Lx9070 V80 and Butterfly electronic and pnuemantic compensation
Old April 30th 16, 01:08 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Default Lx9070 V80 and Butterfly electronic and pnuemantic compensation
I am flying an ASG 29 Es and was wondering if anyone flying an ASG 29-18 had fly these variometers configured to use electronic compensation and is so what is the percentage you use. I could do my own testing but right now I am not able to dedicate the time and I need to achieve the best result possible. If you could share your settings please send me the information?
Kind regards,
Old May 5th 16, 05:16 PM posted to rec.aviation.soaring
Jonathan St. Cloud
No one has any suggestions?
Old May 5th 16, 06:47 PM posted to rec.aviation.soaring
Settings are specific to your sailplane only. Not everyone may have the same pitot/static source and performance as you. Have you tested (individually) your factory pitot and static sources for leaks? Are you mixing mechanical and electronic varios on the same pitot/static source?
There's no "magic" here -- it should not take you more than 5 minutes per electronic vario to find suitable compensation settings on an early morning test flight.
Butterfly vario compensation Ben S Soaring 1 September 29th 14 04:03 PM
Electronic versus Pneumatic compensation (conclusions) [email protected] Soaring 0 September 26th 05 05:02 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 4 September 20th 05 06:21 PM
Electronic versus Pneumatic compensation (follow-up) [email protected] Soaring 2 September 20th 05 06:04 AM
Electronic versus Pneumatic compensation in LX7000 [email protected] Soaring 8 September 15th 05 02:49 AM
