues (my sister has them) and may want to talk to your AME about it. I think your "weathervaning" issues are really just letting yourself be the passenger instead of the pilot. Thanks for that, could well be just me being a passenger. The nearest to the short approach sometimes is a base leg join where I have to loose 800 feet in a short time and turning. but thats not really agressive. In response to another poster mentioning the UK weather and costs that is absolutly right. weather here has been awful on the south coast and the cost of flying Hire for 1 hour of a PA28 wet is about $250 at loose approximation US dollars Landing fee at my local airport is now $35 Touch and go is $16 and they now charge $16 for a missed approach -they waive that fee if ATC instruct a go around, |
#53
New Pilot wrote in
: Thanks for that, could well be just me being a passenger. The nearest to the short approach sometimes is a base leg join where I have to loose 800 feet in a short time and turning. but thats not really agressive. In response to another poster mentioning the UK weather and costs that is absolutly right. weather here has been awful on the south coast and the cost of flying Hire for 1 hour of a PA28 wet is about $250 at loose approximation US dollars Landing fee at my local airport is now $35 Touch and go is $16 and they now charge $16 for a missed approach -they waive that fee if ATC instruct a go around, Holy cow! That's out of control - charging for a missed approach?!?! Is this a Class B airport or something? What is their justification? How much wear & tear does your Archer cause the runway when it never even touches it! Are they concerned about the downdrafts from the ground effect? I think you should consider moving to the US. Life will be better. Especially in another two or three years... I don't think I ever paid more than $15 for a landing fee in an Archer (or even in a Bonanza, for that matter). And I've only ever heard of one airport in the US where the owner was trying to charge people for touch & goes. And I don't think he does it anymore. But even he wasn't charging for a go-around or missed approach... |
#54
On 21 Jan 2008 15:00:46 GMT, Judah wrote:
New Pilot wrote in : Thanks for that, could well be just me being a passenger. The nearest to the short approach sometimes is a base leg join where I have to loose 800 feet in a short time and turning. but thats not really agressive. In response to another poster mentioning the UK weather and costs that is absolutly right. weather here has been awful on the south coast and the cost of flying Hire for 1 hour of a PA28 wet is about $250 at loose approximation US dollars Landing fee at my local airport is now $35 Touch and go is $16 and they now charge $16 for a missed approach -they waive that fee if ATC instruct a go around, Holy cow! That's out of control - charging for a missed approach?!?! Is this a Class B airport or something? What is their justification? How much wear & tear does your Archer cause the runway when it never even touches it! Are they concerned about the downdrafts from the ground effect? I think you should consider moving to the US. Life will be better. Especially in another two or three years... I don't think I ever paid more than $15 for a landing fee in an Archer (or even in a Bonanza, for that matter). And I've only ever heard of one airport in the US where the owner was trying to charge people for touch & goes. And I don't think he does it anymore. But even he wasn't charging for a go-around or missed approach... This is fairly normal for UK GA airfields. This one has full ATC unlike a lot of smaller airfields though the largest plane usually handled are 12 seat biz jets due to the main runway being just a little over 1000 meters long. the ICAO code is EGKA. Touch and goes are charged at some rate usually half or below half of the landing fees. Seems to be factored into their running costs though I don't know the ins and outs of how their financial model works - only that it is very expensive for the humble pilot. The Fees above are based on weight and are the above for anything up to 1.5 metric tonnes they double for bigger aircraft. The missed approach fees started a few months ago. I think because aircraft from other local airfields were practicing approaches and before the wheels touched the ground putting on power and going around. This they would do a couple of times - usually flight training outfits and then they would fly merrily of back to their own airfield with a few low approaches and no touch and go fees. Aircraft from my airfield are equally guilty of the same practice and unilaterally my airfield has put this charge on theoretically to discourage the practice. that is the official line. The downside is that resident pilots may try to recover a landing to avoid the fee plus the extra 6 minutes going round the circuit instead of maybe doing the right thing and declaring a missed approach. |
#55
New Pilot wrote in
news This is fairly normal for UK GA airfields. This one has full ATC unlike a lot of smaller airfields though the largest plane usually handled are 12 seat biz jets due to the main runway being just a little over 1000 meters long. the ICAO code is EGKA. Touch and goes are charged at some rate usually half or below half of the landing fees. Seems to be factored into their running costs though I don't know the ins and outs of how their financial model works - only that it is very expensive for the humble pilot. The Fees above are based on weight and are the above for anything up to 1.5 metric tonnes they double for bigger aircraft. The missed approach fees started a few months ago. I think because aircraft from other local airfields were practicing approaches and before the wheels touched the ground putting on power and going around. This they would do a couple of times - usually flight training outfits and then they would fly merrily of back to their own airfield with a few low approaches and no touch and go fees. Aircraft from my airfield are equally guilty of the same practice and unilaterally my airfield has put this charge on theoretically to discourage the practice. that is the official line. The downside is that resident pilots may try to recover a landing to avoid the fee plus the extra 6 minutes going round the circuit instead of maybe doing the right thing and declaring a missed approach. To put it in perspective, I fly out of a Class D airport, KHPN - Westchester County Airport - in a large suburb of New York City. The airport has a tower, and has two intersecting runways - one about 6500' (~ 2000 meters), the other 4500' (~1500 meters). We have several airlines flying out of our field - Delta, United, USAir, American, Continental, JetBlue, and AirTran. Landing fees for transient single-engine pistons is $15. There are no fees for touch & goes or for missed approaches, at least not to the pistons. I don't know what the "big boys" pay, but I'm sure it's more. Besides the obvious safety issue, what's to stop a training flight from lying about his/her tail #? |
