#21
Curious that no one has mentioned aspect ratio in the discussion. I guess I
should have included that in my original "lead-covered rock" post. Ed "Those who have long enjoyed such privileges as we enjoy forget in time that men have died to win them." Franklin D. Roosevelt, Address for Bill of Rights Day 15 Dec 1941 (Delete text after dot com for e-mail reply.) |
"Keith Willshaw" wrote in message ... "Jack G" wrote in message ... Only in a vacuum would both "glide" at the same speed and go the same distance - I think. Jack In this case you are probably right but there is some truth in the assertion. No, my idiot. |
(snip) I realize this has nothing much to do with this discussion of glide ratio but you've just dug up a memory/question. A couple instances back around Iraq #I when I was out running in the Palo Alto Baylands when I would pretty much stop and watch in awe as a U-2R2 would take off from Ames Moffett about three miles away. The aircraft would fly a perfect straight line in pretty much an up-westerly direction until I would lose the speck in a perfectly clear sky directly overhead. Yes, I did the 360 deg. twist to verify the directly overhead part. Always wondered where it may be heading. JK (recalling the great old sights and sounds living near Moffett) |
Jim wrote in message . ..
On 28 Jul 2003 20:43:34 GMT, (B2431) wrote: A U-2 constructed of lead would have the same glide ratio as one constructed of balsa wood. It would glide faster, but just as far. vince norris Say what? Dave Within limits, weight has no effect on glide ratio (or Lift/Drag, L/D). As has been mentioned, the speed that the plane achieves that glide ratio goes up, by a function of the increase of the wing loading. My glider (an LS6-b, a racing 15 meter glider) carries over 300 lbs of water for strong days - which increases my wingloading from about 7.5 psf to over 10 psf. Wet, my average cross country speeds go up about 10 mph (this is when lift is strong and consistent). My sink rate goes up a bit, but in strong thermals (average acheived rate of climb of 400fpm or more) the glide speed increase is worth it. And of course, when the lift gets weak, we dump the water and creep in - at up to 40/1, in my case!. Using a conservative 30/1 L/D, you can go a LONG way from 17,999ft! There is also a small theoretical increase in performance due to the increases Reynolds number at the higher speed, but this is perhaps .5 to 1 L/D point. Basic aerodynamics, guys! Kirk Phantoms Phorever, but real planes don't need no stinkin engines! |
Thinking of the question from a different angle - the wing needs a range
of speeds to give good performance (lift versus drag) and the weight dictates how much lift, and therefore speed, will be needed. An extremely light load will need less speed to create enough lift, but below a certain speed, the wing's drag vs lift will get in the way, and though it is going very slowly, both forward and down, the glide ratio may not be all that good. As weight increases, the speed necessary increases as well, and there is a best combination of speed vs lift vs drag for best glide ratio. Excessive weight will demand yet more speed, but drag increases as well, so the glide ratio suffers. Our theoretical balsa versus lead U2 might, ironically, have not dissimilar glide ratios, while the real thing at an intermediate weight, have the better ratio. |
On Tue, 29 Jul 2003 01:19:30 GMT, "Jack G"
wrote: I am trying to make sure I understand this concept so please humor me. Clarification: Glide Ratio is the distance traveled forward for each equivalent distance traveled vertically. Is Glide Angle the same thing but measured in degrees? If two aerodynamically identical gliders (but one being heavier) are launched in a straight line from the same vertical distance with the same horizontal force, they will both arrive at the same horizontal distance from the launch point, but the heavier one will take less time to get there. This will be true only if the lift generated can sustain a glide ratio of 0:1 This is where I get confused: Does the lift required to sustain a glide ratio 0:1 increase as the weight of the glider increases? Your help IS appreciated! Jack Glide angle, as I use the term, is the angle of the glide relative to the horizon. Yes, the lift force required to sustain an aircraft in un-accelerated flight is proportional to the gross weight of the aircraft. For instance, if 300 lbs of water ballast is added to a glider then the lift required to maintain a given, un-accelerated glide ratio, or glide angle, is increased as required to offset the additional 300 lbs. Since the glider's wing size and shape are not altered simply by the additional water ballast, and the wing now must produce additional lift to maintain the additional 300 lbs, the glider must fly faster in order to produce the additional lift force required. In a way perhaps, this is kind of good news and bad news depending on what the pilot wants. With the additional weight, the glider MUST fly faster at a given glide ratio, on the other hand, the glider thus CAN fly faster at a given glide ratio. Remember, the glide ratio itself is not altered (significantly) by the added weight. A glider pilot will want a glider that CAN / MUST fly faster at a given glide ratio if he/she wants to cover distance quickly, such as in a competition. However, the additional weight of the water ballast will require stronger thermals for the glider to gain or sustain altitude. If the thermals are weaker than the pilot had hoped for he/she can dump the additional water ballast to lighten the wing loading so as to make use of the weaker thermals -- but thus giving up the ability to fly faster. All this can confuse me too, and I often have to think it through again. One other note; with the added weight of the water ballast the glider CAN / MUST fly faster at a given glide ratio, which is good for covering distance quickly but the faster speed will put the glider on the ground faster if no thermals or other lift sources are found. Have I managed to make any sense? |
#28
Ron Parsons wrote:
Back in the last century when as students we used to have to do simulated flameout approaches to fields down near the Rio Grande with Cessna T-37's, it was quickly discovered that if you dived at a field that you were too close to, you would end up overshooting but if you pulled the nose up almost to a stall, you could mush down at a great angle. But that doesn't make sense Ron...you certainly would end up at the field with too much airspeed but why would you 'overshoot' the field?...hell you could 'pointer straight down' and you certainly wouldn't 'overshoot the field' (although you'd be going like a scalded cat - and may need to 'overshoot' for that reason) -- -Gord. |
#29
"Gord Beaman" ) wrote: Ron Parsons wrote: Back in the last century when as students we used to have to do simulated flameout approaches to fields down near the Rio Grande with Cessna T-37's, it was quickly discovered that if you dived at a field that you were too close to, you would end up overshooting but if you pulled the nose up almost to a stall, you could mush down at a great angle. But that doesn't make sense Ron...you certainly would end up at the field with too much airspeed but why would you 'overshoot' the field?...hell you could 'pointer straight down' and you certainly wouldn't 'overshoot the field' (although you'd be going like a scalded cat - and may need to 'overshoot' for that reason) Never been to the Rio Grande Valley I presume. All those nice flat fields have palm trees as a fence row. Granted you could make a vertical hole, but the point is to get over the near palms, get on the ground and stop before you arrive at the far palms. This was in the days when Primary was conducted by civilian instructors, most of whom expected you to brush tall grass with your wheels on such approaches and then go around. My instructor at the time was a bit more than a civilian. He taught us in the T-34 and T-37 and was still finishing up a few stragglers in the T-28. He was also in the Texas ANG where he was an instructor in the T-33, flew the F-86D and was qualifying in the F-102. He used to say, "Just don't ask me any numbers. "The only time he ever touched the stick with me was on the last day when he took the bird for a few minutes on the way home. One of the smoothest I've ever ridden with. -- Ron |
