Panel Materials
Old September 28th 07, 05:48 PM posted to rec.aviation.soaring
Default Panel Materials
If you are going to be doing any composite cutting, I'd make sure you
use a diamond bit or blade. Carbide works, but diamond will still last
longer. Also, if possible use water when cutting, this keeps the blade
cool and will make it last longer, and keep the dust down. Wet tile
saws work great.
Be sure to wear a mask, carbon fiber can get nasty.
Todd
www.sandwichpanels.org
Old September 28th 07, 06:02 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
Brian wrote:
If you really need a thin core you might look at just using a peice of
aircraft plywood.
You can also save a small amount of weight by using 1/8" medium to hard
model shop balsa for the core of a glassfibre panel - that's what
Libelle panels are made from. This may also make the panel easier to
make and to cut openings in than if it was ply. Glue the balsa together
with white wood glue before its final shaping and doing the glassfibre
layup.
If you put one or two layers of 200 gsm (6 oz/sq.yd) glass on either
side of the balsa you should have a good panel. Add a layer of 25 gsm
(3/4 oz/sq.yd) cloth outside the heavier cloth to get a nice, smooth
finish. As others have said, put a decently wide flange (25mm / 1")
round the bottom of the panel to protect your legs. If you make the
flange from all the layers surrounding the balsa that should do the trick.
As others have also said, if the panel is part of the fuselage structure
then buy a blank from the manufacturer.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Grounded - Where to get rid of the Building Materials? Rocketeer Home Built 49 July 22nd 06 11:43 PM
CFI training materials Steven Barnes Piloting 6 May 8th 06 03:20 PM
CANADIAN IFR TRAINING MATERIALS [email protected] Instrument Flight Rules 1 January 29th 05 11:51 AM
Instrument training materials Paul Folbrecht Instrument Flight Rules 3 July 15th 04 06:01 PM
Mixing construction materials Neal Fulco Home Built 3 October 7th 03 01:55 PM
