#51
O2 Concentrator instead of O2 tank
Tony writes:
Would you care to explain how the Apollo experience, with very fit men doing well on 4.8 psi PP O2 is in any way related to my assertion that you, or the general population, would have difficulty surviving in a pure oxygen atmosphere of 3 psia? Fitness has no effect on susceptibility to altitude sickness and hypoxia. Adaptations are slow to occur and readily lost and rarely practical, even for astronauts. However, a pure oxygen atmosphere at 4.8 psi apparently works just fine, for anyone in normal health. The Apollo spacecraft were regulated to between 4.8 and 5.0 psi, roughly, as I recall. Spacesuits were set to even lower pressures, around 3.8 psi. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#52
On Dec 3, 6:02 pm, Mxsmanic wrote: Tony writes: Would you care to explain how the Apollo experience, with very fit men doing well on 4.8 psi PP O2 is in any way related to my assertion that you, or the general population, would have difficulty surviving in a pure oxygen atmosphere of 3 psia? Fitness has no effect on susceptibility to altitude sickness and hypoxia. Adaptations are slow to occur and readily lost and rarely practical, even for astronauts. However, a pure oxygen atmosphere at 4.8 psi apparently works just fine, for anyone in normal health. Fitness has no effect?? For someone who writes well enough to sometimes sound credible, you ruin it all by making statements like that. Now, almost 5 psia of O2 is a long way from 3 psia -- which was my statement. Fitness, with good O2 exchange, means nearly EVERYHTHING with respect to operating in low oxygen environments. I fully accept that someone who isn't rated can make meaningful contributions to this group, but don't continue to make statements that make others question your credibility, it makes others question your valid statements. Oh well, I'm outta here. The Apollo spacecraft were regulated to between 4.8 and 5.0 psi, roughly, as I recall. Spacesuits were set to even lower pressures, around 3.8 psi. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#53
"Chris W" wrote in message
news Why are we having this argument? Because this is Usenet. We (and I include myself) have a pathological need to point out the errors in even the most obviously ignorant post. That said, I use the term "ignorant" in only the purest sense of the word, and it's possible that Bill Denton may actually learn something. There's no need for his ignorance to be perpetual, nor is it clear to me that we are really so much arguing about this as we are working through one person's misunderstandings. Is it not true that people use concentrators at altitude in unpressurized planes and they don't pass out? If that is the case, and it is my understanding that it is, then they must work. So what is the argument about? Knowing something works is not necessarily the same as understanding why or how it works. To draw a parallel, consider the question glide angle (and by extension, distance). It's somewhat non-intuitive to understand that glide angle is constant as weight varies, and that the only thing that weight changes is the speed at which the best glide angle occurs. You might witness an "argument" as a person struggles through understanding the why and how of that. I should know...I've been there, on the ignorant side of that "argument". Of course, just when I thought I had it all figured out, someone came along and explained to me that it turns out that glide angle *is* affected to a small degree by weight. Just not to the degree one might naively assume. Anyway, given that the question involves pressures, volumes, open systems, closed systems, and physiology, it's not too surprising that at least one person has formed the wrong intuitive idea of the situation. Hopefully, we can just "argue" the truth into him. Pete |
#54
tom wrote: Does anyone use an oxygen concentrator to supply pilot and passengers in a light plane flying over 14000 feet? A quick google did not turn up anything but home units and a recent ruling that they can be used on commercial airlines, but I did not find anything about their use on private planes. They don't require more than about 100 watts, so an aircraft electrical system could keep them going as long as the engine was running. Internal batteries would keep it alive in an emergency. Seems like a nice solution to elimination of messing with refilling tanks. tom |
#55
Hi Tom,
I'm a pilot and I sell concentrators. I'm not too sure they will work well at 14000 feet. The new (expensive) little ones are pretty marginal at best. tom wrote: Does anyone use an oxygen concentrator to supply pilot and passengers in a light plane flying over 14000 feet? A quick google did not turn up anything but home units and a recent ruling that they can be used on commercial airlines, but I did not find anything about their use on private planes. They don't require more than about 100 watts, so an aircraft electrical system could keep them going as long as the engine was running. Internal batteries would keep it alive in an emergency. Seems like a nice solution to elimination of messing with refilling tanks. tom |
#56
"Vaughn Simon" wrote She has a lung problem and we are lucky to live at sea level. I'm glad you are able to deal with it satisfactorily. -- Jim in NC |
#57
Tony writes:
Fitness has no effect?? Yes. For someone who writes well enough to sometimes sound credible, you ruin it all by making statements like that. I'm sorry if it sounds incredible. I did the research, and that was the result. Fitness, with good O2 exchange, means nearly EVERYHTHING with respect to operating in low oxygen environments. No, it does not. You can be in good health, or great health, but it doesn't make any difference. Even Olympic champions will yield to altitude sickness just as often as normal people, and their vulnerability is just as unpredictable. Someone who is truly in poor health with respiratory, cardiac, or some other problems may be more sensitive to hypoxia at altitude, but being in robust health and physically fit doesn't help. In fact, many of these problems don't hurt, either, except insofar as they make the effects of hypoxia more dangerous. I fully accept that someone who isn't rated can make meaningful contributions to this group, but don't continue to make statements that make others question your credibility, it makes others question your valid statements. Others can do the same research I do, and they can reach the same conclusions. Or they can spend their time on personal attacks. The former is a learning experience; the latter is a waste of time, especially when I'm the target. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#58
GomezAddams wrote:
Hi Tom, I'm a pilot and I sell concentrators. I'm not too sure they will work well at 14000 feet. The new (expensive) little ones are pretty marginal at best. There have been tests of portable units and the major issue with them going up in altitude is not that they don't work, but they get a lot because the compressor works harder. |
#59
them going up in altitude is not that they don't work, but they get a lot because the compressor works harder. That is really an interesting point. Prior to this thread--I had never given any thought to the possibility of anyone using a portable concentrator in the cabin of an aircraft, as my interest had been to eliminate the use of refillable bottles for normal use. I had simply presumed that the compressor(s) would be driven directly by the engine(s) and that any necessary intercooling would be provided prior to the concentrator unit; or alternatively that a purpose build self contained unit would be installed. Therefore, this thread has been something of a revelation. Peter |
#60
On 1 Dec 2006 22:28:10 -0800, "tom" wrote:
Does anyone use an oxygen concentrator to supply pilot and passengers in a light plane flying over 14000 feet? A quick google did not turn up anything but home units and a recent ruling that they can be used on commercial airlines, but I did not find anything about their use on private planes. They don't require more than about 100 watts, so an aircraft electrical system could keep them going as long as the engine was running. Internal batteries would keep it alive in an emergency. Changing subjects slightly - what kind of maintenance is required on an oxygen concentrator? Does the zeolite need to be replaced every so often? I scanned the webpages of a few manufacturers, and it appears to be a relatively maintenance free product. Anyway, it seems an interesting concept to use an O2 concentrator vs bottle in the plane. |
Similar Threads | ||||
wing tank fuel guage | D H | Home Built | 7 | October 18th 06 03:32 AM |
My Ercoupe is flyin' again... (long) | Greg B | Owning | 13 | August 30th 06 12:01 AM |
Night bombers interception in Western Europe in 1944 | Bernardz | Military Aviation | 205 | July 22nd 04 05:31 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
