Rapco 215/216 vacuum pumps?
Old April 24th 06, 05:51 PM posted to rec.aviation.owning
Default Rapco 215/216 vacuum pumps?
Anybody useing the new "improved?" Rapco 215/216 vacuum pumps?
Old April 24th 06, 08:47 PM posted to rec.aviation.owning
I replaced my 211 with an 215 during my last annual, because that 211
(still working) is at least 400 hr old if not much older, and I
couldn't find any reference to its age in my log book.
The 215 works fine. It suppose to have better cooling due to the
cooling fins. I can't speak to its life 'cause it has only been about
75 hours. I do however heard that good overhauled vacuum pumps on 4
cylinder engines can easily last about 1000 hrs, so a 400 hr
replacement interval can generally avoid failures. The life of vacuum
pumps on 6 cylinder engines is significantly shorter due to higher
rotation speed of the auxiliary shaft (?). If the vacuum pumps are
used to power de-icing boots they are even less reliable.
Old April 25th 06, 02:33 PM posted to rec.aviation.owning
M wrote:
The life of vacuum
That's a new one on me. Why does the accessory drive spin faster on a 6?
Dave
Old April 25th 06, 02:47 PM posted to rec.aviation.owning
Different gear ratio.... Lycoming 6 cylinders typicaly run a ratio of 1.3 :
1, so 700 hours is the most you should expect. Pretty good article on the
sacramento sky ranch site.
"Dave Butler" wrote in message
news:1145971786.778597@sj-nntpcache-5...
M wrote:
The life of vacuum
Dave
Old April 25th 06, 08:15 PM posted to rec.aviation.owning
See http://www.rapcoinc.com/pumplife.html
Old April 25th 06, 10:08 PM posted to rec.aviation.owning
Thanks, Jim. I didn't find the article on the SSR site, but I believe you. Do
you know what the rationale is for making the accessory shaft spin faster on 6s?
Dave
Old April 26th 06, 02:21 AM posted to rec.aviation.owning
Vacuum pump salesmen! nope, sorry I don't, but I'll add the question to
my list. I wonder if it could be that the fuel pump and the oil pump needs
to turn faster? do they? dunno, good research project.
news:1145999840.940424@sj-nntpcache-3...
1.3 :
Do
on 6s?
Dave
Old April 30th 06, 03:40 AM posted to rec.aviation.owning
Default Lyc 540 accesory drive ratios
Without an answer to "why", but interesting non the less, here are the drive
ratios for various accessories on the O-540 and IO-540 Lycomings per the
Lycoming OP Man.
Starter 16.556:1 CCW
Alternator 3.2:1 CW
Vacuum Pump 1.3:1 CC
Hyd Pump 1.385:1 CW
Tach 0.5:1 CW
Prop Gov 0.895:1 CW
Mag Drive 1.5:1 CW
Fuel Pump 1:1 CCW
These ratios may be different for dual magneto drives or wide cylinder
flange engines.
1.3 :
Do
on 6s?
Dave
Old May 1st 06, 03:58 PM posted to rec.aviation.owning
It's the Continental that spins the pump faster, according to
the Rapco guy in the seminar I took. I don't have the ratio handy, but
I might be able to scare it up.
Dan
Old May 1st 06, 06:29 PM posted to rec.aviation.owning
Dan
Vacuum pumps vk6ad Owning 1 March 10th 06 03:23 PM
Problems with Rapco dry vacuum pumps. abripl Home Built 28 September 25th 05 05:29 AM
Problems with Rapco dry vacuum pumps. abripl Owning 28 September 25th 05 05:29 AM
Wet Vacuum Pumps DBlumel Home Built 4 August 19th 04 08:27 AM
Dual vacuum pumps bad news Javier Henderson Owning 3 May 7th 04 09:06 PM
