Labels
Old January 1st 16, 11:40 PM posted to rec.aviation.soaring
Default Labels
Redoing my panel and looking for label material suggestions. Have used 3M Scotchcal vinyl film and Gerber Quantum marking films in past. Since they are designed for external vinyl signs, the printing holds up very well to UV. The problem is the adhesive. Since some of the labels are only 1/8" x 1/4", the surface area for adhesion is very small. In addition, the texture of the panel surface also reduces the surface area for adhesion. After a couple of years they start to come off. The films are designed for very large exterior signs where there is a large surface area for adhesion. Any suggestions? The only thing I could think of was to use a small dab of epoxy on the back of each label.
Old January 2nd 16, 12:08 AM posted to rec.aviation.soaring
Default Labels
Transfer tape we use for seals makes an excellent label backing.
UH
Old January 2nd 16, 04:53 PM posted to rec.aviation.soaring
Default Labels
I've used engravers.com with good results. They'll make placards any size, thickness you design for very low price, ~$10 for two 1/2" x 4".
Old January 2nd 16, 04:56 PM posted to rec.aviation.soaring
Default Labels
I've used engravers.net with good results. They'll make placards any size, thickness you design for very low price, ~$10 for two 1/2" x 4".
Old January 3rd 16, 08:46 AM posted to rec.aviation.soaring
Andy Gough[_2_]
Default Labels
The texture of the surface you are applying the label to is the problem. You need a thicker adhesive to get down into all the grooves. 3M468 transfer adhesive is five thousands of an inch thick and 3M467 is two thousands. There are other products that will give the same performance.
Jepp Flitemap - text labels, weird font sizes [email protected] Instrument Flight Rules 3 May 4th 05 10:21 PM
Jepp Flitemap - text labels, weird font sizes [email protected] General Aviation 2 May 4th 05 10:21 PM
Jepp Flitemap - text labels, weird font sizes Peter R. General Aviation 0 May 4th 05 10:18 PM
CFS3- Turn off labels? bernard spilman Simulators 1 December 29th 04 03:32 AM
Labels for cockpit? [email protected] Home Built 17 May 11th 04 07:12 AM
