CHEROKEE LANDS ON STINSON: ALL OK
Old May 20th 08, 11:17 PM posted to rec.aviation.piloting
Larry Dighera
Default CHEROKEE LANDS ON STINSON: ALL OK
On Tue, 20 May 2008 21:10:41 GMT, "JGalban via AviationKB.com"
u32749@uwe wrote in 847382c529f0d@uwe:
According to the accounts I have read, both pilots were communicating with
each other on the CTAF. Apparently, they had a misunderstanding about who
was going to use the runway first. The Cherokee pilot understood that the
Stinson would hold, and the Stinson pilot thought he'd been OK'ed to go.
If that is the case, the Stinson should have given way to the landing
aircraft in accordance with 91.113(g). CTAF position broadcasts are
supposed to be just that. I haven't seen any regulation nor Advisory
Circular that advocates air-to-air discussion to resolve right-of-way
issues. Had they each broadcast their positions, and followed
regulations, this mishap might not have happened, IMO.
Below is AC 90-42F (poorly formatted; use the link). I don't see
where it recommends that pilots discuss agreeing to disregard
regulations:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/c54e50252a7fa56d862569d8007804ba/$FILE/ac90-42F.pdf
Advisory Circular
-!!: TRAFFIC ADVISORY PRACTICES AT AIRPORTS WITHOUT OPERATING
mtti 5/21/90 AC No: 9042F
hiti8bd by: ATA- rlklw:
CONTROL TOWERS
1. PURPOSE. This advisory circular (AC) contains good operating
practices and procedures for use when approaching or departing
airports without an operating control tower and airports that have
contrd towers operating part time. This AC has been updated to include
changes in radio frequencies and phraseology.
2 . c ANCELlATlON. Advisory Circular 9042E, dated November 23,
1988, is cancelled.
3. REFERENCES The fdlwing AC’s also contain information applicable
to operations at such
uncontrolled airports.
a. AC Q&66, Recommended Standard Traffic Patterns for Aircraft
Operations at Airports
Without Operating Control Towers. .#f I.
b. AC 150/5340-27A, Air-to-Ground Radio Control of Airport
Lighting Systems.
4. DEFINITIONS.
a. COMMON TRAFFIC ADVlSORY FREQUENCY (CTAF) - A designated
frequency for the
purpose of carrying out airport advisory practices while operating
to or from an airport t t does
not have a contrd tower or an airport where the contrd tower is
not operational. The ?!!T AF is
normally a UNICOM, MULTICOM, flight service station (FSS)
frequency, or a tower frequency.
CTAF will be Mentified in appropriate aeronautical publications.
b. UNICOM - A nongovernment air/ground radio communication station
which may provide
airport information at public use airports.
c. MULTICOM - A mobile service, not open to public cotiespondence
use, used for essential
communications in the conduct of activities performed by or
directed from private aircraft.
d. MOVEMENT AREA - The runways, taxiways, and other areas of an
airport/heliport which
are utilized for taxiing/hover taxiing, air taxiing, takeoff and
landing of alrcraft, exclusbe of loading
ramps, and parking areas.
5. DISCUSSION.
a. In the Interest of promoting safety, the Federal Aviation
Administration, through its Airman’s
Information Manual, Airport Facility Directory, Advisory Circular,
and other publications provides
frequency information, good operating practices, and procedures
for pilots to use when operating
to and from an airport without an operating co&d tower.
b. There is no substitute for awareness while in the vicinity of
an airport. It is essential that
pilots remain alert and look for other traffic and exchange
traffic information when approaching or
FAA Form 7320-15 (4-82) Supersedes WA Fom l32B2
AC 9042F s/21/90
departing an airport without the services of an operating control
tower. This is of particular
importance since other aircraft may not have communication
capability or, in SOme cases, pilots
may not communicate their presence or intentions when operating
into or out of such &ports.
To achieve the greatest degree of safety, it is essential that all
radio-eau@Dd aircraft
tranSm@heCeive on a common freauencv identified for the DurDose of
airPort advisories.
c. The kev to communicatina at an airport without an ooeratina
control tower is selection of
the correct common freauencv. The CTAF for each airport without an
operating control tower is
published in appropriate aeronautical information publications.
The CTAF for a particular airport
can also be obtained by contacting any FSS. Use of the appropriate
CTAF, combined with visual
alertness and application of the following recommended good
operating practices, will enhance
safety of flight into and out of all such airports.
d. There are two ways for pilots to communicate their intentions
and obtain airport/traffic
information when operating at an airport that does not have an
operating tower: by communicating
with an FSS that is providing airport advisories on a CTAF or by
making a self-announced broadcast
on the CTAF.
6. RECOMMENDED TRAFFIC ADVISORY PRACTICES. All inbound traffic
should continuously
monitor and communicate, as appropriate, on the designated CTAF
from a point 10 miles from the
airport until clear of the movement area. Departing aircraft
should continuously
monitor/communicate on the appropriate frequency from startup,
during taxi, and until 10 miles
(from the airport unless the Federal Aviation Regulations or local
procedures require otherwise.
7. AIRPORT ADVISORY SERVICE MAS) PROVIDED BY AN FSS.
a. An FSS physically located on an airport may provide airport
advisory service (MS) tit &n
airport that does not have a contrd tower or where a tower is
operated on a part-time basis and the
tower is not in operation. The CTAF’s for FSS’s which provide this
service are published in
b. An FSS AAS provides pilots with wind direction and velocity,
favored or designated runway,
altimeter setting, known traffic, Notices to Airmen, airport taxi
routes, airport traffic pattern, and
instrument approach procedures information. Pilots may receive
some or all of these elements
depending on the current traffic situation. Some airport managers
have specified that under certain
wind or other conditions, designated runways are used. Therefore,
pilots should advise the FSS of
the runway they intend to use. It is important to note that not
all aircraft in the vicinity of an airport
may be in communication with the FSS.
c. In communicating with an FSS on CTAF, establish two-way
communications before
transmitting outbound/inbound intentions or information. Inbound
aircraft should initiate contact
approximately 10 miles from the airport. lnbounds should report
altitude, aircraft type, and location
relative to the airport; should indicate whether landing or
overflight; and should request airport
advisory. Departing aircraft should, as soon is practicable after
departure, contact the FSS and
state the aircraft type, full identification number, type of
flight planned; i.e., visual flight rules (VFR)
or instrument flight rules (IFR), the planned destination or
direction of flight, and the requested
services desired. Pilots should report before taxiing, before
entering the movement area, and before
taxiing onto the runway for departure. If communication with a
UNICOM is necessary, pilots should
do so before entering the movement area or on a separate
transceiver. It is essential that aircraft
continuously monitor the CTAF within the specified area.
Par 5
5/21/90 AC 90-42F
d. Examples of AAS phraseology:
(1) Inbound:
VERO BEACH RADIO, CENTURION SIX NINER DELTA DELTA ONE ZERO MILES
SOUTH, TWO THOUSAND, LANDING VERO BEACH. REQUEST AIRPORT ADVISORY.
(2) outbound:
VERO BEACH RADIO, CENTURION SIX NINER DELTA DELTA, READY TO TAXI,
VFR,
DEPARTING TO THE SOUTHWEST. REQUEST AIRPORT ADVISORY.
8. INFORMATION PROVIDED BY AERONAUTICAL ADVISORY STATIONS
(UNICOM).
UNICOM stations may provide pilots, upon request, with weather
information, wind direction, the
recommended runway, or other necessary information. If the UNICOM
frequency is designated
as the CTAF, it will be identified in appropriate aeronautical
publications. If wind and weather
information are not available, it may be obtainable from nearby
airports via Automatic Terminal
Information Sewice or Automated Weather Observing System
frequency.
9. SELF-ANNOUNCE POSKION AND/OR INTENTIONS.
a. General. ‘Self-announce” is a procedure whereby pilots
broadcast their position, intended
flight activity or ground operation on the designated CTAF. This
procedure is used primarily at
airports which do not have a control tower or an FSS on the
airport. The self-announce procedure
should also be used when a pilot is unabe to communicate with the
local FSS on the designated
CTAF. . - .‘1* ..
b. If an airport has a contrd tower which is either temporarily
closed or operated on a
part-time basis and there is no operating FSS on the airport,
pilots should use the published CTAF
to self-announce position and/or intentions.
c. Where there is no tower, FSS, or UNICOM station on the airport,
use MULTICOM frequency
122.9 for self-announce procedures. Such airports will be
d. Practice ADofoache& Pilots conducting practice instrument
approaches should be
particularly alert for other aircraft that may be departing in the
opposite direction. When conducting
any practice approach, regardless of its direction relative to
other airport operations, pilots should
make announcements on the CTAF as fdlows:
(1) when departing the final approach fix, inbound;
(2) when established on the final approach segment or immediately
upon being released by
ATC;
(3) upon completion or termination of the approach; and
(4) upon executing the missed approach procedure.
NOTE: Departing aircraft should always be alert for arrival
aircraft that are opposite direction.
10 . u NICOM COMMUNICATION PROCEDURES.
a. In communicating with a UNICOM station, the fdlowing practices
will help reduce frequency
congestion, facilitate a better understanding of pilot intentions,
help identify the IQcatlon of aircraft
Par 8
AC 90-42F 5/21/90
in. the traffic pattern, and enhance safety of flight:
(1) Select the correct CTAF frequency.
(2) State the identification of the UNICOM station you are calling
in each transmission.
(3) Speak slowly and distinctly.
(4) Notify the UNICOM station approximately 10 miles from the
airport, reporting altitude,
aircraft type, aircraft identification, location relative to the
airport, and whether landing or overflight.
Request wind information and runway in use.
(5) Report on downwind, base, and final approach.
(6) Report leaving the runway.
b. Examples of UNICOM Phraseologies:
(1) inbound:
FREDERICK UNICOM CESSNA EIGHT ZERO ONE TANGO FOXTROT 10 MILES
SOUTHEAST
DESCENDING THROUGH (ALTITUDE) LANDING FREDERICK, REQUEST WIND AND
RUNWAY
INFORMATION FREDERICK.
FREDERICK TRAFFIC CESSNA EIGHT ZERO ONE TANGO FOXTROT ENTERING
DOWNWIND/BASE/FINAL (AS APPROPRIATE) FOR l RUNWAY ONE NINE (FULL
STOP/
TOUCH-AND-GO) FREDERICK.
FREDERICK TRAFFIC CESSNA EIGHTZERO ONE TANGO FOXTROT CLEAR OF
RUNWAY ONE -
NINE FREDERICK. *
(2) Outbound:
FREDERICK UNICOM CESSNA EIGHT ZERO ONE TANGO FOXTROT (LOCATION ON
AlFiPORT)
TAXIING TO RUNWAY ONE NINE, REQUEST WIND AND iRAFflC INFORMATION
FREDERICK.
FREDERICK TRAFFIC CESSNA EIGHT ZERO ONE TANGO FOXTROT DEPARTING
RUNWAY ONE
NINE. ‘REMAINING IN THE PATTERN” or “DEPARTING THE PATTERN TO THE
(DIRECTION) (AS
APPROPRIATE)” FREDERICK.
11. EXAMPLES OF SELF-ANNOUNCE PHRASEOLOGIES. It should be noted
that aircraft operating
to or from another nearby airport may be making self-announce
broadcasts on the same UNICOM
or MULTICOM frequency. To help identify one airport from another,
the airport name shotdd be
spoken at the beginning and end of each self-announce
transmission.
(1) Inbound:
STRAWN TRAFFIC, APACHE TWO TWO FIVE ZULU, (POSITION), (ALTlTUDE),
(DESCENDING)
OR ENTERING DOWNWIND/BASE/FINAL (AS APPROPRIATE) RUNWAY ONE SEVEN
FULL STOP,
TOUCH-AND-GO, STRAWN.
* STRAWN TRAFFIC APACHE TWO IWO FIVE ZULU CLEAR OF RUNWAY ONE
SEVEN STRAWN. *
Par 10
5/2 l/90 AC 90-42F
(2) outbawrd:
$TRAWN TRAFFtC, QUEENAIRE SEVEN ONE FIVE FIVE BRAVO (LOCATION ON
AIRPORT)
TAXIING TO RUNWAY TWO SIX STRAWN.
STRAWN TRAFFIC, QUEENAIRE SEVEN ONE FCVE FIVE BRAVO DEPARTING
RUNWAY TWO SIX,
DEPARTING THE PATI’ERN TO THE (DIRECTION), CLlM!SING TO (ALTITUDE)
STRAWN.
(3) Practice Instrument Approach:
STRAWN TRAFFIC, CESSNA TWO ObIE FOUR THREE QUEBEC (NAME - FINAL
APCjR0ACl-l FIX)
IN~~JND MSCENDING THROUGH (ALTITUDE) PRACTICE (TYPE) APPROACH
RUNWAYTHREE
FIVE STRAWN.
STRAWN TRAFFIC, CESSNA TWO ONE FOUR THREE QUEBEC PRACTICE PPE)
APPROACH
COMPLETED OR TERMINATED RUNWAY THREE FIVE STRAWN.
12 . SUM MARY OF RECOMfvIENDED COMMUN1CATIONS PROCEDURES.
FACILITY AT
AIRPORT FREL)U%NCY BE
COMMUNICATION/BROADCAST
PROCEDURES
_ rf, ..
PRACTICE
giUTBQUND INBOUND JNSTR APCH
a. UNICOM
(no Tower
or FSS)
b. No Tower,
FSS, 01
UNICOM
d. FSS Ckwd
(No Tower)
e. Tower or,
FSS not in
Operation
Communicate with
UNICOM station on
putWhed CTAF frequency
(122.7, 122.8, 122.725,
122.975, or 123.0).
If unable to contact
UNICOM &&on, use mlfampfmsm
CTAF.
Self-announce on
MULTICOM freq. 122.9
Comm8 w&h FSS on
CTAF
sti-announced on CmF
&If-annomxd on CTAF
68fofe
taxiing and
befofe
-Hnsm
th8 l@uway
fof
dqmture
10 miles
out, and
entering
downwind,
bass, and
final, and
leaving th8
runway.
Departing
final *
approach fix
mm
lnboutld,
and .
apptoach
completed/
tefminated
Par 11
AC 90-42F 5/21/90
13. IFR AIRCRAFT. When operating in accordance with an IFR
clearance, if air traffic contrd (ATC)
approves a change to the advisory frequency, change to and monitor
the CTAF as soon as possible
and fotlow the recommended traffic advisory procedures.
14. GROUND VEHICLE OPERATION. Drivers of airport ground vehicles
equipped with radios
should monitor the CTAF frequency when operating on the airport
movement area and remain dear
of runways/taxiways being used by aircraft. Radio transmissions
from ground vehicles should be
confined to safety-related matters.
15. RADIO CONTROL OF AIRPORT LIGHTING SYSTEMS. Whenever possible,
the CTAF will be
used to control airport lighting systems at airports without
operating contrd towers. This eliminates
the need for pilots to change frequencies to turn the lights on
and allows a continuous listening
watch on a single frequency. The CTAF is published on the
instrument approach chart and in
other appropriate aeronautical information publications. For
further details concerning radio
controlled lights, see AC 150/5340-27.
16. DESIGNATED UNlCOM/MULTICOM FREQUENCIES. The following listing
depicts appropriate
UNICOM and MULTICOM frequency used as designated by the Federal
Communications
Commission (FCC).
Freauencv Use
122.700
122.725
122.750
-----v---N-BP Airports without an operating contrd tower
122.800
122.900
Airports without an operating control tower
Air-to-air communications & private airports (not -
open to the public)
(MULTICOM FREQUENCY) Activities of a
temporary, seasonal, or emergency nature.
(MULTICOM FREQUENCY) Forestry management
and fire suppression, fish and game management
and protection, and environmental monitoring and
protection.
122.950 ----HWII Airports with control tower or FSS on airport
122.975 -w-m- Airports without an operating contrd tower
123.000 ------m Airports without an operating control tower
123.050 -----w-u-- Airports without an operating control tower
123.075 uI--I-Iw----c--IIwIIY- Airports without an operating
contrd tower
NOTE 1: in some areas of the country, frequency interference may
be encountered from nearby
airports using the same UNICOM frequency.. Where there is a
problem, UNICOM operators are
encouraged to develop a “least interference” frequency assignment
plan for airports concerned
using the frequencies designated for airports without operating
contrd towers.
*UNICOM licensees are encouraaed to aDply for UNICOM 25 kHz spaced
channel frequencies.
Due to the extremelv limited number of freauencies with 50 kHz
channel-soacina. 25 kHz channel
spacina should be imPlemented UNICOM licensees may then request
FCC to assign frequencies
in accordance with the plan, which FCC will review and consider
for approval.*
NOTE 2: Wind direction and runway information may not be available
on UNICOM frequency
122.950.
Par 13
s/21/90 AC 9042F
17. USE OF UNICOM FOR ATC PURPOSES. UNICOM SERVICE MAY BE USED FOR
ATC
PURPOSES, only under the following circumstances:
a. Revision to proposed departure time.
b. Takeoff, arrival, or flight plan cancellation time.
c. ATC clearance, provided arrangements are made between the ATC
facility and the UNICOM
licensee to handle such messages.
18. MISCELLANEOUS. Operations at airports without operating
control towers require the highest
degree of vigilance on the part of pilots to see and avoid
aircraft while operating to or from such
airports. Pilots should stay alert at all times, anticipate the
unexpected, use the published CTAF
frequency, and follow recommended airport advisory practices.
Harold W. Becker
Acting Director, Air Traffic
Rules and Procedures Sewice
. _ .*, -.
Par 17 7
JL---
b
Here's the Part 91 regulation for reference:
http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.2.4.7
§ 91.113 Right-of-way rules: Except water operations.
top
(a) Inapplicability. This section does not apply to the operation
of an aircraft on water.
(b) General. When weather conditions permit, regardless of whether
an operation is conducted under instrument flight rules or visual
flight rules, vigilance shall be maintained by each person operating
an aircraft so as to see and avoid other aircraft. When a rule of this
section gives another aircraft the right-of-way, the pilot shall give
way to that aircraft and may not pass over, under, or ahead of it
unless well clear.
(c) In distress. An aircraft in distress has the right-of-way over
all other air traffic.
(d) Converging. When aircraft of the same category are converging
at approximately the same altitude (except head-on, or nearly so), the
aircraft to the other's right has the right-of-way. If the aircraft
are of different categories—
(1) A balloon has the right-of-way over any other category of
aircraft;
(2) A glider has the right-of-way over an airship, powered
parachute, weight-shift-control aircraft, airplane, or rotorcraft.
(3) An airship has the right-of-way over a powered parachute,
However, an aircraft towing or refueling other aircraft has the
right-of-way over all other engine-driven aircraft.
(e) Approaching head-on. When aircraft are approaching each other
head-on, or nearly so, each pilot of each aircraft shall alter course
to the right.
(f) Overtaking. Each aircraft that is being overtaken has the
right-of-way and each pilot of an overtaking aircraft shall alter
course to the right to pass well clear.
(g) Landing. Aircraft, while on final approach to land or while
landing, have the right-of-way over other aircraft in flight or
operating on the surface, except that they shall not take advantage of
this rule to force an aircraft off the runway surface which has
already landed and is attempting to make way for an aircraft on final
approach. When two or more aircraft are approaching an airport for the
purpose of landing, the aircraft at the lower altitude has the
right-of-way, but it shall not take advantage of this rule to cut in
front of another which is on final approach to land or to overtake
that aircraft.
[Doc. No. 18334, 54 FR 34294, Aug. 18, 1989, as amended by Amdt.
91-282, 69 FR 44880, July 27, 2004]
Old May 20th 08, 11:40 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
"JGalban via AviationKB.com" u32749@uwe wrote in message
news:847382c529f0d@uwe...
Didn't Stinson and Piper merge (less dramatically) back in the 60s?
No. Piper acquired the Stinson division from Convair in 1948. Piper
produced the Twin Stinson as the Apache and sold the 108 to Univair.
Old May 20th 08, 11:42 PM posted to rec.aviation.piloting
"Larry Dighera" wrote in message
Have you seen anything which prohibits such discussions? Have you seen
anything which prohibits one pilot from surrendering the right-of-way
granted by FAR 91.113 to another pilot?
Old May 20th 08, 11:43 PM posted to rec.aviation.piloting
"Denny" wrote in message
I can see a check ride in the future for the Cherokee pilot...
Why?
Old May 20th 08, 11:49 PM posted to rec.aviation.piloting
gatt[_3_]
14 CFR 91.113:
(g) Landing. Aircraft, while on final approach to land or while landing,
have the right-of-way over other aircraft in flight or operating on the
surface...
This sort of reminds me of "How do you keep four Oregonians busy all
day" joke. ("Throw in a four-way stop sign.")
It's like:
"You go" *point*
"No, you go."
"It's okay. You first. I insist."
"No, no, you go ahead." *wave wave*
"Okay...wait, you're moving. That guy's moving. Are you going? Go
ahead. Is he going?" *hestitate*
"JUST F'CKING GO!!!" ...and then they both go and get in a wreck. It's
even weirder with pedestrians.
It underscores the idea that if everybody just LEARNS THE RULES AND
FOLLOWS THEM, everything moves mechanically, everybody is happy, and
things get done faster.
-c
Old May 21st 08, 12:09 AM posted to rec.aviation.piloting
Larry Dighera
On Tue, 20 May 2008 17:42:38 -0500, "Steven P. McNicoll"
wrote in
Have you seen anything in the regulations or ACs that permits a VFR
pilot operating under Part 91 to do so contrary to FARs, other than in
an emergency situation under 91.3?:
http://ecfr.gpoaccess.gov/cgi/t/text... .1.3.10.1.4.2
§ 91.3 Responsibility and authority of the pilot in command.
(a) The pilot in command of an aircraft is directly responsible
for, and is the final authority as to, the operation of that
aircraft.
(b) In an in-flight emergency requiring immediate action, the
pilot in command may deviate from any rule of this part to the
extent required to meet that emergency.
(c) Each pilot in command who deviates from a rule under paragraph
(b) of this section shall, upon the request of the Administrator,
send a written report of that deviation to the Administrator.
(Approved by the Office of Management and Budget under control
number 2120–0005)
As the subject mishap was presumably not an emergency at the time the
communications occurred, I highly doubt 91.3 was applicable at that
time.
In any event, if the pilots hadn't attempted to agree to deviate from
91.113(g), it's unlikely this mishap would have occurred.
Old May 21st 08, 12:16 AM posted to rec.aviation.piloting
wrote in
aircraft.
number 2120-0005)
time.
Is there some part of my question that you did not understand?
Old May 21st 08, 12:50 AM posted to rec.aviation.piloting
B A R R Y
I've surrendered my ROW via a two way conversation. I hope I haven't
broken any regs. G
Old May 21st 08, 12:51 AM posted to rec.aviation.piloting
Edward A. Falk
Anybody have a pointer to a high-res version of a photo of this?
Good enough to print poster size?
-Ed Falk,
http://thespamdiaries.blogspot.com/
Old May 21st 08, 12:58 AM posted to rec.aviation.piloting
B A R R Y
On Tue, 20 May 2008 14:46:17 -0700 (PDT), Tina
This will do nothing to settle the low wing vs high wing argument,
will it?
What puzzles me is I'd have thought the Stinson had to be on the
runway well ahead of the Piper, and although the Piper had right of
way shouldn't the other airplane have been visible? The runway may
have had the same color intensity as the Stinson, but it was a
different hue.
A slow airplane accelerating for take off, and a faster one
decelerating for landing, it takes just an awful set of circumstances
where the two paths converge at the same time on the runway.
If the reports of a two way CTAF exchange are true, both should have
been exactly aware of the other, as in "in sight", before landing or
departing.
That's why both may get to do command performance rides.
I would NEVER accept the ROW to enter the runway from an aircraft I
didn't have in sight, and I wouldn't land after giving it away, if I
didn't see the pilot I gave it to. I've heard too many errorred
position reports, way too many.
stinson 108-3 cc0248037 Aviation Marketplace 0 February 13th 07 08:07 PM
stinson 108-3 cc0248037 Aviation Marketplace 1 November 7th 06 02:30 AM
stinson 108-3 cc0248037 Aviation Marketplace 1 November 4th 06 05:44 PM
FS Stinson 108-2 Robert Little Aviation Marketplace 0 April 11th 06 01:08 AM
stinson stc [email protected] Home Built 7 December 10th 05 10:12 PM
