Aerotow towrope instructions
Old April 8th 16, 03:05 AM posted to rec.aviation.soaring
Bill T
Default Aerotow towrope instructions
Not a requirement per U.S. Regs, and they take a beating on gravel/paved runways.
BillT
Old April 8th 16, 11:31 AM posted to rec.aviation.soaring
I believe it is mandatory to operate a glider in accordance with the flight manual.
Old April 8th 16, 10:13 PM posted to rec.aviation.soaring
Bill T
I'll check my manuals, but as I recall, it only specifies rated strength of a weak link. Not the brand name of "TOST".
BillT
  #24
Old April 8th 16, 10:39 PM posted to rec.aviation.soaring
AS
BillT
There is an FAR that stipulates that any aircraft - experimental or standard cert. - shall be operated in accordance of the manufacturer issued POH. The 80-200% rule only applies to aircraft that do not have that detail written in their POH. So, the POH defacto becomes an FAR.
As for Tost or not: the weak links are well engineered and time proven devices, so if you can build a better mouse-trap, good luck. I have heard of gizmos using penny nails and similar as force limiting devices. If the sheath that protects the weak link takes a beating, you can slip it into a piece of clear plastic hose.
Uli
OLC contributions- Instructions joesimmers Soaring 3 May 7th 09 06:15 PM
Least favorite ATC instructions... ... ... caleb Owning 72 January 15th 06 02:48 PM
Tost Retract Towrope on a SuperCub John Sp Soaring 1 July 24th 05 09:09 PM
Instructions for BFG Loran C Mike W. Piloting 6 April 18th 05 04:19 AM
Towrope sources Paul Remde Soaring 1 January 2nd 05 02:57 AM
