Extended full-power in small pistons
The POH for a number of small piston aircraft warn that high power and prop
settings should not be used for extended periods. What counts as an extended period, and what happens to the engine if these recommended (or mandatory) limits are exceeded? |
On Jan 1, 2:41*pm, Mxsmanic wrote:
The POH for a number of small piston aircraft warn that high power and prop settings should not be used for extended periods. *What counts as an extended period, and what happens to the engine if these recommended (or mandatory) limits are exceeded? On a sim, nothing. |
"Mxsmanic" wrote in message
... The POH for a number of small piston aircraft warn that high power and prop settings should not be used for extended periods. What counts as an extended period, and what happens to the engine if these recommended (or mandatory) limits are exceeded? Anything over five minutes will cause the engine to explode. |
Anything over five minutes will cause the engine to explode. Or, in some cases, like in Bonanzas, Barons, and R182's, the prop can suddenly depart the aircraft. It is a well established problem from running at max power for extended periods of time. The actual time it takes for this to occur depends on a number of conditions, such as ambient temperature, CHT, age and hours on the engine and oil, etc. |
"Clark" wrote in message ... But that's ok because the ejection seat fires automatically... My back hurts! Peter :-( |
On Jan 1, 4:41*pm, Mxsmanic wrote:
The POH for a number of small piston aircraft warn that high power and prop settings should not be used for extended periods. *What counts as an extended period, and what happens to the engine if these recommended (or mandatory) limits are exceeded? I got a good chuckle out of all the other answers. You guys are so bad. g Here's my crack at answering this question. To operate the engine above and beyond it's design will result in premature engine wear and tear. Also at or above the design parameters, the engine is not getting adequate lubrication and/or cooling, again resulting in premature wear and tear or possibly even cause engine seizure. This wear and tear will also shorten the Time Between Overhaul TBO. Monk |
Mxsmanic wrote:
The POH for a number of small piston aircraft warn that high power and prop settings should not be used for extended periods. What counts as an extended period, Depends; Is PIC renter, owner, or employee? T |
Monk writes:
Here's my crack at answering this question. To operate the engine above and beyond it's design will result in premature engine wear and tear. Also at or above the design parameters, the engine is not getting adequate lubrication and/or cooling, again resulting in premature wear and tear or possibly even cause engine seizure. This wear and tear will also shorten the Time Between Overhaul TBO. Okay, thanks. The last POH I looked at (Bonanza or Baron, not sure which) said that it was "not recommended," which sounded gentler than "forbidden," and implied that it just wasn't a good idea, but wouldn't necessarily cause a catastrophic failure of the engine. The POH also seems to imply that operating with full throttle at less than maximum RPM is okay, and so is operating with maximum RPM but less than full throttle. I think it also says something about not being at maximum EGT for too long. I was mainly worried that exceeding some mysterious limit would cause an engine failure in flight. |
Anthony, your response again demonstrates your fundamental ignorance about
flying. Since when do throttle and RPM control EGT? What does EGT have to do with engine performance and longevity? Since when do full throttle and RPM produce maximum EGT? It's a good thing you actually don't fly. The limitations in the POH obviously would not make sense to you, since you don't have a grasp of the fundamentals of engine operation. |
On Jan 2, 10:41*am, Mxsmanic wrote:
The POH for a number of small piston aircraft warn that high power and prop settings should not be used for extended periods. *What counts as an extended period, and what happens to the engine if these recommended (or mandatory) limits are exceeded? TBF goes down. Cheers |
Similar Threads | ||||
Full Stalls Power Off | w3n-a | Soaring | 5 | December 4th 08 10:29 PM |
Full Stalls Power On | w3n-a | Piloting | 0 | December 4th 08 02:30 PM |
Can hydraulic lifters cause inadequate full power? | [email protected] | Owning | 13 | October 23rd 08 07:40 PM |
Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 07:52 PM |
4--O-470 pistons,used | jerry Wass | Aviation Marketplace | 0 | August 17th 04 05:07 PM |
