Google Earth has a FLIGHT SIMULATOR hidden inside!
Old September 23rd 07, 03:53 AM posted to alt.satellite.gps.garmin,alt.comp.freeware,rec.aviation.piloting
KCat
Default Google Earth has a FLIGHT SIMULATOR hidden inside!
After reading this, I uploaded the latest Google Earth freeware on WinXP
and hit Control ALT A which brought up an SR22 and an F16 as choices.
The same sequence exited the Google Earth Flight Simulator.
I had trouble controlling the airplane until I found the following settings
by QWERTY keyboard trial and error.
I'd start at Moffett Field at runway R32 heading 320 degrees.
http://maps.google.com/?q=37.4064203...04305827617645
The comma & period controlled my left & right brake respectively.
- The C centered both the ailerons and the rudders.
- LeftBracket and RightBracket controlled the flaps.
- PageUp and PageDown controlled the throttle.
- UpArrow and DownArrow controlled the elevators.
Once airborne:
- G retracted the landing gear.
- Shift F retracted the flaps.
- LeftArrow and RightArrow controlled the ailerons.
- Shift LeftArrow and Shift RightArrow controlled the rudders.
When I got out of control,
- Spacebar paused the simulation so I could catch my breath.
- The h toggled the heads up display on and off.
- Alt LeftArrow and Alt RightArrow turned the pilot's head.
To land,
- G extended the landing gear.
- The f key extended the flaps.
- Simultaneously pressing comman & period braked to a halt.
best
kcat
Old September 23rd 07, 04:30 AM posted to alt.satellite.gps.garmin,alt.comp.freeware,rec.aviation.piloting
ABLE_1[_2_]
settings
At the start up screen, if you would have clicked on the HELP button you get
the complete list of controls on the keyboard. Could have saved yourself a
lot of time. :-)
Happy flying!!!
Old September 24th 07, 04:28 AM posted to alt.satellite.gps.garmin,alt.comp.freeware,rec.aviation.piloting
Robert M. Gary
I'd start at Moffett Field at runway R32 heading 320 degrees.http://maps.google.com/?q=37.4064203...04305827617645
Once airborne:
To land,
best
kcat
Hardly hidden, its right on the menu bar.
Mini-Flight Sim in Google Earth [email protected] Soaring 3 September 5th 07 11:26 PM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
C5 in-flight refueling by KC135, satellite photo via Google earth Morgans Aviation Photos 0 November 13th 06 12:48 AM
Google Earth - Glider David Pye Soaring 1 June 8th 06 04:39 PM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 12:07 PM
