#21
Pic of the Airgizmo installation
150flivver wrote: This has been an interesting discussion. I wonder why the Airgizmo website has this on the bottom of the page: All products on this site are intended for use on experimental aircraft. Installation in a production aircraft requires an FAA field approval. That's a copout and legal mumbo jumbo. The fact is if a company doesn't STC their product they lose any authority to tell you how to install it. |
That is the crucial difference. The FAA deserves blame in a lot of
areas but not this one. Tell your mechanic to RTFM. Actually, Newps, I know it's out of character for me to do so -- but I'm *complimenting* the FAA on this one. (Well, the Des Moines FSDO, anyway...) They looked at a gray area, and made a real-life, common sense ruling in favor of making the installation of an AirGizmo a logbook entry. Kudos to whomever made the call! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
There's nothing gray about it. The point some are trying to make is that it does not matter WHAT your opinion is as the plane owner or what the opinion is of the installing wrench. It does not matter what is contained in the ACs and other pubs if the mechanics don't all agree. The fact that some immediately call the FSDO shows they don't have a common understanding of what others find so crystal clear. Those who say this is clear may be technically correct. But, as a practical matter, that won't mean a hill of beans when someone who has a different view starts a beef about it. At some future time, after the plane is sold twice, or some inspector hungry for a violation performs a ramp check 5 states over, you could well be flagged on the install. A wrench who does not "get it" may well flag it on a pre-buy as an improper install. The wrench who signed it off cannot (and likely will not) stand behind you. Was the thing hard wired into the plane for power? Or did the shop simply tie wrap the power cable to the harness and snake it around the front of the panel to go into the cig. lighter? Mike |
#24
Jay Honeck wrote: They looked at a gray area, and made a real-life, common sense ruling in favor of making the installation of an AirGizmo a logbook entry. Kudos to whomever made the call! Yhe point I'm trying to make is it's not a gray area. It's not a decision the FSDO should ever have been asked to make. |
#25
Mike Spera wrote: At some future time, after the plane is sold twice, or some inspector hungry for a violation performs a ramp check 5 states over, you could well be flagged on the install. A wrench who does not "get it" may well flag it on a pre-buy as an improper install. The wrench who signed it off cannot (and likely will not) stand behind you. OK, take a ramp check as an example. Inspector comes up and doesn't like the Gizmo. Looking thru the window he has no idea what process happened to make that legal. He doesn't know if you just had a logbook signoff or got a field approval. There's nothing he's going to do on that ramp to stop you from flying today. If he wants further documentation on the device he can make a request that you produce your records. Whatever. It ain't going to happen today. And if he does make that request the fact of the matter is the mechanic signed it off, therefore it's legal. The FAA has to go thru quite a process to make you remove that Gizmo. The fact of the matter hundreds of these are being quite properly signed off with a logbook entry. Was the thing hard wired into the plane for power? Or did the shop simply tie wrap the power cable to the harness and snake it around the front of the panel to go into the cig. lighter? The power cord is irrelavant. I have an XM radio attached to the front of my panel. I had my mechanic install a cig lighter up under the panel so you couldn't see it. The XM is plugged into that. I would have just hard wired the XM cord but it needs less voltage, 5 or 6 volts I think, so you need the end of the original cord which is the voltage reducer. I do have my 295 hardwired, although it is not in the panel, merely on an arm attached to the back of my throw over yoke. |
#26
in favor of making the installation of an AirGizmo a logbook entry. Kudos to whomever made the call! Yhe point I'm trying to make is it's not a gray area. It's not a decision the FSDO should ever have been asked to make. I get it! But, despite this, they made the *right* decision. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#27
That's just what a friend told me with his 180. He installed the Airgizmo
(great name), but then pulled it out in favor of the Propellerhead mount. http://www.propellerheadpilot.com/Default.htm Of course, the Skywagon crowd is pretty advanced in hangar queening their airplanes. http://temp.corvetteforum.net/c5/kgr...r_stc-c180.pdf Karl "Curator" N185KG "Jay Honeck" wrote in message oups.com... The Airgizmo mount is difficult to work with as well. It is way more convenient to have the 3/496 in your hands for most operations. I don't understand what you mean by this, Karl. Can you expand a bit? -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#28
(great name), but then pulled it out in favor of the Propellerhead mount. http://www.propellerheadpilot.com/Default.htm That's a slick-looking product -- I might have to move our Lowrance Airmap 2000c onto one of those things. I don't like the "remove it at the end of the day to save the suction cup" thing, though. That would get old. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#29
It does get old. But then I find that I've been using my 396 for XM radio at
night. I love the old mystery radio shows. Then I use the thing in "auto" mode........and drove Houston---Walla Walla without a hitch. It did drive me off and on a couple of off ramps though. Then I use it in my friends 46' Swan, and have a Bluechart chip from Olympia to Alaska that has 1500 marine charts on it. I can't believe it's become by main music/aviation/auto,marine data source. Great technology. Karl "Curator" N185KG "Jay Honeck" wrote in message ups.com... That's just what a friend told me with his 180. He installed the Airgizmo (great name), but then pulled it out in favor of the Propellerhead mount. http://www.propellerheadpilot.com/Default.htm That's a slick-looking product -- I might have to move our Lowrance Airmap 2000c onto one of those things. I don't like the "remove it at the end of the day to save the suction cup" thing, though. That would get old. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Similar Threads | ||||
The Good, the Bad, the Ugly: AirGizmo PIREP, PS Engineering CD/Intercom woes, XM "service" | Jay Honeck | Owning | 34 | December 15th 06 03:02 AM |
US ELT Installation | mhr | Soaring | 57 | December 31st 05 07:39 PM |
magneto installation help | Dick | Home Built | 5 | February 10th 05 03:02 PM |
Skycraft Landing Light Installation Pix | Jay Honeck | Owning | 5 | February 6th 05 02:05 PM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
