ASW 19 instrument panel
Old October 31st 17, 04:19 PM posted to rec.aviation.soaring
Default ASW 19 instrument panel
On Monday, October 30, 2017 at 11:10:50 PM UTC-7, Charles Longley wrote:
I am an A&P/IA and am looking for someone who had it done to their glider.. Your advice isn’t reallly useful. I know who Williams is.
Ive done this to my Asw-19 glider, somewhat recently. Purchased a conversion kit from Schleicher, installed it and performed W&B balance according to paperwork supplied with the kit. The conversion is evasive and time consuming, but it rejuvenates the glider and in my opinion it is totally worth the effort. I’ve also installed a second airbrake spoiler conversion, with materials also purchased from Schleicher. If you need more details send me an email.
Old October 31st 17, 04:45 PM posted to rec.aviation.soaring
Mike Borrowdale[_2_]
glider=
.. Your advice isn=E2=80=99t reallly useful. I know who Williams is.
conver=
according
cons=
worth
the effort. I=E2=80=99ve also installed a second airbrake spoiler
conversio=
details
send me an email.
I did this mod to my 19 about 10 years ago. As mentioned, the fitting is
far from easy using the Schleicher-supplied kit. A professional I
talked to later said he'd taken 40 hours to fit the first he did.
But when, a few years later, I made an inadvertent inverted arrival (don't
ask!) it made all the difference between extracting me easily
and performing major surgery on the nose. Made it well worth the effort
involved and I would highly recommend it.
Mike
Old October 31st 17, 11:39 PM posted to rec.aviation.soaring
Hi Mike,
Can you email me some more info about the panel mod? Getting my long legs under the panel is fun, but maybe the mod will be worth it. I’m at swanson43537. At yahoo dot com.
Thanks,
John
Old November 1st 17, 07:44 AM posted to rec.aviation.soaring
Charles Longley
Thanks for the help guys! I am going to put an offer in on the glider.
Old November 1st 17, 07:47 AM posted to rec.aviation.soaring
krasw
Easy and cheap mod is to just laminate new panel with larger leg openings. Just draw original panel shape to piece of plywood, group instruments together by using cardboard templates (outer dimensions, of course) and draw new leg openings. Then saw along the line, paint and wax, and you have ready positive mold for glass layup. It is quite easy to make openings 2-5 cm larger if you have a mix of large and small dials. Makes a day and night difference for entry and exit.
P-39 Instrument-Panel - P-39 Instrument-Panel.jpg ... Miloch Aviation Photos 0 June 26th 16 01:47 AM
PIK-20D Instrument panel Solo Soaring 5 February 15th 09 06:50 PM
Instrument Panel ccwillwerth Home Built 7 February 9th 06 02:15 PM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
