Badge flight start/finish question
I am hoping for a shot or 2 next month to attempt a 1000k badge flight.
I realize that the turnpoint or turnpoints need to be an FAI 90 degree sector. What about start and finish, I plan to use the gliderport for my start and finish, does this also require the 90 degree sector or is a line required? If a line is required what is the max width of the line? Thanks for any info, Joe |
Hi Joe -
I prefer the line option. I believe it is 1000m max or 0.61 miles. Be careful when you put this into something like an Oudie. You enter 0.31 miles. That translates into 0.31 miles on each side of the line or 0.62 miles total. I hope this helps - Lou On Monday, September 29, 2014 8:26:51 PM UTC-5, joesimmers wrote: I am hoping for a shot or 2 next month to attempt a 1000k badge flight. I realize that the turnpoint or turnpoints need to be an FAI 90 degree sector. What about start and finish, I plan to use the gliderport for my start and finish, does this also require the 90 degree sector or is a line required? If a line is required what is the max width of the line? Thanks for any info, Joe |
On Monday, September 29, 2014 7:29:30 PM UTC-7, MNLou wrote:
Hi Joe - I prefer the line option. I believe it is 1000m max or 0.61 miles. 90 degr. out-bound and 90 degree in-bound? Or any old line across the A/P? Heinz |
On Monday, September 29, 2014 9:26:51 PM UTC-4, joesimmers wrote:
I am hoping for a shot or 2 next month to attempt a 1000k badge flight. I realize that the turnpoint or turnpoints need to be an FAI 90 degree sector. What about start and finish, I plan to use the gliderport for my start and finish, does this also require the 90 degree sector or is a line required? If a line is required what is the max width of the line? Thanks for any info, Joe Info is on the SSA website here http://www.ssa.org/BadgesAndRecords and your specific questions are answered in detail in the badge and record procedure guide here http://www.ssa.org/files/member/B&RGuide_2_2012.pdf Understanding the rules = fewer disappointments. best, Evan Ludeman / T8 |
Thanks for the link Evan I found it.
So for start and finish you have the option to use 90 degree sector, or a start line, the start or finish line is 1 Kilometer wide. |
On Tuesday, September 30, 2014 9:12:48 AM UTC-4, joesimmers wrote:
Thanks for the link Evan I found it. So for start and finish you have the option to use 90 degree sector, or a start line, the start or finish line is 1 Kilometer wide. Quick Editorial: We've seen so many angry/frustrated pilots over the years missing out on significant badges and records for simple errors. While we all understand that the Sporting Code isn't a light read, for the most part it's reasonably clear. It takes probably an hour to go through it and the key appendices with some level of rigor. It's an hour well spent if you are planning to spend 10 hours in the cockpit for a 1000K. As far as the specifics, the following paragraph has most of the required info. START TIME and ALTITUDE 1.3.1. The time and altitude (msl) at which the SOARING PERFORMANCE begins, both determined by the type of SOARING PERFORMANCE and the type of START POINT claimed: b. When a declared START POINT is claimed for a distance performance, START TIME and ALTITUDE may be taken at: (i) the exit from the START OZ SECTOR, (ii) the crossing of a START LINE, or (iii) the most favourable FIX recorded within the START OZ SECTOR. c. The SECTOR OZ radius for GOAL or CLOSED COURSE distance performances is 1000m. d. For speed performances, a declared START / FINISH POINT is required; START TIME and ALTITUDE must be taken at an exit from the START OZ SECTOR with a 1000 metre radius or on crossing a START LINE. So, you are either using a Start Line (1000M wide, centered on the declared Start Point) or a Start Sector, centered on the Start Point, 1000M in radius. P3 Formerly chairman of the SSA B&R Committee and long-suffering State Record Keeper. |
Thanks for the link Evan I found it. So for start and finish you have the option to use 90 degree sector, or a start line, the start or finish line is 1 Kilometer wide. Just a reminder that the new Sporting Code is effective as of October 1, 2014. Section 3 (Gliding, Edition 2014) and Annex C (Official Observer and Pilot Guide, valid from 1 October 2014) are both at http://www.fai.org/igc-documents . Changes are indicated with vertical lines on the right side of the text. |
On Tue, 30 Sep 2014 06:58:14 -0700 (PDT), Papa3
wrote: On Tuesday, September 30, 2014 9:12:48 AM UTC-4, joesimmers wrote: Thanks for the link Evan I found it. So for start and finish you have the option to use 90 degree sector, or a start line, the start or finish line is 1 Kilometer wide. Quick Editorial: We've seen so many angry/frustrated pilots over the years missing out on significant badges and records for simple errors. While we all understand that the Sporting Code isn't a light read, for the most part it's reasonably clear. It takes probably an hour to go through it and the key appendices with some level of rigor. It's an hour well spent if you are planning to spend 10 hours in the cockpit for a 1000K. As far as the specifics, the following paragraph has most of the required info. START TIME and ALTITUDE 1.3.1. The time and altitude (msl) at which the SOARING PERFORMANCE begins, both determined by the type of SOARING PERFORMANCE and the type of START POINT claimed: b. When a declared START POINT is claimed for a distance performance, START TIME and ALTITUDE may be taken at: (i) the exit from the START OZ SECTOR, (ii) the crossing of a START LINE, or (iii) the most favourable FIX recorded within the START OZ SECTOR. c. The SECTOR OZ radius for GOAL or CLOSED COURSE distance performances is 1000m. d. For speed performances, a declared START / FINISH POINT is required; START TIME and ALTITUDE must be taken at an exit from the START OZ SECTOR with a 1000 metre radius or on crossing a START LINE. So, you are either using a Start Line (1000M wide, centered on the declared Start Point) or a Start Sector, centered on the Start Point, 1000M in radius. P3 Formerly chairman of the SSA B&R Committee and long-suffering State Record Keeper. Since a 1000km diploma is a distance flight not a goal flight you can also use your point of release or stopping of engine as the start point and your landing point, starting of the motor or a GPS point chosen post flight as the finish point. Basil |
If you use a line, make sure it is the right length (i.e. do not confuse
diameter with radius). The thing with the regulations is that you need not declare which one of the observation zone types you use, just the location. As long as you actually use a valid one, the performance will count. But to do this, you will probably have to set your PDA to the OZ of your preference. There are a number of other gotchas in the regulation, however, especially regarding the declaration (glider identification and so forth), official observer etc so I suggest you spend some time with the regs to avoid grief after you have made a significant effort in flying the 1000k. Alexander |
Similar Threads | ||||
See You 3.95 and U.S. Start/Finish rules | [email protected] | Soaring | 2 | March 27th 12 04:25 PM |
Seniors USA 2009 Start and Finish notes..... # 711 reporting | [email protected] | Soaring | 65 | March 21st 09 04:47 PM |
Bronze Badge question | [email protected] | Soaring | 32 | January 11th 06 09:19 PM |
Rules for 1000k with start/finish at midpoint. | Andrew Warbrick | Soaring | 2 | August 10th 04 05:04 AM |
