Another E glider concept
Old August 17th 20, 01:21 PM posted to rec.aviation.soaring
Dan Marotta
Default Another E glider concept
The chines are improve handling at Mach 3.Â* Don't you remember the SR-71?
And didn't the ending credits say that it was a Master's Thesis in
design or something similar?
On 8/17/2020 5:40 AM, Martin Gregorie wrote:
On Sun, 16 Aug 2020 20:04:19 -0700, Marc Ramsey wrote:
On Sunday, August 16, 2020 at 6:19:27 PM UTC-7, wrote:
If you mean the fins on either side of the nose clearly marked
"sensor", likely angle of attack vanes. Not very useful when the
motor is running...
Not thinking about the sensor fin.
at 0:25 in the video. The horizontal line mid screen a few inches below
the canopy. Looks like a transition between a flatish underbelly and
vertical cockpit upper side. Looks like the chines under a boat?
I see what you mean, the odd transition between the upper and lower
fuselage profile that extends to the tail. Perhaps structural, or for
style? I find it hard to believe it does much for the aerodynamics
except produce a bit of drag.
Graphical artifact?
In the top view just from the right it looks as though it sticks out as
far as the sensor does and is blurred, while from the top left it only
seems to extend a cm or so and in other views it just looks like a
blurred line along the fuselage.
Dan, 5J
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [4/5] - "Eclipse Concept Jet 4.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [3/5] - "Eclipse Concept Jet 3.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [2/5] - "Eclipse Concept Jet 2.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (0/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
Saturday 072807 in Oshkosh Pt 4 - the Eclipse Concept Jet [1/5] - "Eclipse Concept Jet 1.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 04:02 PM
