Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
Wiring diagram for GA radio/mic?
Old November 2nd 05, 01:17 PM
Gary G
Default Wiring diagram for GA radio/mic?
Would anyone be kind enough to point me to a wiring
diagram for a general aviation radio?
I need to know the pinout configurations and voltage
for the mic connection.
Thank you and regards in advace!
Gary
Old November 2nd 05, 05:09 PM
RST Engineering
Gary --
No offense, but you are getting to be a PITA with this microphone stuff.
Ask the question in ONE newsgroup and you will probably get the answer you
want. Ask it in three or four and you are being a nuisance.
"Gary G" wrote in message
Gary
Old November 3rd 05, 02:10 AM
Jon A
On Wed, 2 Nov 2005 09:09:27 -0800, "RST Engineering"
Gary --
Have you answered him, Jim? You should be the one since you're the go
to guy on radio work.
Gary, has Jim answered your question? If not keep asking. If so, his
answer is correct, look no further.
Gary
Old November 3rd 05, 03:22 AM
RST Engineering
Definitively, in RAH, where he started this post in the first place without
spamming it across four newsgroups.
Old November 3rd 05, 03:18 PM
Gary G
With all due respect - why is it that you care about that.
If it doesn't concern you, why bother?
I don't see that many people agree with you on that.
Judge and Jury convened and departed in your mind already?
No - I did not get an answer.
Most thankful regards,
Gary
Old November 3rd 05, 03:19 PM
Gary G
Spamming my ass.
Let's see - help fellow pilots out . . . .ask a qeustion . . .SPAM
DOES NOT COMPUTE!
Whatever . . .
Thanks to EVERYONE ELSE for your valuable input and
offers to help.
Old November 3rd 05, 07:35 PM
Gord Beaman
Poor Jim...he's had a bug crossways up his arse for several years
that I know of...
-Gord.
(use gordon in email)
Old November 4th 05, 12:09 AM
On Thu, 03 Nov 2005 09:18:42 -0600, Gary G
Gary
"With all due respect" - perhaps after posting in multiple groups,
you neglected to go back and check them all for "an answer".
It sure looks like you got an answer to me, just not in RAM.
If you think you'll get anywhere twisting Jim's tail, knock yourself
out. The really, really funny thing is, he's probably the best 'group
resource available for concise, accurate answers to GA
avionics-related questions.
see below;
TC
From RAH, not RAM
On Wed, 02 Nov 2005 07:15:48 -0600, Gary G
Gary
Same thread, also from RAH
On Wed, 02 Nov 2005 14:30:17 GMT, Orval Fairbairn
There is VERY low voltage involved -- #22 AWG (shielded) wire will
suffice.
There are three hookups to the jack: Mike Key, Mike Audio and Mike Ring.
Ring goes to Ground
Key goes to a switch, which grounds the key circuit. This activates the
transmit relay in the radio.
Mike Audio passes straight through to the radio audio circuit and
carries the voice. This wire should be shielded, to reduce EM
interference.
IIRC, the audio is the tip of the jack; the key is the next position on
the jack. Ground is the outer (long) part of the jack. Check with a
circuit tester.
Still in the same thread...
On Wed, 2 Nov 2005 09:07:30 -0800, "RST Engineering"
Not quite, Orval. From the leading edge of the male connector (microphone
end as opposed to the aircraft end) the sections of the plug are tip, ring,
and shell.
Grounding the tip places the transceiver in the transmit mode; ungrounding
it (open) leaves the transceiver in the receive mode.
The ring carries the microphone audio (more later).
The shell is airframe or chassis ground.
The mic audio line coming from the transceiver is a current source that is
intended to provide a 300 ohm mic element with about 10 mA. Generally this
is a simple resistor fed from a quiet regulated supply inside the
transceiver. I usually use the +10 volt supply and a 680 ohm resistor. The
microphone circuit is designed to emulate a carbon microphone (variable
resistance with audio) and will give somewhere between half a volt and a
volt peak to peak with normal mic audio.
Old November 4th 05, 01:02 AM
Jon A
On Thu, 03 Nov 2005 19:35:05 GMT, Gord Beaman
that I know of...
Yea, and when Arnold beat him in the California gubernatorial race, it
really sent him over the edge ;-)
Old November 4th 05, 04:04 AM
RST Engineering
Yeah, and when Arnold gets his ass handed to him on a plate in next week's
elections, I'll chuckle that it was my colleagues (teachers, cops, firemen,
public service nurses) that did it.
He who laughs last, laughs loudest.
Wiring Diagram for Edo Aire RT-551? Gary Emerson Soaring 4 December 16th 15 02:06 PM
ball 101A wiring diagram coneil Soaring 4 June 22nd 04 06:55 AM
Dittel FSG50 wiring diagram Chris Davison Soaring 0 October 15th 03 07:23 AM
King KMA-26 Wiring Diagram Keith Dobbins General Aviation 0 August 23rd 03 04:03 AM
Kawasaki TA-440 2B wiring diagram. jackthepilot Home Built 1 August 4th 03 06:33 PM
