NK ClearNav Update
Old February 3rd 08, 06:23 AM posted to rec.aviation.soaring
Paul Remde
Default NK ClearNav Update
Hi,
I received my demo NK ClearNav a few days ago. It is awesome! You can see
the latest reviews he
http://www.cumulus-soaring.com/nk.htm
Let me know if you want to be a beta tester.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
Old February 3rd 08, 03:15 PM posted to rec.aviation.soaring
kirk.stant
On Feb 3, 12:23*am, "Paul Remde" wrote:
Hi,
I received my demo NK ClearNav a few days ago. *It is awesome! *You can see
the latest reviews hehttp://www.cumulus-soaring.com/nk.htm
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
Neat system - It's great to see a bright display finally available.
And no touch screen! Those are an abomination in a cockpit!
One feature I think would be really nice to have: An integrated
"TCAS"-like display of nearby transponder equipped traffic. Even if
just an audio warning along with a range and altitude warning display
on the map (from an MRX-type transponder detector, for example).
And for Europe, of course, integrated FLARM.
Kirk
66
Old February 3rd 08, 06:27 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Paul Remde wrote:
Hi,
That's a most interesting device. It does pretty much what I'd want from
a navigation tool.
There's one fairly important point that's not mentioned by your site or
NK's given that it contains a GPS: What data is available OUT of the
ClearNav during a flight?
I use an SDI C4, which needs the following NMEA sentences: GPRMB, GPRMC,
GPROO and GPWPL. It uses GPRMC to calculate wind speed and direction.
The other three, together with its wind calculation, are used to handle
final glide. I imagine that most other GPS-enabled varios will use the
same information: the LX 160 / 1600 certainly does. This class of vario
will loose a lot of its capability without a GPS data feed.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 3rd 08, 10:02 PM posted to rec.aviation.soaring
Paul Remde
Hi Martin,
That is an interesting point. At this time I don't think there are any
plans to provide GPS data out.
However, I recommend simply using the ClearNav for navigation and glide
computations and using the other unit as only a speed-to-fly variometer.
A similar situation happened to me years ago with my Cambridge L-NAV and
GPS-NAV and Pocket PC with Glide Navigator II. I found that I used GN II
for navigation and glide computations and used the L-NAV as a speed-to-fly
variometer only. It was pretty big and bulky for those functions. That is
why I later upgraded to a Cambridge 302. I think the same is true in this
situation. Until NK comes out with their own variometers I think the best
units to use with it are the Cambridge 302 and the LX1600. A Borgelt B500
would also work, but it would have extra features that would not be needed
such as an extra GPS and navigation display.
Good Soaring,
Paul Remde
"Martin Gregorie" wrote in message
Paul Remde wrote:
Hi,
see the latest reviews he
That's a most interesting device. It does pretty much what I'd want from a
navigation tool.
GPROO and GPWPL. It uses GPRMC to calculate wind speed and direction. The
other three, together with its wind calculation, are used to handle final
glide. I imagine that most other GPS-enabled varios will use the same
information: the LX 160 / 1600 certainly does. This class of vario will
org |
Old February 4th 08, 01:31 PM posted to rec.aviation.soaring
Is the top right of the display, where it shows "Distance" and "Alt.
diff" the final glide read-out?
If so I was confused by the "Alt. diff" label, thinking that it was
waypoint surface height difference and that I'd still need the C4's FG
calculations. However, if those are the FG display, then I agree that
the C4's FG functions can be ignored.
Regardless of feeding the vario, I still think that a GPS output would
be a useful option, at least in the interim. I'm certain I'm not the
only pilot using a logger without a built-in GPS receiver (EW series D).
org |
Oct 17 Update DHeitm8612 General Aviation 0 October 15th 04 01:31 AM
May 23 Update DHeitm8612 General Aviation 0 May 21st 04 01:47 AM
Oct 26 Update DHeitm8612 General Aviation 0 October 24th 03 04:07 AM
Oct 19 Update DHeitm8612 General Aviation 0 October 17th 03 07:44 AM
Sep 28 Update DHeitm8612 General Aviation 0 September 26th 03 04:20 AM
