Micro-wind energy
Old February 8th 14, 04:46 AM posted to rec.aviation.soaring
JS
Default Micro-wind energy
Seems a bad idea to me.
As Dan suggested, there is no need for all this with good batteries.
A couple of Tenergy or K2 12V 10A/H LiFePO4 would be the best solution. You can do 1000k with a VGA moving map display and transponder (plus the usual assortment of crap) running from pre-flight to flight download. The batteries will still be above 12V afterwards.
Besides the aerodynamic drag and storage problems, what time and money are involved to replace the canopy after a bad deployment or retrieval of one of those generators? It will happen sooner or later.
With that consideration, even phosphate batteries are cheap.
Old February 8th 14, 05:06 PM posted to rec.aviation.soaring
Dan Marotta
My concern with the LiFeP04 batteries concerns my hangar arrangement. Two
of my three batteries require tools or removal of the tail to get them out
of the glider so my glider stays connected to "smart" chargers continuously.
At present, I'm not comfortable with leaving a lithium battery connected all
the time. Is it safe as with the AGM batteries?
"JS" wrote in message
Old February 8th 14, 05:44 PM posted to rec.aviation.soaring
Dave Springford
Well ... it is not safe to leave any battery on continuous charge inside the glider. All it takes is for the charging circuit in the smart charger to fail and pump too much into the battery and then boom!
However, as long as one believes in the charger, then yes, it is safe to leave the LiFePo4 batteries on their smart charger. The K2 batteries have a Battery Management System (BMS) built into the battery case, so this also helps to regulate the charge.
With both the smart charger and the BMS looking out for the battery it should be safer than the single redundancy of the lead-acid charger.
Another option is to buy a $10 plug-in timer and run the charger through the timer and set it to charge for a limited time period each day. We do this with our tow plane batteries through out the winter to keep them topped-up while the runway is under feet of snow.
Suggestion: wind energy will make gliders cheaper RichardFreytag Soaring 20 April 24th 10 06:37 AM
Vector Wind, Relative Wind calculation C 302/303 [email protected] Soaring 2 December 9th 08 07:23 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) JR[_2_] Aviation Photos 0 August 13th 08 09:36 PM
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) JR[_2_] Aviation Photos 0 August 13th 08 09:35 PM
Need Micro Balancer Jim Rotorcraft 35 August 26th 03 01:34 AM
