Fuse for radio
Old July 13th 19, 05:24 PM posted to rec.aviation.soaring
soaringjac
Default Fuse for radio
Anyone know what fuse rating i would need for an old Edo-Aire RT-551 radio. Its marked inop now but i still want to replace the fuse in the panel for it
Old July 14th 19, 01:12 AM posted to rec.aviation.soaring
Scott Williams
a couple of months ago I bought a Glasflugel Mosquito with an RT-551, the power circuit has a 5 amp glass fuse and there were 5 amp spares in the side pocket.
While not authoritative, may help.
Good luck,
Scott
Old July 14th 19, 01:54 AM posted to rec.aviation.soaring
soaringjac
Good luck,
Scott
Awesome thanks Scott! That definitely helps!
Old July 14th 19, 07:40 PM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Between you, me, and the fence post, I prefer breakers rather than fuses. Breakers are easier to reset while in flight than replacing fuses.
Remember to use a minimum of 3A fuses/breakers or risk loosing precious volts. See page 86 of this presentation http://aviation.derosaweb.net/presentations/#wiring.
John OHM
Old July 15th 19, 04:07 PM posted to rec.aviation.soaring
krasw
On Sunday, 14 July 2019 21:40:14 UTC+3, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
John OHM
Why would you ever need to reset breaker during flight? Breakers protect your wiring, if your wires shorted, are you sure you wan't to reset the situation during flight?
Old July 15th 19, 04:57 PM posted to rec.aviation.soaring
kinsell
John OHM
In many years of flying, never have blown a fuse or popped a breaker.
If your wiring is shorted or an instrument has a fault, take care of it
on the ground.
Personally I think a five amp blown fuse is the perfect companion for an
inop radio. Why waste your money on a breaker?
Old July 15th 19, 08:48 PM posted to rec.aviation.soaring
I always try to size the fuse to match the expected draw of the device I'm protecting. No idea what an RT-551 radio draws but a Becker 3201 draws a max of 1.4 amps when transmitting (according to their literature, anyway). So, if you protect it with a 2 amp rated fuse then Ohms law tells us that you'd only lose 0.11 volts across the fuse (E=IR or 0.109v = 1.4 A * 0.078 ohms). Negligible. I guess I don't really understand all of the concern over losing 1 tenth of 1 volt across the fuse.
Robert
On Sunday, July 14, 2019 at 1:40:14 PM UTC-5, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
John OHM
Old July 16th 19, 12:47 AM posted to rec.aviation.soaring
kinsell
I was just flying with a friend who had a 1 amp breaker, installed by
the glider factory, protecting a fancy LXNav flight computer. Manual
said current draw was 700 ma. Unfortunately the breaker was popping
frequently at the end of long flights.
Manual for the LXNav recommended a 3 amp breaker. It probably draws
more current at low voltage, I assured him a 3 amp breaker would be a
fine choice.
No sense trying to use the tiniest fuse or breaker you can, just use
something appropriate to protect the wiring. Breakers are great for
airline pilots who like to have lots of buttons to push.
Robert
John OHM
Old July 16th 19, 01:38 AM posted to rec.aviation.soaring
On Monday, July 15, 2019 at 2:48:29 PM UTC-5, wrote:
I always try to size the fuse to match the expected draw of the device I'm protecting. No idea what an RT-551 radio draws but a Becker 3201 draws a max of 1.4 amps when transmitting (according to their literature, anyway). So, if you protect it with a 2 amp rated fuse then Ohms law tells us that you'd only lose 0.11 volts across the fuse (E=IR or 0.109v = 1.4 A * 0..078 ohms). Negligible. I guess I don't really understand all of the concern over losing 1 tenth of 1 volt across the fuse.
Robert
John OHM
Robert,
Yes, you are correct that a lowly 1/10Vdc across one fuse is a pretty small loss. But is that everywhere you are loosing volts in your panel? Do you also have a fuse at your battery? What about your wiring? What gauge is it (too small)? How long is the run? (You might be surprised how long - don't forget the positive lead forward and then the negative lead back again) Corrosion? Even the master switch looses something! Connections/connectors too. So watch out for those lost nickels and lost dimes because it all adds up. My $0.02.
- John
Old July 16th 19, 02:11 AM posted to rec.aviation.soaring
Gary Wayland
On Sunday, July 14, 2019 at 2:40:14 PM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
John OHM
Are you saying there's (more) voltage drop as the fuse gets smaller? I know, I should never question a guy about electronics with a guy that has OHM in it! What is the resistance load, in ohms, for a 1, 3, or 5 amp fuse?
Also, we are trying to protect equipment, AT the expense of any voltage drop, if there is any... Regards, Gary
Cambridge 302 fuse [email protected] Soaring 6 December 18th 18 03:36 PM
ASW 27 Fuse ballast tank FS pat Soaring 0 July 22nd 12 05:56 PM
B40 fuse question Tuno Soaring 3 December 8th 08 07:43 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
