dynamic soaring
Ralph Jones wrote:
... The most interesting conclusion is that if the curl is the only source of energy (in other words, there is no vertical velocity component to complicate the issue), the optimum strategy is amazingly simple. Most of the variables fall right out of the calculation, and the result is: Circle in a 55-degree bank. Go to the left if the curl direction is upward, right if it's downward. ... But in the case of wind shear discussed here as mentionned on the site quoted in the first post of this discussion, the curl direction is horizontal, perpendicular to the direction of the wind. |
dynamic soaring
On Fri, 19 Jan 2007 01:19:21 +0100, Robert Ehrlich
wrote: Ralph Jones wrote: ... The most interesting conclusion is that if the curl is the only source of energy (in other words, there is no vertical velocity component to complicate the issue), the optimum strategy is amazingly simple. Most of the variables fall right out of the calculation, and the result is: Circle in a 55-degree bank. Go to the left if the curl direction is upward, right if it's downward. ... But in the case of wind shear discussed here as mentionned on the site quoted in the first post of this discussion, the curl direction is horizontal, perpendicular to the direction of the wind. I haven't seen any analysis of that, but I'm betting that with sufficient horizontal curl you could climb by making successive loops. But a porpoising technique might make a bit more sense...;-) rj |
dynamic soaring
The one with nerves of steel is the one holding the radar gun with a
several pound RC "missile" coming at them at 200+ ! wrote: It is absolutely fascinating. The RC guys have reached 300+mph doing this. I personally have clocked someone flying a 2M wingspan RC glider doing 209mph. It is amazing how fast the energy builds up and how quickly speed goes from 40 to 150+ It requires nerves of steel and amazing reflexes to dive to the ground at 200+ and pull out only a couple of feet above ground though! wrote: amazing is right. |
dynamic soaring
In the last year, the USAF Test Pilot School has been conducting
dynamic soaring test flights with a Blanik L23 at low level (sometimes down to 100' AGL) over the lake bed. Jim |
dynamic soaring
On 19 Jan 2007 05:18:50 -0800, "JS" wrote:
In the last year, the USAF Test Pilot School has been conducting dynamic soaring test flights with a Blanik L23 at low level (sometimes down to 100' AGL) over the lake bed. Jim Hmmm, sounds like there's some kind of stealth UAV in the works...;-) rj |
dynamic soaring
"Ian" wrote in message ps.com... flying_monkey wrote: ED: What's curl? Math Geek: Oh, that's just the divergence of the gradient. Get a better maths geek. Curl ain't div grad. Another maths geek. You know they're hardcore when they say 'maths' instead of 'math' I pretty much stand in awe of long division.... |
Similar Threads | ||||
US SSA-OLC League new for Summer 2006 Season! | Doug Haluza | Soaring | 20 | April 26th 06 03:54 PM |
2006 ChicagoLand Spring Soaring Seminar Feb 18 | ContestID67 | Soaring | 1 | February 6th 06 08:46 PM |
Introducing NJ's Newest Soaring Club! | Jim Buckridge | Piloting | 2 | February 22nd 05 04:07 PM |
Possible future legal problems with "SOARING" | Bob Thompson | Soaring | 3 | September 26th 04 11:48 AM |
