Is the 787 a failure ?
On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote:
When you want it really really bad, that's generally how you get it... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. That's TECHNICAL ... "legal" ... has NOTHING to do with how potential passengers should act or react. Passengers are convinced the 787 is a death-trap. That's ALL it takes to destroy it. |
"Mr.B1ack" wrote: On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote: When you want it really really bad, that's generally how you get it... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. That's TECHNICAL ... "legal" ... has NOTHING to do with how potential passengers should act or react. Passengers are convinced the 787 is a death-trap. That's ALL it takes to destroy it. All planes are death traps. You can't pull over to a cloud & call for a tow, for any of them. |
On Jan 26, 11:28*am, "Michael A. Terrell"
wrote: "Mr.B1ack" wrote: On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote: When you want it really really bad, that's generally how you get it.... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. *If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. * *That's TECHNICAL ... "legal" ... has NOTHING to do * *with how potential passengers should act or react. * *Passengers are convinced the 787 is a death-trap. * *That's ALL it takes to destroy it. * *All planes are death traps. No, this isn't the 1930's anymore. You can't pull over to a cloud & call for a tow, for any of them. Since then, you hardly ever have crashes because of all-weather designs, flight patterns and glide paths (in case you need to land). |
On Sat, 26 Jan 2013 01:42:01 -0600, "Mr.B1ack"
wrote: On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote: When you want it really really bad, that's generally how you get it... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. That's TECHNICAL ... "legal" ... has NOTHING to do with how potential passengers should act or react. Passengers are convinced the 787 is a death-trap. That's ALL it takes to destroy it. You are convinced passengers are convinced. There have been no deaths, no injuries, and only limitted damage to this point. A minor tweek will likely solve the battery problem. It appears to be a problem with the APU not knowing how to handle Lithium batteries, as the problem occurs when on the ground with the APU running the system. |
On Sat, 26 Jan 2013 20:56:43 -0500, clare wrote:
On Sat, 26 Jan 2013 01:42:01 -0600, "Mr.B1ack" wrote: On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote: When you want it really really bad, that's generally how you get it... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. That's TECHNICAL ... "legal" ... has NOTHING to do with how potential passengers should act or react. Passengers are convinced the 787 is a death-trap. That's ALL it takes to destroy it. You are convinced passengers are convinced. There have been no deaths, no injuries, and only limitted damage to this point. A minor tweek will likely solve the battery problem. It appears to be a problem with the APU not knowing how to handle Lithium batteries, as the problem occurs when on the ground with the APU running the system. I love it when people who have no ****ing idea what's going on, make **** up like "a minor tweek will fix it". |
Marvin the Martian wrote: I love it when people who have no ****ing idea what's going on, make **** up like "a minor tweek will fix it". Why? Just because that's what they said when they took you to the veterinarian to have you neutered? |
On Sun, 27 Jan 2013 00:51:59 -0500, Michael A. Terrell wrote:
Marvin the Martian wrote: I love it when people who have no ****ing idea what's going on, make **** up like "a minor tweek will fix it". Why? Just because that's what they said when they took you to the veterinarian to have you neutered? Wow, you're clever. You must know everything given you have such a wit. No, the point being that NO ONE knows what the problem is. If it was a "minor tweek", they would have fixed it after the FIRST fire. |
On Sat, 26 Jan 2013 23:29:30 -0600, Marvin the Martian
wrote: On Sat, 26 Jan 2013 20:56:43 -0500, clare wrote: On Sat, 26 Jan 2013 01:42:01 -0600, "Mr.B1ack" wrote: On Fri, 25 Jan 2013 22:21:55 -0600, F. George McDuffee wrote: When you want it really really bad, that's generally how you get it... ----------------------- On Fri, 25 Jan 2013 20:54:55 -0600, "Mr.B1ack" wrote: snip Now from a business point of view however ... snip These URLs may be of interest. If an emergency is defined as an event that was unanticipated in occupance and limited in duration, clearly this is no emergency. That's TECHNICAL ... "legal" ... has NOTHING to do with how potential passengers should act or react. Passengers are convinced the 787 is a death-trap. That's ALL it takes to destroy it. You are convinced passengers are convinced. There have been no deaths, no injuries, and only limitted damage to this point. A minor tweek will likely solve the battery problem. It appears to be a problem with the APU not knowing how to handle Lithium batteries, as the problem occurs when on the ground with the APU running the system. I love it when people who have no ****ing idea what's going on, make **** up like "a minor tweek will fix it". When you look at the complexity of the APU unit, it WILL be a relatively minor tweek. |
... When you look at the complexity of the APU unit, it WILL be a relatively minor tweek. ... I don't think replacing the batteries with a safer, heavier technology and redesigning/recertifying the electrical systems of the plane can even be called a "tweak," let alone a "minor tweak." | | MIT Professor: Battery Fix Could Ground 787 Until 2014 | ... | In a nutshell, Sadoway thinks that Boeing needs to monitor | the temperature and cool each of the eight cells of the | 787's lithium-ion battery or switch to an older battery | technology that has a far better safety record -- nickel | metal-hydride (NiMH). | | If Boeing opts to substitute NiMH for lithium-ion, | certification could result in delays of up to a year -- | effectively grounding the 787 until 2014. | ... | When Sadoway got a look at the lithium-ion battery used in | the 787, he was surprised by "the seeming absence of a | cooling apparatus." | ... http://www.forbes.com/sites/petercohan/2013/01/27/mit-professor-battery-fix-could-ground-787-until-2014/ --bks |
Similar Threads | ||||
ATC failure in Memphis | Mxsmanic | Piloting | 77 | October 11th 07 03:50 PM |
The Failure of FAA Diversity | FAA Civil Rights | Piloting | 35 | October 9th 07 06:32 PM |
The FAA Failure | FAA Civil Rights | Instrument Flight Rules | 0 | October 8th 07 05:57 PM |
Failure #10 | Capt.Doug | Piloting | 7 | April 13th 05 02:49 AM |
Another Bush Failure | WalterM140 | Military Aviation | 8 | July 3rd 04 02:23 AM |
