Side-mounted canopy -- Prevent blowing shut?
Old September 5th 08, 08:37 PM posted to rec.aviation.soaring
V1
Default Side-mounted canopy -- Prevent blowing shut?
I have a side-mounted canopy (Ventus 2). I'm concerned that a gust of
wind could blow it shut when it's in the open position, breaking or
damaging the canopy.
I could close it every time I walk away for a minute or two, but
sooner or later I tend to forget and leave it open. I've thought about
several ways to hold it open without undue stress on the hinges or
canopy, but I have to assume someone else has probably solved this
problem and proved through actual use a simple method what works.
I'd like hear from anyone who has come up with a good solution.
Thanks,
- Frank Allen
Old September 5th 08, 08:59 PM posted to rec.aviation.soaring
toad
Thanks,
- Frank Allen
You already know the good solution, but have dismissed it as too much
work.
Close the canopy whenever you are not actually working on something in
the cockpit. Make it a physical habit, no memory required.
Todd
3S
Old September 5th 08, 09:08 PM posted to rec.aviation.soaring
Brian Bange[_2_]
I stuff a soft cushion under the retaining cable, half in and half out of
the canopy behind the rear hinge, and then only for a minute or two. So
far that has worked fine for me.
Brian
Thanks,
- Frank Allen
Old September 5th 08, 09:49 PM posted to rec.aviation.soaring
Paul Remde
Hi Frank,
If you are leaving it open in an attempt to keep the cockpit temperature
down, then you may want to consider getting a Canopy Cap. They have been
extremely popular.
http://www.cumulus-soaring.com/canopycap.htm
Good Soaring,
Paul Remde
"V1" wrote in message
Thanks,
- Frank Allen
Old September 6th 08, 01:04 AM posted to rec.aviation.soaring
Richard[_1_]
Thanks,
- Frank Allen
Frank,
More serious than leaving the canopy open is closing and not locking
it and leaving the vent window open. It will pressurize with a large
gust, open and rip one or more of the hinges off.
You can guess how I know this,
Richard
www.craggyaero.com
Old September 6th 08, 03:08 AM posted to rec.aviation.soaring
Tony Clark
On 5th September 2008, V1 wrote:-
"I could close it every time I walk away for a minute or two, but
it open".
"I'd like hear from anyone who has come up with a
good solution".
Thanks,
Frank Allen
Sure did find a good solution with the "sooner or later forgetting"
problem Frank! It's called 'being a club member'! If I am flying a club
glider and walk away from the cockpit without closing the canopy I get my
"arse kicked all round the field" by a club instructor!
This technique does wonders for "the memory problem" and ensures that
"the closing while unattended habit" is carried over for when I'm
flying a 'private' glider!
Regards
Tony (aka pilot extraordinaire)
Tony Clark
it open".
good solution".
Thanks,
Frank Allen
Regards
Old September 6th 08, 07:42 AM posted to rec.aviation.soaring
bikensoar
On Sep 5, 1:49*pm, "Paul Remde" wrote:
Hi Frank,
down, then you may want to consider getting a Canopy Cap. *They have been
extremely popular.http://www.cumulus-soaring.com/canopycap.htm
Good Soaring,
Paul Remde
Thanks,
- Frank Allen- Hide quoted text -
- Show quoted text -
Unfortuately the canopy cap is not yet available for side opening
canopies.
Old September 6th 08, 08:47 AM posted to rec.aviation.soaring
Hi Frank,
Good Soaring,
Paul Remde
Thanks,
canopies.- Hide quoted text -
The Canopy Cap for side mounted canopies has been available for about
a year now.
There are patterns for Schempp-Hirth A and B fuselages including
Discus and Discus 2, Ventus and Ventus 2,
Nimbus 2 and 3. Check with your favorite soaring supplier.
Old September 10th 08, 02:07 AM posted to rec.aviation.soaring
V1
Thanks to everyone who provided suggestions. I'm seeing that it's
even more critical to close AND lock than I had considered - a great
tip from Richard (the voice of expensive experience).
- Frank
it and leaving the vent window open. *It will pressurize with a large
gust, * open and rip one or more of the hinges off.
Richardwww.craggyaero.com
Upper Surface Blowing (USB) Charles Gray Military Aviation 1 August 17th 08 10:21 PM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Fueling from Plastic Containers and Blowing yourself up? Juaquin Murrieta Home Built 23 April 11th 05 04:27 PM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
