Igc file help. Computer science
Old November 30th 18, 11:32 AM posted to rec.aviation.soaring
Default Igc file help. Computer science
Hi Martin,
I just started reading here on RAS the last couple of days and this seems to be one of the more active fora on gliding I found so far.
Interesting to read you have this java class to interprete log files. I am sure many enthusiastic pilots with some programming skills started their own projects because non of the software they tried covered all their needs.
I for example wanted to do flight preparation in the SeeYou desktop app and then be able to use those tasks in XCSoar and do task declaration in my FLARM logger using the config file via the SD card interface. Therefore I wrote a powershell script to transform the SeeYou waypoints file into seperate FLARM config files, one for each task I prepared.
Are you aware of any central location where glider pilots share their projects, so no one has ro reïnvent the water again? :-)
Pascal
Old November 30th 18, 11:53 AM posted to rec.aviation.soaring
On Friday, November 30, 2018 at 1:32:16 PM UTC+2, pascal cuylaerts wrote:
Hi Martin,
Interesting to read you have this java class to interprete log files. I am sure many enthusiastic pilots with some programming skills started their own projects because non of the software they tried covered all their needs..
Pascal
Github.
Old November 30th 18, 03:05 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
I've put some projects on SourceForge.
The ICG package hasn't been published so for. I originally wrote it in
order to have a log analysis and display program that would run under
Linux, but then discovered GPLIGC and a utility for converting IGC logs
into KML files for display on Google Earth. Both work well enough for my
purposes but neither can display the task and turnpoint sectors or
barrels.
The package I DO use a lot, though is one I wrote to deal with turnpoints
and landout fields. Its based on my own proprietary file format that's
designed to be able to maintain with a text editor and is a superset of
Winpilot (DAT), CUP and EW turnpoint files: IOW it can store the data
that any of these contain plus extra detail about landout-suitable
airfields. The package can read and write its own proprietary format (of
course) as well as importing data from DAT, CUP and EW and outputting it
in any of them as well. Extending it to handle other formats would be
quite easy. I currently maintain a database of UK landout fields with the
data held in the proprietary OpenField format. This is published in both
DAT and CUP formats, with each accompanied by a Waypoint Notes file
suitable for input to XCSoar, LK8000 and any other moving map system that
can use it.
We're currently in the middle of the Great 25KHz to 8.33KHz conversion,
so I quickly whipped up another program that lists all airfield
frequencies in the landouts database in alphabetic order for easy
comparison with the CAA's converted airfields supplement. This has vastly
simplified updating the landouts database.
You can see the output from this program on my website (select the
'Landouts database and CGC Field Book'):
https://www.gregorie.org/gliding/pna/
I have a hazy plan to publish both packages next year, but they're more
likely to be added to my other website than to SourceForge, simply
because their main audience will be quite small. They will probably end
up he
http://www.libelle-systems.com/free/
Martin | martin at
Gregorie | gregorie dot org
Old December 14th 18, 05:15 AM posted to rec.aviation.soaring
Thomas Van de Velde
On Wednesday, October 31, 2018 at 10:59:48 AM UTC-7, wrote:
Hey guys im taking a computer science class on data structures and algorithms. I wanna do something glider related for my final project. I was thinking about trying to see if there is a pattern between average vario for a task and Xc speed. However, I have no clue how how to obtain such data from an igc file. Also,any suggestion On maybe doing something different for the project are welcome.
Thanks!
You may want to take a look at the following Python module: https://pypi.org/project/xcsoar/
I've used it to generate this:
https://goo.gl/miiVrq
Old December 14th 18, 03:33 PM posted to rec.aviation.soaring
Dan Marotta
Pretty impressive looking!Â* Does each red dot indicate the location of a
thermal or a forecast of the likelihood of a thermal being there (or
thereabouts)?Â* Given the subject of "igc file", I would assume it's post
flight but then I'd have to ask again:Â* exactly what is each red dot?
Thanks!
Dan, 5J
Old December 14th 18, 05:23 PM posted to rec.aviation.soaring
Thomas Van de Velde
Each dot is a historical thermal. You can click on a dot and get additional details about the pilot, time, altitude gain, thermal strength, etc for that particular thermal. The filters on the right interact with the map so if you zoom in on an area you'll see who flew there from where and when. You can also use those filters to slice and dice the data in many different ways; e.g. all flights from a particular airport at a particular time or month of the year, etc.
Thanks!
Dan, 5J
Science Qs Greg Farr Aviation Photos 4 April 3rd 08 08:16 AM
Science et vie 01 Patrick R7 Aviation Photos 17 October 19th 07 09:57 AM
Mixture--science vs witchcraft? Douglas Paterson Owning 34 August 28th 07 10:25 PM
TSA Rocket Science Judah Piloting 11 January 14th 04 11:59 PM
