Sayit ain't so EAA! (Engines)
Old April 12th 14, 06:37 AM posted to rec.aviation.homebuilt
Default Sayit ain't so EAA! (Engines)
On Saturday, May 4, 1996 12:30:00 PM UTC+5:30, Gregory R. TRAVIS wrote:
In what one can only imagine was an editorial gaffe of epic proportions
( ;-) ), this month's _Sport Aviation_ reports the following:
"The Continental IO-550G (Venture engine) was certified at
280 hp using 2500 rpm. The engine had tuned induction (top
of engine) [This is the Continental factory tuned induction - GRT]
and neutral exhaust (8" stubs out the bottom of the cylinder).
The calibrated test engine delivered 284 hp and 0.375 bsfc.
This same engine was fitted with a tuned/muffled exhaust
and delivered 302 hp, .365 bsfc, and peaked all EGT's [sic]
within 1% fuel flow during lean out."
[May 1996, p. 81, "EPG III" ]
Can they really be saying that:
1) A stock factory engine actually delivered 4 more horsepower than
it was rated for?
2) That stock factory BSFCs for the IO-550 are around 0.375?
3) That with relatively minor modifications (confined to the
EXHAUST system!) the factory engine produced 22 hp more
than its certification called for (and 8 more than legally
allowed for by law for a certified 280 hp engine)?
4) That with the same exhaust modifications, the engine got into
the CI-engine (diesel) threatening 0.365 bsfc range?
But what about the pistons the size of dinner plates? Where are the
four valves per cylinder? How about the dual overhead cams? The
electronic sequential multiport fuel injection?
It's just not that easy to believe that a two-valve, six cylinder, 550CID
engine with a single cam and pushrod activated vales can deliver that
kind of performance with a mechanical continuous fuel injection system
and magnetos. Is it?
greg
Primary purpose of an IC Engine is to give TORQUE.
All IC Engines produce torque in SINE WAVE. Co sine components of forces acting on piston are wasted as heat, noise & vibrations. This is so right since IC Engine invention. No one else has so far EVEN POINTED IT OUT.
I have done extensive research on this aspect & have invented TEJJ Constant Torque IC Engine which eliminates all co sine component losses. It is Patent pending in India. It offers following major advantages:
1. Maximum possible continuous torque (for 4 cylinder engine) like an electric motor.
2. Smoother, cooler & quieter engine.
3. Work done per power stroke increases by 55% compared to similar sized exiting engines.
4. Considerable fuel savings.
5. Improvement in power & pick up.
6. Reduction of green house gases.
7. Existing 2nd, 3rd, 4th &5th gear ratios can be used for 1st to 4th gear in vehicles with TEJJ IC Engine. 5th gear over drive ratio can be suitably increased.
Detailed advantages with graphics are available at http://www.patentauction.com/patent.php?nb=7706.
I need some institutional or manufacturers support for developing the idea further. It can really bring PARADIGM SHIFT IN ENTIRE INDUSTRY.
Any one interested can contact me at or on my mobile number +919424140739.
Old April 13th 14, 04:25 AM posted to rec.aviation.homebuilt
Bugs
Wrong.
The Dyna-Cam design may, depending on the profile of the cam.
Reciprocating engines... nope.
Preheating engines: Airplane engines versus auto engines Peter R. Owning 86 January 2nd 08 07:48 PM
rl-10 engines.jpg [email protected] Aviation Photos 0 April 10th 07 09:55 PM
o and io engines Lets Fly Owning 25 May 12th 06 10:29 PM
new engines Neal Fulco Home Built 7 September 12th 04 08:21 PM
Need Cox Engines Alan Home Built 4 January 16th 04 07:08 AM
