DG-1000 Electric Landing Gear System Troubleshooting
Anyone have experience with this system and troubleshooting it?
I could use some help. Thanks, mark Markgrubb. At aol.com |
On Saturday, June 20, 2020 at 7:15:05 AM UTC-7, Chris Gill wrote:
At 03:46 20 June 2020, wrote: Anyone have experience with this system and troubleshooting it? I could use some help. Thanks, mark Markgrubb. At aol.com What are you having issues with? I operate a DG1001M with the electric landing gear, feel free to email me Chris Have you reviewed the glider's maintenance manual? Have you contacted DG for support? If the problem is electrical you will need the proper instrumentation, which includes a good digital voltmeter and clamp-on dc ammeter: https://www.amazon.com/Multimeter-Au...02&s=hi&sr=1-4 It looks like the controls for this system are integrated into the DEI, but may be a separate box. The control uses limit switches (or electronic position sensors) to indicate the gear position. Make sure these are operational. I have worked on a DG808 which would not start. The current switch for the starter was an electronic MOSFET contained in a control box. All interlocks were working, so I tested the starter by jumping the power connection (against DG's instructions). This reset whatever was internally preventing the MOSFET from operating, and it began working again. Eventually, the box failed and had to be replaced. Here are a couple of tech notes from DG that deal with the landing gear system: https://www.dg-flugzeugbau.de/wp-con.../2006-59-e.pdf https://www.dg-flugzeugbau.de/wp-con.../2006-59-e.pdf Here is a DG video that may help: https://www.youtube.com/watch?v=kw4uW8w_VCI Good luck! Tom |
Similar Threads | ||||
C-402B landing gear system | [email protected] | Piloting | 0 | July 2nd 17 06:33 PM |
Gear Up, pt 4 - f89d-241-1000.JPG (1/1) | Mitchell Holman | Aviation Photos | 0 | April 13th 07 01:51 PM |
Gear Up, pt 4 - f89d-199-1000.JPG (1/1) | Mitchell Holman | Aviation Photos | 0 | April 13th 07 01:51 PM |
Troubleshooting the Comanche fuel system | Thomas | Owning | 9 | March 28th 06 11:07 AM |
Bonanza "Landing Gear Safety System" | Roy Smith | Owning | 3 | January 16th 04 05:01 PM |
