Parts help.. Exhaust Augmentor inserts
Ok.. this may be more appropriate in homebuilt because its going on an
experimental, but I wanted to pick owners brains regarding a certified part I want to utilize. I got a good look at a friend's twin bonanza the other day, and really liked the exhaust augmentation that it uses to pull air from inside the cowl. The T-Bon had what looked like stainless with some sort of slotted mesh inside of it that helps break up the sound pulses. Well.. several other rotary engined fellows have fashioned their own crude exhaust augmentor tubes and have had workable results so far in flight. Enough that I located and obtained an augmentor tube off of ebay (no part number attached) and when it arrived it looked perfectly useable.. except that there was no slotted insert. Straight pipe would be "ok" but the insert would be better (from a temperature and noise standpoint). Anyone know of the proper name for this slotted insert so that I can try and find one.. Even better.. someone know of an old derelict aero-commander or twin bonanza (or similar steed) with weeds growing through it.. that the owner might part out an entire tube with insert? This might save me a 4 hour each way road trip to Air Salvage of Dallas. Dave |
Similar Threads | ||||
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
Navion Parts Availability | Margy Natalie | Owning | 12 | August 15th 03 03:47 AM |
Navion Parts Availability | Margy Natalie | Restoration | 10 | August 15th 03 03:47 AM |
