You have to buy the Garmin Serial cable for $38. However this will still
not work properly with Flitestar/Flitemap. It will upload a route from Flitestar but it will not substitute the waypoints with the actual items. In other words if you plan a route KFOK-CCC-KHTO you will find is has uploaded those custom user waypoints that will apprear over the airports and vor. This of course makes the upload worthless. The Garmin 295 would upload perfectly, leading me to think they have changed something in the protocol with the 296. Because the interaction between these two tools is some important, I have been sending emails and calling each manufacturer attempting to see if there is a resolution. Each one says its the other ones fault. Because this formerly worked fine with the 295 I assume the problem is with the 296. It sure would be nice if there was more competition in this arena. -- Rich Raine remove ----- for email www.eRaine.com "Bill Padley" wrote in message .. . Dave.. I didnt explain well..g There was a thread here previously to say that Flitestar did not work well with USB gps connections, only serial ..A serial to USB converter (theIOGEAR) was recommended ..all good so far... However garmins output from the 296 is on a very small connector (like a camera firewire connector) -on the other end is a usb plug ..how can the serial to USB converter be used when there is no serial connector on the garmin? How does the serial to usb converter actually get to the garmin? that was my question...I believe some people have it working with Flitestar , but I have no idea how! cheers Bill Padley london "Dave Butler" wrote in message ... Bill Padley wrote: I have just received my Garmin 296 , and also have the IOgear usb to serial adapter However , the cable provided by Garmin is a small connector on one end , and a usb on the other..the usb to serial adapter is expecting a the serial end to be plugged ito the GPS, which of course it cant...(no serial female socket) I didn't quite follow that description, but if what you need is a serial gender-changer, they are quite inexpensive and available. Check your local computer supply store. |
Rich
Thanks for that info...what a mess! keep us in touch if you get any more out of either manufacturer , though to be fair , if it worked with the 295 and now is broken , it does kinda point to Garmin ! all the best Bill Padley London "Rich Raine" wrote in message ... You have to buy the Garmin Serial cable for $38. However this will still not work properly with Flitestar/Flitemap. It will upload a route from Flitestar but it will not substitute the waypoints with the actual items. In other words if you plan a route KFOK-CCC-KHTO you will find is has uploaded those custom user waypoints that will apprear over the airports and vor. This of course makes the upload worthless. The Garmin 295 would upload perfectly, leading me to think they have changed something in the protocol with the 296. Because the interaction between these two tools is some important, I have been sending emails and calling each manufacturer attempting to see if there is a resolution. Each one says its the other ones fault. Because this formerly worked fine with the 295 I assume the problem is with the 296. It sure would be nice if there was more competition in this arena. -- Rich Raine remove ----- for email www.eRaine.com "Bill Padley" wrote in message .. . Dave.. I didnt explain well..g There was a thread here previously to say that Flitestar did not work well with USB gps connections, only serial ..A serial to USB converter (theIOGEAR) was recommended ..all good so far... However garmins output from the 296 is on a very small connector (like a camera firewire connector) -on the other end is a usb plug ..how can the serial to USB converter be used when there is no serial connector on the garmin? How does the serial to usb converter actually get to the garmin? that was my question...I believe some people have it working with Flitestar , but I have no idea how! cheers Bill Padley london "Dave Butler" wrote in message ... Bill Padley wrote: I have just received my Garmin 296 , and also have the IOgear usb to serial adapter However , the cable provided by Garmin is a small connector on one end , and a usb on the other..the usb to serial adapter is expecting a the serial end to be plugged ito the GPS, which of course it cant...(no serial female socket) I didn't quite follow that description, but if what you need is a serial gender-changer, they are quite inexpensive and available. Check your local computer supply store. |
