#21
New Cobra trailer - - which top?
On Wednesday, February 11, 2015 at 9:14:19 AM UTC-8, Ben wrote:
So, if you were ordering a new Cobra trailer, would you order a fiberglass top or an aluminum top? For sake of discussion, lets exclude obvious price difference. I've never seen an aluminum top with insulation. What type of insulation is used and is it worth the 1000 plus euros? For those having a reasonably new Cobra trailer, in your opinion, what options are "mandatory" and what options are "losers"? Thanks for your feedback. I'm curious, what does one pay for a 15 meter Cobra Trailer delivered to a West Coast port? |
On Tuesday, February 17, 2015 at 8:00:31 PM UTC-8, wrote:
On Wednesday, February 11, 2015 at 9:14:19 AM UTC-8, Ben wrote: So, if you were ordering a new Cobra trailer, would you order a fiberglass top or an aluminum top? For sake of discussion, lets exclude obvious price difference. I've never seen an aluminum top with insulation. What type of insulation is used and is it worth the 1000 plus euros? For those having a reasonably new Cobra trailer, in your opinion, what options are "mandatory" and what options are "losers"? Thanks for your feedback. I'm curious, what does one pay for a 15 meter Cobra Trailer delivered to a West Coast port? Brand new?...20 ish..depending on extras etc. But that number is based on what the Euro was compared to the US Dollar 18 months ago. The Euro is about 20% cheaper now. |
The UV issue is solved by a black factory coating (gloss paint?) on the inside of the glass top. It was available in 1998+, maybe only as an option, but both my 1998 & 1999 have it.
On Wednesday, February 18, 2015 at 8:55:13 PM UTC-5, wrote:
The UV issue is solved by a black factory coating (gloss paint?) on the inside of the glass top. It was available in 1998+, maybe only as an option, but both my 1998 & 1999 have it. It has been a standard for a long time. |
Last two trailers I got the fiberglass and had a local craftsman insulate the interior. I thought the fiberglass looked better and was lees likely to form condensation. I was not sorry for my choice. I have also had AL tops, but as a personal preference I prefer fiberglass.
On Wednesday, February 18, 2015 at 9:18:19 PM UTC-5, Jonathan St. Cloud wrote:
Last two trailers I got the fiberglass and had a local craftsman insulate the interior. What did you use for the insulation? Kevin |
On Thursday, February 19, 2015 at 11:47:28 PM UTC+13, wrote:
On Wednesday, February 18, 2015 at 9:18:19 PM UTC-5, Jonathan St. Cloud wrote: Last two trailers I got the fiberglass and had a local craftsman insulate the interior. What did you use for the insulation? Styrofoam sheets are probably the only reasonable answer. If you want to make it more durable you can brush or roll or spray on a layer of epoxy resin or urethane. NOT polyester resin. And some thin glass mat if you want to be super fancy. |
#28
On Friday, February 20, 2015 at 12:33:49 AM UTC+13, Bruce Hoult wrote:
On Thursday, February 19, 2015 at 11:47:28 PM UTC+13, wrote: On Wednesday, February 18, 2015 at 9:18:19 PM UTC-5, Jonathan St. Cloud wrote: Last two trailers I got the fiberglass and had a local craftsman insulate the interior. What did you use for the insulation? Styrofoam sheets are probably the only reasonable answer. If you want to make it more durable you can brush or roll or spray on a layer of epoxy resin or urethane. NOT polyester resin. And some thin glass mat if you want to be super fancy. Movie and stage show people make a lot of scenery and props out of foam, and then need a hard coating on them to protect them. This seems to be one of the ones they use: http://www.fxsupply.com/materials/foamcoat.html Coverage seems to be about 150 sq ft per gal, so you might need about three gallons or $160 worth to do sides and top of a trailer. Here in Wellington, the same area of recycled polystyrene sheets will cost about twice that. |
#29
I used a closed cell soft foam. Not sure where my mechanic got it but it was ⅜ inch thick.
#30
Well that might protect the glider inside the trailer but it does
nothing for the fiberglass trailer top. On 2/18/2015 6:55 PM, wrote: The UV issue is solved by a black factory coating (gloss paint?) on the inside of the glass top. It was available in 1998+, maybe only as an option, but both my 1998 & 1999 have it. -- Dan Marotta |
Similar Threads | ||||
2013 Cobra trailer price list needed for TA trailer sale | [email protected] | Soaring | 0 | June 22nd 13 02:42 PM |
looking for used Cobra trailer | Brad[_2_] | Soaring | 3 | July 1st 11 02:58 AM |
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! | flyingmr2 | Soaring | 4 | November 16th 10 03:11 AM |
Cobra Trailer | [email protected] | Soaring | 22 | December 8th 06 12:38 AM |
Cobra Trailer | Soaring | 1 | September 28th 03 01:14 PM |
